Question about M&S Systems DMC1CD 6-Disc CD Changer
Eroor1 on cd display
Cd box is pushed out
CD menu is displayed ROOT Mode Normal Folder How can I watch the CD
Hold the stop button for 10-20 seconds and the unit will reset. This will solve the problem.
Sep 06, 2012 | Cyberhome CH-DVD 300 DVD Player
Reset radio and now cd changer doesn't work or even display when pushing button
try this and thats to remove the cartridge and take all the cds out ,then insert the empty cartridge into the set to see if it removes the last cd that was in the player ,then with one cd in try it again and if that doesnt work then disconnect the battery and try again other than that i have no idea sorry
Apr 12, 2012 | Honda Cars & Trucks
CD stuck in my Honda Odyssey CD changer
Turn van off. Open & close drivers door, wait for everything to power down. Turn van back on and push button to close CD/Nav opening. It will close. Having an issue with CD player also.
Mar 19, 2012 | 2008 Honda Odyssey EX-L
The 2006 Grand Vitara 6 cd changer is jammed. Do you have any suggestion? When turned on display reads cd 1 loading, shortly afterwards push eject displays. I push eject, with no response. Do you have any...
If it is an in dash changer I would recommend you replace it with an aftermarket single disc player. In dash changers are notoriously unreliable and go bad easily.
Jun 06, 2011 | Car Audio & Video
Protect- push power
After installing the cd display shows the Push Power in the model of MHC-RV5
Jul 07, 2009 | Sony DVP-S330 DVD Player
Error 11
Error 11 and or Error 17 is mean that CD is dirty or scratch, and the optic can not detect CD track.
Solved problem:
1. Clean the CD
2. Change open source by push knob going to "CD" display or push "search" from remote to "CD" display
3. If still come out Error 11, change the MP3 CD by Original CD with clean track CD.
4. For the last step, clean the optic sensor by CD cleaner for a few minute.
5. Check and try to play the CD again.
Apr 26, 2009 | Pioneer Car Audio & Video
Numark Cd-Mix-2 left side disk problem
Cd drawer and laser assembly are belt driven. Belt needs to be replaced
Sep 08, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
2 questions
Hold down the Display/Menu function button (one of those three buttons on the left of the unit) for about 3-4 seconds until the display reads "t set". When this appears, push the track forward button once (>>|) so the display reads "beep"; now press the play pause button (>||) once. The display will now say "on", push the track forward button (>>|) once to make it read "off"; now push the stop play button. You're done. Enjoy the silence.
Mar 14, 2008 | Sony Walkman D-EJ100 Personal CD Player
FW-R7 displays "Locked" when attempting to open CD Trays
You were close, but didn't explain it very well. If you push on the 'DISPLAY' button (left side of machine as you are facing it, about half way down) when the unit is off, it will say something like "DEALER MODE", push it again to return it to regular mode. You may have to press and hold the button to get it to display 'DEALER MODE', then when everything is normal, "DEALER MODE" just goes off and isn't replaced by anything. Hope I explained it well. nyati585@aol.com
Feb 09, 2007 | Philips FW-R7 CD Shelf System
46 people viewed this question
Top M&S Systems Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Tre Elkins
Are you a M&S Systems Audio Player and Recorder Expert? Answer questions, earn points and help others
