Dll tool license key - Computers & Internet
SERIAL NUMBER
1) Run wga tool to check - genuinity , type of copy (OEM/Retail)
Link :
http://go.microsoft.com/fwlink/?linkid=52012
Shortlink :
http://downloadwgadiagtool.notlong.com
2) Check date/time
Do the below troubleshooting steps in safe mode
3) Check the "value data" for the following keys under HKEY_CLASSES_ROOT\.htm
1. Default
2. Content Type
3. PerceivedType
- Double click each of the above keys
- check the value data (default value data)
Defaut = htmlfile
Content Type = text/html
PerceivedType = text
- If the value data is different, change it to the above default value
4) Reregister the following dll files
regsvr32 licwmi.dll
regsvr32 regwizc.dll
regsvr32 licdll.dll
regsvr32 jscript.dll
regsvr32 vbscript.dll
regsvr32 msxml.dll
regsvr32 shdocvw.dll
regsvr32 softpub.dll
regsvr32 wintrust.dll
regsvr32 initpki.dll
5) Rename/replace the dll files
rename c:\windows\system32\licwmi.dll licwmi.old
rename c:\windows\system32\regwizc.dll regwizc.old
rename c:\windows\system32\licdll.dll licdll.old
rename c:\windows\system32\wpabaln.exe wpabaln.old
expand d:\i386\licwmi.dl_ c:\windows\system32\licwmi.dll
expand d:\i386\regwizc.dl_ c:\windows\system32\regwizc.dll
expand d:\i386\licdll.dl_ c:\windows\system32\licdll.dll
expand d:\i386\wpabaln.ex_ c:\windows\system32\wpabaln.exe
copy c:\windows\system32\licwmi.dll c:\windows\system32\dllcache
copy c:\windows\system32\regwizc.dll c:\windows\system32\dllcache
copy c:\windows\system32\licdll.dll c:\windows\system32\dllcache
copy c:\windows\system32\wpabaln.exe c:\windows\system32\dllcache
6) Initiate to activation tool
- Create a new dword value under HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows
NT\CurrentVersion\Winlogon
- dword value named : Activation Required
- set the dword value as : 1
(or)
- goto HKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT\Current
Version\WPAEvents\oobe timer
- change atleast one digit of oobe timer value data
7) Delete RESET5 keys
- start > search tool > search for reset5.* > delete all the files
8) Rename/replace WPA.DBL file
ren c:\windows\system32\WPA.dbl wpadbl.old
MGA Diag : http://go.microsoft.com/fwlink/?linkid=52012
Validation tool : http://www.microsoft.com/genuine/diag/
Regards
Apr 27, 2012 | Microsoft Windows Vista Home Premium with...
Daemon tools lite cd key
Dear ghinea_denys, Daemon Tools Lite doesn't need any CD key if used for non-commercial use. It can be installed both as a Shareware and a Freeware. While you are using it for Commercial Use you have to activate the Paid License, and in that case you must provide it with a License Key. To use it for personal and non-commercial work, you should activate the Free License, which will help you install Daemon Tools Lite to your computer without any CD key.
You can download the latest Daemon Tools Lite 4.41.3 from the link below:
http://www.daemon-tools.cc/
N.B. : License key is also needed for using Daemon Tools Pro as full version.
Hope this helps,
Regards,
Mrityunjay.
Aug 05, 2011 | Computers & Internet
I need dll-files.com fixer license key
Download link http://downupfiles.com/0s3nt for Dll Files Fixer v3.0.81. incl. Crack by SMT. You don't need any Serial key for register dll files fixer, with this crack Dll Fixer will works like charm.
You may watch video tutorial on this link Dll Files Fixer License Key
Apr 11, 2011 | Computers & Internet
Tsbyuv.dll is missing in windows xp home edition
http://www.fix-all-dll-errors.com/tsbyuv.dll/
You can get find it here..follow the link. :)
Oct 30, 2009 | Microsoft Windows Xp Home Edition Sp2...
I cannot load some programmes. I get an error 429 activex component message., Is there a free vista available to run over the top to fix any or all problems i might have on my system
cause : This issue can occur when DAO dynamic-link library (DLL) files are mismatched or when there are incorrect registry entries. This issue can also occur when there is a missing DAO design-time licensing key. This key is required by Microsoft Excel, but is not required by applications created with Visual Basic
Method 1 loadTOCNode(2, 'resolution');
  1. Click Start, and then click Run.
  2. In the Open box, type regsvr.exe.
  3. Re-register DAO350.dll.
    NOTE: You can obtain a copy of DAO350.dll at the following FTP address: ftp://ftp.microsoft.com/softlib/mslfiles/ To register DAO350.dll, follow these steps:
    2. In the Open box, type Regsvr32.exe C:\progra~1\common~1\micros~1\dao\dao350.dll
    3. Click OK.
  4. Click Start, point to Settings, and then click Control Panel.
  5. Click Add/Remove Programs.
  6. Insert your Microsoft Office 97 CD, and then click Uninstall.
  7. Delete the DAO folder from the hard drive.
  8. Click Start, point to Settings, and then click Control Panel.
  9. Click Add/Remove Programs.
  10. Insert your Office 97 CD, and then click Install.
  11. Repeat steps 4 through 6 to uninstall Office 97.
  12. Click Start, and then click Run.
  13. In the Open box, type eraser97.exe. (This file is also available at ftp://ftp.microsoft.com/softlib/mslfiles/.)
  14. Repeat steps 4 through 6.
  15. Repeat steps 8 through 10 to reinstall Office 97.
Please Rate Solution!
Sep 08, 2009 | Computers & Internet
Install missing dll file
Dear
If u have missing .dll file (download from web)
copy .dll file to c:\windows\system32
go to run and type (if ur dll file is abc.dll)
regsvr32 abc.dll
and press enter n ok
Oct 19, 2008 | Computers & Internet
Personal license key
what u meen personal key for mp3
Jan 24, 2008 | Computers & Internet
License key
it is on the license tag of your os cd case or stuck to your pc. There are freeware programs that can get the key, but I never used them don't know which kind to use. Spin and chance.
Dec 09, 2007 | Computers & Internet
Open Questions:
How do I fix my Toshiba laptop? Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 25, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
629 people viewed this question
David Payne
David Payne
