Question about Sony STR-DE685 Receiver
Sub-woofer wont play - Sony STR-DE685 Receiver
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: sub woofer is blowing up and down even when head unit is off
This is an internal power supply failure - most likely a failed capacitor or bad ground trace..
Your amplifier requires repair.
To verify this - remove the RCA cables and if the "heartbeat" is still present - take the amplifier to a local repair shop that specializes in car audio and tell them your symptoms.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Jun 10, 2009
I have AIWA NSX-RV85. The sub-woofer surround tore leaving just the cone. When I play, The woofer just makes a rattling sound coming out of vibrating cone.Any advise on how to fix my speakers.Thanks
Refit the rubber, you can find itbon eBay, its called reconing actually in this case the cone is the inlybpart wich you dont want to replace... The rattling is beingproducer due to the fact the rubber normally holds the cone ibto positionering over the coils. This rattling is not good can defect your cone. So dont play it roll you got a new rubber fitted!
Nov 08, 2016 | Aiwa Audio Players & Recorders
My powered subwoofer no longer works through the receiver
if you have your front and centers set to 'small' you want your Bass out to be subwoofer only, and the rca jack labeled 'sub out' is the only place to connect your sub to if you want to control the frequencies with your reciever. I dont know the brand of your sub, or the inputs on the back of it to advise you where to connect, but it sounds like it worked for you at one time, but suddenly it does not
Mar 05, 2013 | Audio Players & Recorders
I have a MTS surround sound system and when i put the volume up the woofer turns off. whats wrong with it? and how can i fix that
Seems you are over driving the unit and causing it to overheat and the protective circuits are kicking in. U need a more powerful system to play at the volumes you want.
Aug 26, 2017 | Audio Players & Recorders
Stereo without sub woofer how this setting
i have -VSX-D2011 when i want to stereo mode the sub woofer is automatic
play in stereo mode and disturb
i check all setting and much time waste on manual instruction
Stereo mode play only two front speakers if any one have knowledge about setting please help with advance thanks
Jun 26, 2012 | Pioneer VSX-D2011 Receiver
Subwoofer is not playing
It is hard to say. The sub-woofer has its own amplifier, although it is supplied the sound data from the main amplifier. It could have a problem with the battery power circuit (Sub-Woofer Amplifier Connector Pin 6, LIGHT GREEN/VIOLET) or it could have a problem with the GROUND circuit (Pin 2, BLACK/LIGHT GREEN) Or it could possibly not be receiving the signal from the main amplifier (Pin 7, BROWN/ORANGE "+"), (Pin 8, RED/BLACK "-"). Or it could be that either the sub-woofer speaker is blown, or the sub-woofer amplifier is defective.
There is also a "High Audio Mute" circuit that connects between the main amplifier and the sub-woofer amplifier.
Mar 06, 2012 | 2000 Lincoln Navigator
Can i power 2 12 subs a rockford punch z and a xplode with this amp i found all this **** in my garage and i need to know if it will power all this
First of all. Using two different kinds of sub woofers, is not an option, as these two sub woofers have different specifications and you should never mix sub woofers. Now the better choice from the 2, would probably be the Rockford. (cant be sure without knowing the models, power handling is also a factor in how well either of the sub woofers will play, but Rockford as a rule makes better sub woofers than Sony does) In my opinion, both the sub woofers deserve a better amplifier than what Boss has to offer. However to connect either of these sub woofers, you would need to determine how many voice coils it has and how many OHM the voice coil/s are. If it is a DVC (dual voice coil) and each voice coil is 4 OHM or 2 OHM, then you can connect one voice coil to one channel of the amplifier and the other voice coil to the other channel of the amplifier. If it is a DVC 2OHM you can also connect it wired in Series/Series to give a 4OHM load and should be connected to the BRIDGE dedicated speaker outputs of your amplifier. If it is a SVC (single voice coil) and it is 4 OHM, then you can connect the sub woofer to the designated speaker outputs of your amplifier that states BRIDGE. DO NOT run the amplifier in BRIDGE mode at 2 OHM as this will probably damage the amplifier. dreamsystems
Feb 18, 2011 | Boss Blade BL700 2-Channel Amp - 300W...
I lost my remote control and I want to turn on my sub woofer manually through my receiver. How do I turn on my sub woofer.
Perhaps I misunderstand the question.
Depends on the Sub. Most powered subs will go into standby mode in the prolonged absence of a signal. Then they wake up when you play something.
Or are you saying you need to Enable the Sub, as in setup? Remote probably required for anything like that.
Dec 02, 2009 | Aiwa AV-D58 Receiver
Sub-woofer shutting off
woofer circuit problem! it could have been overdriven causing overload to the component on the circuit. check woofer circuit for damage components, most likely power ICs and capacitors bulging
May 20, 2009 | Audio Players & Recorders
Connect Issue?
You need to make sure your using cable rated for use as Sub woofer don't use Audio or Digital Cables they're not the same.
Oct 20, 2007 | Samsung HT-DS1000 System
Sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Oct 08, 2007 | Audio Players & Recorders
Sony STR-DE685 Receiver Logo
22 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
