Question about Royal Sovereign Heating & Cooling
V lec air conditioner faults e3
The fault shows e3 shuts down
bobotfel
  • 236 Answers
SOURCE: Fault E3
Start the unit using the remote control, after that push the C button of remote control if C display at the unit then off the unit and plug out the power supply. Then plug in again and "on" the unit using the remote control.
Posted on Dec 30, 2007
  • 521 Answers
SOURCE: Fault E3
it indicates the problem of a compressor as the fan works fine .i feel the compressor is not able to cool the device.i will suggest you to get it checked by a proper technician.
Posted on Aug 09, 2008
  • 400 Answers
SOURCE: Water level float switch error
You do not mention the model, I presume that it is a cassette, in which case the float switch is located in the indoor unit. You have to remove the cover which is 4 screws. First make sure all power supply is turned off. Then remove the drain pan which surrounds the fan blade. You will see in one corner of the unit a slightly deeper part of the drainpan, this is the corner where both the condensate pump as well as float switch is located. Before you do any of this, give a serious blow into the drain pipe from outside and this may dislodge any sludge which may be causing the floatswitch to stick. You can also pull out a rubber plug which is under the pump on the drainpan.
Posted on Mar 05, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have a wind chaser portable air conditioner
They make a few different 12,000btu models.
Click HERE for the manufacturer's web page to select and download your specific manual.
These error codes are not available in the manual.
Please contact them Monday through Friday, between 8:30 am - 4:30 pm PST,
Toll Free 1-800-405-2943 Inside the US
1-310-827-8615 Outside the US
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Posted on Jul 28, 2009
  • 12 Answers
SOURCE: air conditioner runs for 5 minutes then shuts down
your ac's compraser is getting off due to heat in that area voltage is one of the big issue 2 your thermostat is not working properly of your motor is jammed not rotating properly RPM(running per minute)
Posted on Feb 02, 2010
Fault E3 Have same problem, fan works fine but will not turn on cold air. Display shows "e3". I have a remote, but do not see a button "c".
Try this : Start the unit using the remote control, after that push the C button of remote control if C display at the unit then off the unit and plug out the power supply. Then plug in again and "on" the unit using the remote control.
Aug 09, 2008 | Kenwood KW85 Air Conditioner
E3 error code
e3 error code comes when room not getting cool after 3 hours ac working, pls close all doors and windows and if possible try to run ac in an empty room for 1 hour , then check for fault,
Oct 13, 2013 | Kenwood KW85 Air Conditioner
E3 keeps coming up on my portable air conditioner
Would need to know what brand. E3 can be a sensor fault. Check and clean both in and out filters .
Aug 27, 2013 | Heating & Cooling
It won't start and displays E3 fault code. Manual says this is faulty coils? Took apart and cleaned all, looks good. Still has code displayed and won't run. How to clear fault code? Thank You.Jeff
E3 means "unit-abnormal protection to avoid occurence of unit damage."
Manufactures does not recommend that a homeowner try to attempt a repair on a code like this as it indicates possible wiring or internal problems. Have you checked for an internal fuse on the circuit board? I would also check the incoming power to make sure you have the proper voltage. You can also try unplugging the unit, waiting 30 seconds and plug back in to see if the code disappears.
According to A/A brands, if this code appears, shut off device and call authorized service company. I'm just trying to get you some things you can check yourself prior to doing that.
Hope this helps.
Jul 29, 2011 | Home Pride AA-TH 358 Air Conditioner
I have E3 showing up on my Conia air conditioner an cannot find the booklet that came with to find out how to fix it ???
Please check one of this:
E3 Fault room sensor(s) (open or closed circuit)Code
E3
Error detail Remote control transmission error (transmitting error)
Inspected unit Remote control.
Dec 10, 2010 | Heating & Cooling
Error code E2 A.C. AUX
Disply E2 error Coming
Jul 23, 2010 | Heating & Cooling
Error : E3 FAULT
i have problem ac indoor come on display e3 error problem kindly give me solution
Sep 16, 2008 | Kenwood KW85 Air Conditioner
Fault E3
Oct 28, 2007 | Kenwood KW85 Air Conditioner
CF 210 Delonghi
i just found out that e3 means voltage problems. i plugged my into a place i knew would have enough voltage and it started right up with ac
Sep 10, 2007 | DeLonghi CF210 Portable Air Conditioner
Heating & Cooling Logo
Top Royal Sovereign Heating & Cooling Experts
jdthefixer
Bill Long
Are you a Royal Sovereign Heating and Cooling Expert? Answer questions, earn points and help others
