Question about Lutron Sf-10p Skylark Single-pole 8a Sf10p Dimmer
How to wire a cooper devices sf10p dimmer switch
Cooper 9534SG-K master dimmer amber LED goes out when lightsbturned off
Any switch with a light in it needs power to the switch along with neutral
May 07, 2014 | Cooper Wiring Devices Aspire Smart Dimmer...
Wiring instructions for Cooper TR7730 combination wiring device
Hi Dave,
Great description, but you never mentioned what you are
using the switch for. I can explain in detail, but I need to
know if the switch load is coming from the same cable or
an additional one.
Dec 18, 2013 | Cooper Wiring Devices Electrical Supplies
Cooper wiring devices 390-6107xx-eg1d wiring diagram
This is the Cooper product #6107; Standard Series Occupancy Sensor, 3-Way, 500W/400W, Incandescent, Halogen, Fluorescent Rapid Start Ballast.
Do NOT use to control light fixtures with CFL or LED lamps!
Connect this switch by using the diagram for the #6107 Single-Pole or 3-Way (match your existing switch) linked below.
https://objects.eanixter.com/PD365967.PDF
Dec 01, 2013 | Cooper Wiring Devices Electrical Supplies
I need a wiring diagram to wire two way dimmer switched in place of normal switches
Take off the 2 wires from the old switch... put on the 2 wires from the dimmer. the 3rd wire is a ground it is green put it on a ground screw at the back. If your switch has more wires it is likely a 3 way system and needs a 3 way switch instead.
Apr 04, 2013 | Cooper Wiring Devices 6009W-K ROTARY...
I have a cooper comb devces how do i wire i want switch to control the plug
The Cooper combo device requires neutral wire to energize the outlet.
To control outlet with switch, the Hot side of device must have break-away fin.
Remove break-away fin.
Connect jumper wire from switch load side to outlet Hot side.
Open following link for instructions with illustration:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#combo
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on electrical wiring or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 20, 2011 | Cooper Wiring Devices 277W-BOX SINGLE POLE...
I"m installing a Cooper Devices
Wiring is suspect.
Black hot wire connects to dark screws.
Break off tab should be intact.
White neutral wire connects to silver screw.
Wire going to switch load connects to brass screw.
Jun 18, 2011 | Cooper Industries Cooper Wiring 274W...
I am trying to wire this device as illustrated on the back of the blister pack card and my breaker keeps tripping. Help !!!!!
You are switching from live to ground. Try connecting between live and the unit you are switching.
Jun 01, 2011 | COOPER WIRING DEVICES 452-BOX...
I need the wiring diagram for a Cooper 277W single pole switch with pilot light. The light is to be on when the switch is on. Thanks!
I have 120Volt cooper 277 pilot light switch here in my office.
Dang instruction sheet shows wiring for all kinds of cooper devices.
EXCEPT pilot light switch.
So I tested with multimeter and came up with following:
Key to any wiring device is color of screws.
Hot from breaker box always goes to dark-colored screws.
Neutral always goes to silver-colored screws.
Brass screws are for Hot wires from breaker or Hot going to Load
Green screw - ground
Dec 03, 2010 | Cooper Wiring Devices 277W-BOX SINGLE POLE...
Cooper S106P dimmer switch
Black hot wire connects to the black wire of the dimmer. the outgoing black wire will connect to the yellow wire located on the same side as the ground wire. the other yellow wire will cap off.
Apr 11, 2010 | Cooper Wiring Devices S106P-W-K 3WAY SLIDE...
How to wire a cooper industries 6107 3-way motion detector switch
I opened the box and traced the lines to see which are connected
when the switch is turned on and I left the red wire disconnected.
Jan 28, 2010 | Cooper Wiring Devices Motion Sensing...
Lutron Sf-10p Skylark Single-pole 8a Sf10p Dimmer Logo
79 people viewed this question
Top Lutron Electrical Supplies Experts
Steve
jdthefixer
berniekruege
Level 1 Expert
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
