Question about Samsung AW0693L Air Conditioner
Aw09l2B model awo9l2B...need horsepower of that unit
On my 10t802 I simply need horsepower, plug# and air cleaner type or # and oil weight and capacity
take the model # type # and code # to your local mower parts store they will sell you all of that and van tell you the hp.
Oct 05, 2016 | Poulan Garden
What is the motor hp?
Please see below courtesy of engineeringtoolbox.com
Electrical power is in general rated in watt (W) or horsepower (HP). A horsepower is a unit of power equal to 746 watts or 33000 lb ft per minute (or 550 lb ft per second).
A watt is equal to the power produced by a current of 1 amp across the potential difference of 1 volt. A watt is 1/746 of 1 horsepower.
Even if the watt is the base unit of electrical power, it is common to rate motor power in either horsepower or kilowatts.
Power in Watts
Direct Current Electric power supply to a direct current (DC) motor:
PkW = ?m U I / 1000 (1)
where
PkW = power (kW)
?m = motor efficiency
U = voltage (V)
I = current (A, amps)
Electric power supply to a alternating current (AC) motor:
Single Phase PkW = ?m U I PF / 1000 (1b)
where
PF = Power Factor
Two Phase Four Wire PkW = ?m 2 U I PF / 1000 (1c)
Three Phase PkW = ?m 1.73 U I PF / 1000 (1d)
Power in Horsepower
Horse power can be expressed as:
Php = PkW / 0.746 (2)
or
Php = (?m U I / 1000) / 0.746
= ?m U I / 746 (2b)
where
Php = horsepower (hp)
Feb 03, 2016 | Boating
What is horsepower and can I determine horsepower from vin number
to get an answer we need to know the make model year, engine size turbo etc because what you have given means nothing
Vin are vehicle serial numbers and that same make of vehicle can have several engine capacities depending on the manufacturers level of car finish( sedan --low hp super sports big engine hp)
Dec 29, 2015 | Cars & Trucks
What is the horse power
Hi, if you are referring to a particular vehicle you need to provide make model year and engine option. If you are asking what a horsepower is it is defined as
horsepower[ ?h?rs?pou(-?)r ] NOUNa unit of power equal to 550 foot-pounds per second (745.7 watts).Powered by OxfordDictionaries · © Oxford University Press
Jun 02, 2015 | Cars & Trucks
How do I tell what horsepower wet end pump do I need on my eon spa
Use the information on the motors label.
many times the horsepower and the service factor are not visible because it is intentionally left off. Use the code number or the model number to identify the horsepower with the manufacturer.
Feb 24, 2015 | Pool & Spa
How many cc is equival in horsepower
You can't.
There is no formula to convert Cubic Centimeters to Horsepower. It doesn't work that way.
Apples and Oranges.
CC's are a unit of volume and horsepower is a calculation of work load. Only a dyno would be able to tell how much horsepower a given displacement will/would make.
You could have 2 identical CC engines and have totally different HP outputs.
Feb 15, 2015 | Garden
How to calculate horsepower
They do not equate at all. A foot pound is a unit of torque and work. Horsepower is the RATE of doing work. If you know the RPM at a given torque, then you can calculate HP
Aug 15, 2014 | Mtd 22" Yard Machine Push Mower
How much horsepower does my intex Crystal Clear Model 635T filter pump have? I'm looking at a hth vacuum that requires at least 1/2 horse power. thanks
If the unit does not have the horsepower rating, but has the AMP rating, try this formula found in Answers.com
"Amps are a factor in calculating power, and so can be used to determine horsepower, but only when other factors are present.
Given other factors, you can find the horsepower. The easiest way is to determine watts by multiplying amps X volts. Next multiply watts by .00134 and you have horsepower.
If: amps (A)= 20 and volts (V)=120 then
A X V =2400 watts (W)
2400 watts X .00134 = 3.216 horsepower"
Hope this helps you???
Aug 14, 2011 | Intex Krystal Clear Model 635 Pool Filter...
What is the average power consumption (watts)? What is the start-up power consumption?
Sir / madam
Horsepower (HP) is the name of several units of measurement of power. The most common definitions equal between 735.5 and 750 watts. Horsepower was originally defined to compare the output of steam engines with the power of a draft horses... In refrigerator the unit use is horsepower(HP) 1 HP = 750 watts
Jun 21, 2011 | Refrigerators
Samsung AW0693L Air Conditioner Logo
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
