Question about GE 23333 Digital to Analog TV Converter Box
What does the smart mean?
Does smart mean wi fi ?
How can I set up wifi on my philips smart tv?
U do not set up wi fi on your smart tv. Your tv taps into your existing wi fi system and tells you it is there and then you enter the password for entry to your wi fi network and then the smart tv can do its thing.
Sep 04, 2015 | Philips Televison & Video
I have T-Mobile 4g galaxy avant android phone. I do not have coverage n my ares 4 the Internet. Cam I hook WI-FI up 2 my desk top and accessories the inn tenet via my home wi-fi
You can get WI-FI anywhere WI-FI is available with a smart phone.
But if you only have a modem at home and an ethernet cable from the modem to your computer to get internet, then you may not have WI-FI at home.
You'll need to get a wireless router to have WI-FI at home.
Once you do that, you can continue to have your desktop hooked up by the ethernet cable, but you can also install a WI-FI adapter card in your desktop. It will have an antenna on the back of your computer and then you can set it up anywhere in your house and have internet without an ethernet cable.
Mar 16, 2015 | T-Mobile Cell Phones
I have no wireless
To what Wi-Fi are you trying to connect? Is this your personal Wi-Fi router in your home? Or is this the Wi-Fi at the local coffee shop?
There is a huge amount of information you have excluded that is needed to fix your problem.
Answer these questions:
What kind of 'loptop' do you have?
What is the operating system of your 'loptop'?
Please go to the 'Help' section in your 'loptop' and check there for answers. You might find it right away.
Of the bazillions of Wi-Fi signals out there, and the thousands of bazillions of different kinds of 'loptops' out there, you must be so much more specific with what you are trying to do that I can't help you now. I need input!
The more information you provide, the better chance you have of someone rescuing you. Be smart, share all you know, then add some more, and maybe we can help you. Your "loptop" is only as smart as the information you put into it.
That is the 1st rule of computing.
Aug 18, 2014 | Computers & Internet
Can not connect to wireless network
If the signal strength is low, consider using a simple wi-fi repeater, or relocating the wi-fi router so it is closer to the Player
Mar 23, 2014 | Samsung BD-EM57 Smart Wi-Fi Blu-ray Player
IsEA6500 smart wi fi router agood choice for DSL
Really any quality WIFI router would work with any internet service. The router should not have any affect on the dsl modem.
Jan 23, 2014 | Cisco Linksys EA6500 Smart Wi-Fi Dual-Band...
What are some examples of home automation?
HVAC, centralized control of lighting, automatic security systems, applicances, etc
Jan 30, 2013 | Home Automation
The router is blinking a yellow light
Here are some of the more common reasons that the status light may blink amber:
  • The Wi-Fi base station has not yet been configured because it is new.
  • The Wi-Fi base station has been reset.
  • A new firmware update is available for the Wi-Fi base station.
  • No IP address is available for the Wi-Fi base station.
  • A Wi-Fi base station in Extended Mode is out-of-network Wi-Fi range of a primary Wi-Fi base station.
  • The WAN Ethernet cable is unplugged from the Wi-Fi base station.
  • The Wi-Fi base station lacks a path to the Internet (or local router).
  • Internet access may be temporarily unavailable from your Internet Service Provider (ISP).
  • Your AirPort Time Capsule has detected that the internal hard drive has reported a SMART error, and is failing (This requires firmware 7.5.2, and AirPort Utility 5.5.2).
Feb 10, 2011 | Apple AirPort Extreme Router
Can I install Android on HTC smart f3188 If yes please tell the steps thank u
can htc smart f3188 run android operating system? i mean i want install android or windows to this phone?
Dec 13, 2010 | HTC F3188 Smartphone
I need to install wifi software to my nokia 5310,any solution
Ok for starters your Nokia 5310 is not a SMART phone so you will not be able to install WI-FI software! Even if you could your phone would have to have WI-FI components built into the phone for WI-FI to work. If you need WI-FI try looking at some of the Nokia N series phones like N95 etc. Because they use Symbian Software they are capable of running applications that can control WI-FI and GPS etc.
Jun 21, 2009 | Nokia 5130 Cellular Phone
GE 23333 Digital to Analog TV Converter Box Logo
21 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
