Question about Pool & Spa
Replaced touch pad in waterco spa and new touch pad is still not working
Require a circuit diagram of waterco 4555142
3 Suggested Answers
  • 77 Answers
SOURCE: my self priming spa pump wont prime
Bleed air from pump by loosening union nut until water emrges, then retighten by hand. good luck
Posted on Aug 19, 2009
  • 5089 Answers
SOURCE: white springs spa wiring diagram and troubleshooter
120Volt or 240Volt?
Hardwire or plug-in-outlet?
Where is the GFCI? On the outlet or on the breaker?
Here is a starter:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/How-to-wire-GFCI.html
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Are you connecting a new spa?
Or is old spa having problems?
Exactly which problems?
Or if the element getting wet and causing GFCI to trip?
Is circuit breaker tripped?
Add a comment for live response 11-7-12
Posted on Nov 07, 2012
Motor cuts out after running for 15 mins. Then comes on again after a few mins. Why?
Sounds like it is overheating.
Because of electrocution hazard around pools I suggest replace any of it if you even suspect a problem.
Oct 13, 2017 | Waterco Pool & Spa
Waterco spa pump. In demand mode, why won't pump switch off?
Spa pumps are not only for Heat. The pup also circulates water thru the filter and provides optimal chemical dispersion. Recommend you call the customer service see how your warranty has been holding up and go from there.
Nov 21, 2015 | Waterco Pool & Spa
My waterco portapac was fitted 3 months ago. worked beautifully until 2 days ago. Now it is not heating. Any ideas? Thanks
it has a pressure switch that is a common failure pump waterco portapac Google Search the switch looks like this in most cases and is a gravy fix waterco portapac Google Search now you can bypass it FOR TESTING ONLY ! to see if it is indeed the culprit, it's around a $20 part and nice to have on hand Also check to see if the pump has a restriction, like a plugged impeller, debris might got into the pump and restricted flow, causing a low pressure situation ? Australian Spa Parts
Dec 30, 2014 | Waterco Pool & Spa
Spa quip hot tub error code 07 stuck relay
Bad relay on the circuit board will require a new circuit board.
Rod
US Parts Center
Apr 17, 2013 | Pool & Spa
How to replace bearing
Depends on the replacement cost of the motor and what your end bell housings are made of. As a rule it is a better long term solution to replace the motor. Aluminum end bells which have become common in the last few years do not hold new bearings very well.
The process to change them is a bit time consuming, considering that you have to disassemble the pump, and then the motor, and then reassemble hoping for favorable results. Some specialty tools are required that are not found in a conventional home repair toolbox.
Mar 09, 2013 | Waterco Pool & Spa
I have a Magic Chef microwave model mco153sf. The
HI. This is , indeed, an issue within the touch pad circuitry. it is damage, and will require replacement. I have located a replacement touch pad. Use the link below to access the touch pad. You can order the pad on-line, by clicking the link below.
CLICK HERE
Dec 23, 2009 | Magic Chef CMV1000B Microwave Oven
Pool & Spa Logo
37 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
