Question about Honeywell QuietCare HCM-630 Humidifier
Burping sound or knocking sound
We just purchased our quietcare humidifier and noticed a knocking or burping of water sound. Otherwise it is very nice. Is there anything we can do to minimize the knocking sounds?
3 Suggested Answers
co7196
  • 3433 Answers
SOURCE: how to clean and store for summer
need it it will be ready, flush water system with clean water with a dash of bleach mixed in. The bleach will inhibit any mildew or moldClean fan of collected dirt, remove and replace filters so when you needed again it will be ready..make sure all water is drained and let unit thoroughly dry outdoors. Good luck
Posted on May 18, 2009
SOURCE: My Quietcare portable humidifier isn't
I was having the same issue. I noticed that when the main fan unit was removed, there was a small plastic piece that was sticking up from the base next to the filter, which has a female end on the fan unit. I played with this, and realized I could lift it up. Once I did this, I replaced the fan unit and it started working. I think this is the water level reader which, when all the way down, won't allow the fan to start since it thinks there is no water.
Posted on Dec 23, 2010
No humidity
remove and clean the filter then re-install it the air is being blocked
Dec 03, 2013 | Honeywell QuietCare HCM-630 Humidifier
Honeywell quietcare humidifier won't turn on
I am surprised that this answer isn't found anywhere, including in the manual from Kaz. If yours is the same version as mine, and your lights aren't even lighting up on top, most likely your float may have gotten bound up with gunk (the float rises up when the pan is full enough of water, which enables the motor to run. It is held into place by a plastic bracket with two phillips head screws, and looks a bit like a plastic bottle with a narrow neck in a small rectangular shape (not open at top). Remove the screws and the bracket, and take out the float and clean it and the reservoir (in the base) it sits in. Reinstall, and the float should move freely. Problem solved!
Oct 13, 2012 | Honeywell QuietCare HCM-630 Humidifier
I duct taped a crack in the water tank but water was deep on the floor this morning. What's wrong?
I am wondering if the floater is sticking. I have the same problem and there is no crack like others have mentioned. But when taking it apart I noticed the floater which is the piece that sticks up from inside the base was not easily moving. Taking it out tonight after work and cleaning it along with the filter.
Feb 17, 2011 | Honeywell QuietCare HCM-630 Humidifier
My Quietcare portable humidifier isn't working anymore after I cleaned the inside. The orange light is on but no fan is running. What is the problem and how do I fix it?
Dec 20, 2010 | Honeywell QuietCare HCM-630 Humidifier
Our HCM-640bw Honeywell humidifier will leak water onto the floor. If I fill the tank and let it sit without turning it on, no leaking. When it runs for about two hours it leaks bad. Any ideas on how to...
Found a hairline crack in the water canister. Had to locate by filling the canister and waiting for a couple of minutes for water droplets to form outside the canister. This ever so slight crack allowed air to enter the chamber and made changes to water dispensing rate which overfilled the resevoir over time ( hours). The cracks were not visible under 10X magnification without the water droplets.
Jan 18, 2010 | Honeywell QuietCare HCM-630 Humidifier
Humidity wont go above 15%
It may not be large enough to bring it up depending on the size of the space. I would try hot water on pad, and maybe even boiling water as well as turning on a shower to get it up. Then use hot water to maintian it.
Jan 03, 2010 | Honeywell QuietCare HCM-630 Humidifier
How to clean and store for summer
May 07, 2009 | Honeywell International QuietCare...
HCM 640bw leaks
Look for a microscopic crack in the water chamber. Leaking air will allow the water to continue to drain out of the tank. A bit of glue and duct tape over the crack should fix it.
Dec 11, 2008 | Honeywell QuietCare HCM-630 Humidifier
Cool Mist Humidifier Filter Drying Out
How long are you going between filter changes?
A filter that stops wicking water up and turns orange/yellow is one full of deposits.
It sounds like you have hard water. How are you filtering this water before you use it? Distilled water is the best.
Replace the filter. They don't last forever. Mine normally last a month to a month and a half.
Good Luck
Feb 10, 2008 | Honeywell QuietCare HCM-630 Humidifier
Honeywell QuietCare HCM-630 Humidifier Logo
42 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
