Question about Car Audio & Video
No sound on Alpine W535HD - Car Audio & Video
I have no sound when I play a DVD/CD on my Alpine IVA-D105 head unit. Butbi do have sound when I use the tuner....
Disconnect whatever you have connected to the solid blue wire in the Alpine plug, and re-connect it to the blue/white wire instead.
Jul 14, 2015 | Alpine Car Audio & Video
Installed Alpine CDE-121 in May, has worked great up until now. System works, but no sound comes out
Some models of some vehicles have a power amplifier that is separate from the head unit. You did not specify what you have your Alpine installed in but you may find the "no sound" issue involves a separate power amp.
Nov 17, 2013 | Alpine CDE121
Alpine cde 133bt no sound
check trouble shooting methods on the manufactures website http://support.alpine-usa.com/products/documents/OM_CDE-133BT_EN.pdf
http://www.alpine-usa.com/product/view/cde-133bt/Specs
Hope this helps also check your wires make sure they match up
May 31, 2013 | Car Audio & Video
IVE-W535HD
i have the same issue. if i find out later today ill respond back on here. calling best buy "geek squad"
Feb 24, 2013 | Alpine IVE-W535HD - 6.1" In-Dash Video...
Alpine CDM-9821 No sound
I had this problem with mine, it was the wiring harness.
Jul 12, 2009 | Alpine CDM-9821 CD Player
No sound with USB and IPOD Apline IDA-X100
You connected your blue alpine wire (power antenna) to your blue wire (amplifier remote on) on the BMW harness adapter. You need to undo this, amputate your blue alpine wire (because your E36 has no power antenna) and connect the alpine blue wire with white stripe (remote power) to your blue wire on the harness adapter.
When you switch source from the radio, alpine is shutting off your amplifier through the connected power antenna wire. Since you're not listening to the radio anymore, it sees no reason why it should give it power.
Dec 27, 2008 | Alpine CDA-9851 CD Player
Alpine 7800F No sound, don't read.
Blown audio output IC, possibly from miswiring speakers, or accidentaly shorting out one of the speaker wires. It will need to be repaired, or replaced.
Dec 30, 2007 | Alpine CDM-7854
Peripheral's Connex2Car adapter to an Alpine CDA-9851
the alpine should recognize it as a "changer" when you select the source; ie: radio, CD, changer. Sounds simple, but have you turned up the volume on the iPod?
The Alpine adapter is $100, but works great, you can totally control all your iPods functions, and it displays all song info on the Alpine decks display.
Dec 30, 2007 | Alpine CDA-9851 CD Player
Car Audio & Video Logo
47 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
