Question about Video Cameras
Iskysoft video converter Mavericks and Safari or Firefox
In Facebook when I click the green or blue Download floating icon it looks like it is downloading the selected video. In the Media Browser it show the progress bar to the end. Then it says "Failed to obtain video info". Also tried to copy Url and pasted it in the Media Browser. Same result.
  • 37 Answers
SOURCE: aiptek a-hd 720p flash media files won't capture on Adobe Premiere Elements 3.0.2
I believe it is the format,the easiest thing to do would be convert it but with what? I reccomend quicktime PRO it's around $20 and will not only play the vid, but convert it without loss of quality.
Posted on Nov 06, 2008
  • 10 Answers
SOURCE: I can't download my videos from my JVC GZ-HD7U into my PC using Magix Edit Pro.
It happens because you didn't install the quicktime plugin. once the quicktime is installed it will show the preview of the video so you can make your selection.
download the quicktime plugin: http://www2.cli.co.jp/products/ne/update_qtc_for_gzhd7/qtc3e_update.htm
if not download the VLC player. it will nearly play every format. Choose your .tod file and play it on vlc. http://www.videolan.org/vlc/
hope its helps :) by the way i got the same camera :P
Posted on Dec 31, 2008
rockitman187
  • 2559 Answers
SOURCE: Application error - the application failed to initialize properly (0xc0000005) when launch Import Media (HandyCam/Dics) application
The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
Usually you get this error message when performing a specific task, and if that happens you need to check the corresponding 3rd party's website/support department to see if they are aware of the problem
..a while back symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
So what can you do...? well below are a couple of suggestions:
0xC0000005 - Resolution Suggestion One:
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then I would remove them and see if the error goes away. If it does then send the memory back and get a refund!
0xC0000005 - Resolution Suggestion Two:
In Windows XP Service Pack 2 Microsoft introduced Data execution prevention (DEP), a set of hardware and software technologies that perform additional checks on memory to help protect against malicious code exploits. In Windows XP SP2, DEP is enforced by both hardware and software.
Some software/application behaviors are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation
(such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with Safe SEH must have their exception handlers located in executable memory regions.
Applications that attempt to violate DEP will receive an exception with status code STATUS_ACCESS_VIOLATION (0xC0000005).
If an application requires executable memory, it must explicitly set this attribute on the appropriate memory by specifying PAGE_EXECUTE, PAGE_EXECUTE_READ, PAGE_EXECUTE_READWRITE or PAGE_EXECUTE_WRITECOPY in the memory protection argument of the Virtual* memory allocation functions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offense, contact the vendor for a resolution...
Note: It is possible to "Turn Off" DEP in the boot.ini file but this really would be a last step!
/NOEXECUTE
This option is only available on 32-bit versions of Windows when running on processors supporting no-execute protection. It enables no-execute protection (also known as Data Execution Protection - DEP), which results in the Memory Manager marking pages containing data as no-execute so that they cannot be executed as code. This can be useful for preventing malicious code from exploiting buffer overflow bugs with unexpected program input in order to execute arbitrary code. No-execute protection is always enabled on 64-bit versions of Windows on processors that support no-execute protection.
There are several options you can specify with this switch:
/NOEXECUTE=OPTIN Enables DEP for core system images and those specified in the DEP configuration dialog.
/NOEXECUTE=OPTOUT Enables DEP for all images except those specified in the DEP configuration dialog.
/NOEXECUTE=ALWAYSON Enables DEP on all images.
/NOEXECUTE=ALWAYSOFF Disables DEP. (This setting doesn't provide any DEP coverage for any part of the system, regardless of hardware DEP support. The processor doesn't run in Physical Address Extension (PAE) mode unless the /PAE option is present in the boot.ini file.)
0xC0000005 - Resolution Suggestion Three:
I have also seen this error in the gaming community when folks have updated drivers for their graphics card. If this happens just roll back your drivers.
0xC0000005 - Resolution Suggestion Four:
Microsoft Internet Explorer 6.0 stops responding when you try to open an HTML document or a Web page. Additionally, you receive the following error message:
Access Violation (0xC0000005 exception)
CAUSE:
This problem may occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags. If a SPAN tag is not closed correctly by using the </SPAN> tag, an access violation may occur.
WHY are you using IE6 still??? Upgrade to IE 7 today!
...and that should have now resolved the 0xC0000005 error for you!
Please rate this fixya
Posted on Jan 29, 2009
SOURCE: Can't download my video files from xacti e2 to my computer
TRANSFERRING RECORDED IMAGES AND VIDEOS FROM YOUR VPCT700 DIGITAL CAMERA TO YOUR COMPUTER
Connecting the Camera to Your Computer
1. Connect one end of the USB cable to the PC/AV terminal of the camera.
2. Connect the other end of the USB cable to an available USB port on your computer.
3. Turn on your camera.
-The [USB] screen appears.
4. Select [PC] with the Up and Down Arrow buttons, and press the SET button.
5. From the Windows desktop, double click on “My Computer”.
6. Look for a new “Removable disk” icon. This “Removable disk” is actually the memory card in your camera. Typically, the camera will be assigned drive letter “E” or higher.
7. Double click on the removable disk and locate the DCIM folder.
8. Double click on the DCIM folder to open it to find more folders.
-Your recorded images and video clips will be inside these folders.
-Copy & Paste or Drag-N-Drop image and video files to a folder on your computer.
Mac users: Double-click the “untitled” or “unlabeled” disk drive icon on our desktop. iPhoto may automatically launch.
Downloading images and Video Files
When the camera is turned on and connected to your computer, it is considered to be a disk drive, just like a floppy disk or CD. You can download (transfer) images by copying them from the “Removable disk” (“untitled” or “unlabeled” disk on a Macintosh) to your computer hard drive.
Windows
Open the “removable disk” and subsequent folders by double clicking on them. Your images are inside these folder(s). Select the images that you want, and then choose “Copy” from the “Edit” menu. Open the destination location (folder) and choose “Paste” from the “Edit” menu. You may also drag and drop image files from the camera to a desired location.
Macintosh
Open the “untitled” disk icon, and the destination location on your hard disk. Drag and drop from the camera to the desired destination.
NOTE
- Memory card users may prefer to use a memory card reader (highly Recommended).
- Video playback application is not included with the package. Make sure that video playback application has been installed in your computer.
Posted on Feb 14, 2009
SOURCE: Half of My Video Shows Up GREEN?!?!!
Here is something i found:
http://www.bernzilla.com/item.php?id=884
Posted on Mar 02, 2009
Video downloadhelper 5 button is not showing on my browser for mozilla firefox after downloading
Open Firefox, Click on Open Menu Option in the right hand top corner of the screen, then click on Add-ons in the search box type Video DownloadHelper and click on Install. Once done, you will see and icon in the right hand top corner which is red/yellow/blue color
Mar 14, 2015 | Icon Computers & Internet
How can I download movies strait from fasebook to my phone.When someone post a video and I want to download it how do I do it
I am going to recommend 'savefrom.net' and the best way to download videos using it from facebook, youtube, etc.. is to get the firefox savefrom.net helper addon. Take these steps:
  1. Ensure you have firefox browser installed and open
  2. Add add-on https://addons.mozilla.org/en-US/firefox/addon/savefromnet-helper/
  3. Goto facebook
  4. Find the video and you should see a download link or icon
  5. Click it to download the video
It will be in flv, mp4, or some other format.
Jan 03, 2015 | Cell Phones
Want to delete search history
Which web browser do you use? In Firefox, click the icon that looks like a clock and then click "Clear recent history..." Scroll down and select "Everything" and then click "Clear Now." If you use another browser, look through the Options or Settings for similar wording.
Another option - if you use Windows or a Mac - is to use CCleaner. It's free and available at http://www.piriform.com/ccleaner - Do not click the Buy Now button. Click Download Now to get the free version. Once it's downloaded and installed, open the program. Select the Cleaner option on the left (brush icon) and you'll see a lot of check boxes. If you have Internet Explorer, check Temporary Internet Files and History. If you use another browser, click the Application tab, find your browser and check Internet Cache and Internet History (Chrome and Firefox options). If you want to see what's available to be deleted, click Analyze (at the bottom). If you just want to delete without checking, click Run Cleaner.
Aug 04, 2014 | Computers & Internet
What is the software can i use to download clips from www.video-one.com?
if it's stream based you can use Real Player from real.com
it's free which makes it that much nicer.
Feb 28, 2011 | Computers & Internet
My facebook chat is disabled and a yellow right tringular icon on my chat icon place..please solve my problem.
the yellow triangular icon with an exclamation mar means that the chat is unable to load try some other browser it some times also happens due to slow internet connection speeds. I recommend Google Chrome or Mozilla Firefox though opera and apple safari browser will also serve the purpose. Where to download them? Just serach them on google.com and you'll get the correct location.
Feb 16, 2011 | Facebook Social Network
I cant open my facebook account
First, verify that the user name and password that you are using is correct. Ttry to log in to your Facebook account using different computer that's connected into different network. If the same problem occur, try to access your email that is associated with Facebook.
However, if you're not able to experience the same problem on different computer, then the problem could be your internet browser. Try to optimize your internet browser or try different browser.
Here's how to optimize the browser:
* For Internet Explorer:
1. Run Internet Explorer and click on 'Tools' menu.
2. Go to Internet Options and locate the Browsing History section.
3. Click the 'Delete' button and delete the Temporary Internet Files, Cookies and History.
4. Close the Internet Explorer and re-open it.
5. Access your e-mail.
* For Mozilla Firefox:
1. Run Firefox and hit 'Tools' menu.
2. Go to 'Clear Recent History' and click the drop-down arrow for 'Time range to clear'.
3. Select 'Everything' and then click the line beside details.
4. Check browsing & download history, form & search history, cookies, cache.
5. Click "Clear Now" button.
6. Close and re-open Firefox.
7. Access your e-mail.
* For Safari:
1. Open the Safari.
2. Click the Safari menu (right beside the Apple icon) and select "Empty Cache".
3. When asked "Are you sure you want to empty the cache?", click "Empty".
4. Click the Safari menu (right beside the Apple icon) then go to "Preferences".
5. From the security dialog box, click "Bookmarks".
6. Click on "Show Cookies" button and then hit "Remove All" button.
7. Select "Done".
8. Access your email.
Thank you and good luck!
Jun 27, 2010 | Facebook Social Network
When I log into one of my facebook accounts it will not let me connexct to farmville. My other facebook avvount works fine. I can visit this farm as a neighbor farm but cannot open it on its own.
First, verify if the problem is your Facebook account is working on different computer. Try to access your FarmVille (FV) in a different computer that is CONNECTED in a DIFFERENT network and see if the same problem will occur.
If your FV works on diff. computer, then it's not your FV, the problem could be your internet browser. You may either access your FV using another internet browser (Mozilla Firefox, Opera) in your computer, or clear the cookies, cache of your browser.
To clear the cookies and cache, here's how:
* For Safari:
1. Open the Safari.
7. Select "Done".
Jun 25, 2010 | Computers & Internet
MY FACEBOOK PAGE ID DISABLED WHAT SHOULD I DO?
I'm sorry, but we it's not possible for us to reset your Facebook account. Aside from that, Facebook is working correctly here in our end.
If Facebook is not showing on your computer screen, the problem could have something to do with your internet browser. Try to optimize your browser. Here's how:
5. Access your Facebook account.
7. Access your Facebook account.
* For Safari:
1. Open the Safari.
7. Select "Done".
8. Access your Facebook account.
Jun 13, 2010 | Facebook Social Network
DVD to Zuine
just google "Zune video converter" to get ahold of a converter... the first link is usually fine...
After you get the conversion you just toss the converted file into a folder monitored by the Zune software and it will pick it up automatically. From there you right click the name of the file in the Zune software and click "transfer to zune"
There you go...
Jan 21, 2008 | Microsoft Zune JS8-00001 Digital Media...
Video Cameras Logo
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
