Tcl tv model no 14175 before it was stanby only,, I replaced ic 44608p40, now power is ok,, but if the unit is rest for a minute then on again its delay to start,,what the other problems?
SOURCE: TV screen went black, sound OK
check cold solder vertical circuit
Posted on Feb 19, 2007
Slinteriors
  • 8617 Answers
SOURCE: TV HV
usually when thiers arching its usually inside the flyback connection that causes the arching.I reccomend changing the flyback.
Posted on Apr 13, 2008
likha
  • 790 Answers
SOURCE: tv tcl-14175 no sound on channels but ok on audio video mode
Hi
The first problem was always standby mode.... get back the original eprom IC 24CO8WP in to the PCB, then find the original remote control of you TCL Tv tcl-14175 then you power On In the Remote control while your TV is in Standby mode! then you see your tv is going ON... Because your unit is in Child lock Mode....
thanks!
Posted on Nov 21, 2008
jerryg50
  • 1667 Answers
SOURCE: Sony 2167 No power on
I have not worked on your particular model. But, I have serviced many TV sets over the years. My answer will ge generic.
Check all the capacitors in the horizontal output stage and power supply areas for high ESR. All the caps that are out of spec must be changed.
The high voltage multiplier & flyback can also cause the fault you are having.
You have to consider that the DC voltages are not the only important spec that has to be met. There are also many power drive signals that work with reactive devices. If there is any defect in the critical areas there will be failures.
Jerry G.
Posted on Nov 26, 2008
SOURCE: orion tv problem
tv flipping colors and verticle alignment not straight
Posted on Feb 10, 2009
TCL TV Model L40P60UF; no picture and sound when switched on but stanby led is on. When power on is pressed from the remote control, the red led disappear. What could be the problem
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jun 08, 2015 | Televison & Video
Diagram of TCL-14175 I want to repair my Tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 10, 2014 | Televison & Video
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Schematic diagrams to many popular TVs are given. You can refer it.
Apr 11, 2014 | Sony Televison & Video
I have problem model TCL-14175 I replace ic 8 pins 44608P40 but still unstable power supply
You've replaced the main system control memory IC, I assumes. If so, an adjustment called, memory initialization, should be done after replacement, or, the newly prepacked IC do not work. If you wish to get more details about this, check this link. http://electronicshelponline.blogspot.com/
Oct 08, 2013 | Samsung Televison & Video
Sanyo tv model # st-21ys2 defective system ic
sir may ginagawa akong tv ang trouble nya. pag on mo ng tv after mga 2 to 3 .minutes nawawala na ang sound tpos pag pinatay mo at pag plug mayron uli sounds tpos nawawala uli sound buo ang i.c sanyo st 21ys2
Apr 15, 2013 | Televison & Video
I have TCL TV set. When I on the power of TV set, tv shows message ASM after 3 second in Red and auto scanning running. I already plugged the cable so many times, but same problem continue. Please help.
Hello
The mamory IC inside the circuit of your tCL tv is faulty. Memory IC is one which transfers data to main system IC when we switch the set ON each time. Now it transfers the data to the system IC ofcourse, but not memorize the [LPM]; last position memory. This IC can be located very nearto the main system IC; will have 8 solder terminals. It can be easly unsodered out and resodered in. Its number is most important. Keep a keen look on its number and buy an exact replacemnt. It will be very cheap to buy, and can be had from most of the electronic spare part shops at your town. OK.
Jun 29, 2011 | Televison & Video
Tv wont turn on
Hello Charliebigwh, hi technically your monitor's power supply has a problem, this is either your switching regulator does not work or there is a short in that section, If you want to do it your self, need to replace all large value, and or high voltage capacitors(especially the capacitors with its top is bubbly), need also to replace the switching IC, and power transistor.
Have it checked by a technician if you cannot do the work.
Apr 15, 2010 | LG 32LG30 32 in. LCD HDTV
My tv is a tcl brand model tcl-14175 i accidentally on the child locked.can I have the child lock code for my tv?please
my tv is tcl model ( t1436a ) , lost my tv's remote controller , please give the model number of remote controller
Sep 24, 2009 | Tvone TV-207 Television
Tv tcl-14175 no sound on channels but ok on audio video mode
Hi
thanks!
Nov 21, 2008 | Samsung DLP HL-P5663W 56" TV
TCL tv
i have tcl satellite tv...the porblem is when i switched on , 5 or more minutes after, the tv unit shut off itself. Sometimes the tv scan its channels first before having picture then shut off after few minutes..varying time when shutting off.....And when using for video movies everything alright....please tell me what to do??...any solutions??..advance thanx to those who could help...
Oct 29, 2007 | JVC AV32F476 32" TV
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
