Question about Pelonis Heating & Cooling
Circulating fan yjjj\\==My fan squeals sometimes and I don't know how to stop that
2 Suggested Answers
GeoffW1
  • 3961 Answers
SOURCE: My 1998 Toyota Avalon XLS squeals loadly when I start the engine and the fan is on in the car. I turn of the fan and it stops. After driving I turn the fan back on and don't get the squeal anym
Almost certainly one or more of the drive belts (not the timing belt) on the engine needs an increase in tension. It may tell you about this in the owner's handbook.
If not you can either ask a mechanic to do this straightforward job for you, or try it yourself. You can download a zipped service manual from here
http://www.freeautorepairmanual.org/free-download-toyota-avalon-service-manual.html
and look these belts up in the charging section and steering section.
Posted on May 17, 2012
May 15, 2012 | 1998 Toyota Avalon
I have a '99 Honda Civic. Some mornings the belts squeal very loudly for a few seconds. I don't know what belt is sqealing or how many there are that could squeal for that matter. Also when I
its more than likely the alternator drive belt needs re tensioning if its got aircon that belt may cause the same problem just get the drive belts checked and re tensioned
Feb 12, 2018 | Cars & Trucks
Sometimes my temperature gauge goes up on my Toyota estima and the engine gets very hot and the water overflows from the coolant, don't know what the problem is.
Check if the fan is running. You may also have blockage in the radiator or coolant is not circulating properly. I suggest first draining the radiator and inspecting if there are debris in the liquid that comes out.
Aug 07, 2011 | 1994 Toyota Previa
Kenmore refrigerator(model 10653606202) freezer is cooling, can hear the circulation fan' noise, also see defrosted water in the bottom collection pan. but the refrege is not cooling.
If the freezers is freezing everything and you can hear the circulation fan, maybe it is a defrost problem. Sometime ice will build up behind the rear panel in the freezer section that blocks either the chilling tubes to the refrigerator section.
You will need to remove the food from the freezer, then remove the shelves and inside back panel of the freezer. If you see a lot of ice, that is probably your problem. DON'T use water to defrost, either unplug and let it set with the door open or hurry it up with a hair dryer.
It also means your defrost assembly has stopped working and will need replaced, but the unit will work without it for several weeks before the ice build up redevelops.
Jun 07, 2011 | Refrigerators
My heat only works when I am driving. When I stop at a light it goes cold?
check your temp sensor because this is wierd man. maybe the supply is not constant.
Nov 23, 2010 | 1991 Lexus LS 400
Amana ABD2533DEB Bottom Freezer - Fridge not working
Sounds like the circulating fan is either gone or is going bad. This problem is hard to diagnose because sometimes the fan will run but not fast enough to circulate the air through the freezer and refrigerator. I would have your repairman look at this or if you have the know how then you can order the fan and replace it yourself.
Aug 22, 2009 | Amana ABB1927DE Bottom Freezer...
96 Trooper still squealing after changing all belts
sound like alternater belts you changed one may not have been as good as it should try again
May 21, 2009 | 1996 Isuzu Trooper
Squealing noise under the hood
No, The fan clutch will not make a Noise it will just not catch the Fan to Cool. It is the Belt. Make sure that it is Tight. You may have a Bad Belt Tensioner if it is not.
Jan 23, 2009 | 2004 Chevrolet TrailBlazer
My dehumidifier is squealing
the fan motor is the cause it needs to be replaced
May 06, 2008 | Maytag M3DH30B2A Dehumidifier
Heating & Cooling Logo
10 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
