Question about ASK Proxima C160 Multimedia Projector
How to find dp6155 service code - ASK Proxima C160 Multimedia Projector
Need part number for DP6155 blue polarizer
unfortunately, parts are no longer made for that model and the fried polarizer is a common problem. there aren't many of them out there anymore. you might check ebay, but chances are they'll all have the same issue. good luck.
Dec 05, 2009 | InFocus Proxima DP6155 Multimedia...
I have an LP600. I'm on my 3rd bulb, and the two replacements bulbs have had shadows on one side or the other.
it's not the lamp. you have a light tunnel that is collapsing and needs to be replaced. you'll have to send it to an infocus service center. try av solutions. they're pretty good. www.avsolutionsny.com
Nov 18, 2009 | InFocus Proxima DP6155 Multimedia...
Shut down
maybe there is a things that cover the exhaust fan some kind of a book or your laptop, or something... then check also the air filter maybe it so very dusty.
Oct 28, 2009 | InFocus Proxima DP6155 Multimedia...
Powers up but shuts down right afterward
there is a edge connector on the power supply board that goes into a socket on the main board. this connector gets corroded after a while and needs to be resoldered. you could do it yourself (if you're handy with a soldering iron) or send it in for repair to an infocus authorized service center. try av solutions in ny. they're pretty good.
Oct 21, 2009 | InFocus Proxima DP6155 Multimedia...
ALIGNMENT Problem - InFocus Proxima DP6155 Multimedia Projector
if the lcd panels have become misaligned, it is time for a new projector, the parts are no longer available for this unit, and it needs the most expensive part, the LCD block
Jul 19, 2008 | InFocus Proxima DP6155 Multimedia...
I have an alignment problem with colors and i've found a little mesh screen
yr previous buld is it burn out or explode ?
if explode might be the tiny glass neeed to service (cleaning)
please do a tilt correction
do manually
Mar 08, 2008 | InFocus Proxima DP6155 Multimedia...
Hot to adjust the convergence on the DP6155
resolder the fingers on the edge of the power supply where it goes into the main board edge connector.
Oct 16, 2007 | InFocus Proxima DP6155 Multimedia...
ASK Proxima C160 Multimedia Projector Logo
22 people viewed this question
Top ASK Proxima Office Equipment & Supplies Experts
jasbo
jasbo
240cpa
Lyle Siemens
Lyle Siemens
Are you an ASK Proxima Office Equipment and Supply Expert? Answer questions, earn points and help others
