Question about Life Fitness T3 Treadmill with Advanced Console
Speed stall error - Life Fitness T3 Treadmill with Advanced Console
Error Code U0019 on a HYUNDAI SANTA FE MODEL YEAR 2004 ENGINE : DIESEL
Code meanning low speed can communication bus not sure what that is
Apr 09, 2015 | 2004 Hyundai Santa Fe
Proton savvy 1.2 runs for a while then stalls
hi,
savvy engine is same with renault engine. there's a flywheel sensor/engine speed sensor between engine and gearbox. change the engine speed sensor.
The engine speed sensor is control the ignition timing, if the sensor can't read the 0' angle the engine won't fire up.
Jul 10, 2014 | 2009 Proton Savvy 1.2
Speed Stall error
Have to check the speed sensor. Either the speed sensor is faulty or the can be dust or speed sensor alignment.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Dec 12, 2013 | Life Fitness F1 Smart Treadmill
2003 f250, 5.4l v8...Started with a 0304 error code. replaced 4th coil pack and spark plug and now am having a 0720 code and it keeps stalling at idle. I need to know if this is actually a bad speed s
PO 720 is an output speed sensor circuit malfunction
That issue will have to be diagnosed & may be the shifting
problem
PO 304 may have been cyl #4 or not & you may have
others going bad as well
You never do just one spark plug
Only proper testing will solve your issues
no one on the phone or internet can diagnose
the actual vehicle,you need to have it
Dec 22, 2012 | 2003 Ford F250 Super Duty Crew Cab
2001 Dodge Stratus with error codes P0715 and P0700.
speed sensor and transmission control, change the speed sensor and have the codes erased, drive for a while and see if the light comes back.
Sep 05, 2012 | 2001 Dodge Stratus
1989 olds ciera 3.3 A/T have had intermittent stalling problem no SEL light and when it stalls it always cranks right back up and will stall again does not matter hot or cold it will just start stalli
The overdrive solenoid in the transmission locks the torque converter, and at low speeds, if it activates or hasn't released from a high enough speed, it will cause stalling. If that is what's happening, it could be the solenoid, or the signal line to it from the ECM, or the ECM itself not working properly.
Jul 05, 2017 | Oldsmobile Cutlass Ciera Cars & Trucks
We are getting a speed stall error on our True Fitness treadmill PS100. Is there anything we can do to fix it?
Yes you may be able to recalabrate the machine. A grade stall is when the machine does bot think the machine is at the right height. A bad lower board can also be the problem. True has those treadmills brought overseas. There not the american made quality of the units they useto make in MO.
It can be fixed. I know all the employees at True
Oct 10, 2009 | Endurance TF6iHRC Treadmill
1992 Buick LeSabre Custom....180K on the odometer...stalls at low speeds....sometimes at highway speeds without warning...error code 17 is popular...I have a 41 also but the magnet has been missing 2 years...
dont know what the code are w/out looking them up however i do know that is a common problem when ignition coils or 1 ign coil goes bad. or distributor shaft wears out, which i dont think 92 buicks have. your 92 buick should be ign. coils . ignition coils need tested at a auto part store.most are free test call them to make sure.
Jun 25, 2009 | 1993 Buick LeSabre
My Neon keeps stalling at 4k rpm. will not run
Just to let you all know it ended up being the CENSOR in the trany that was bad.
May 28, 2009 | 1997 Dodge Neon
Car stalls while driving at high speeds
i would start by checking the spark plugs and leads. if that ok i would think there is a problem with the dispack that the spark plug leads fit to, if its cracked or any rust i would replace.
May 23, 2017 | 1994 Mazda 626
Open Questions:
See all Life Fitness T3 Treadmill with Advanced Console Questions
Life Fitness T3 Treadmill with Advanced Console Logo
71 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
