Question about Proform CrossTrainer Treadmill
My treadmill will not start it's plugged in and the only the speed,distance, and pace light is on
How do I calibrate a Trimline 4650.1 treadmill?
WARNING: DURING THE ENTIRE CALIBRATION PROCESS, STAND ON THE PLASTIC SIDE RAILS ONLY!
DO NOT STAND ON TREADMILL WALKING BELT!
CALIBRATION
1. Turn off treadmill.
2. Simultaneously press PROGRAM, ENTER, and START/STOP for about 3 seconds.
3. Maximum speed will be shown in the TIME/PACE display followed by an "E" for English units or an "N" for metric
units. Press START/STOP to change from English units to metric units.
4. Press ENTER.
5. Press START/STOP. Incline and speed will calibrate simultaneously.
6. When successfully completed, TIME/PACE display will show CAL PASS.
7. Press POWER. Your treadmill is ready for use
Jan 02, 2017 | Exercise & Fitness
ASI Image Pro 2 Treadmill will not start
PLEASE see the video and proceed according. God bless you
Dec 10, 2013 | Exercise & Fitness
Jazfit Running Machine
reset the machine, follow this steps and fix it. God bless you
However RUN the software calibration for easy diagnostic goes under the HOOD motor and follow the steps.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Dec 06, 2013 | Exercise & Fitness
Starting Problem
see the video attached. LUBE too the rollers bearing front +back and test the drive belt motor, and replace if necessary.
God bless you
Jul 22, 2013 | Sportcraft Tx2.5 Tx 2.5 Treadmill Motor...
Why does my treadmill not adjust speed? when i press any number it starts running but at a really quick pace. Also, if i put the speed as .5 it will stop.
RUN the software calibration go under the HOOD motor see the instruction, and fix it. see the speed sensor7f016ade-041e-4f50-8a39-9f81109c1be9.gif
God bless you
Jul 10, 2013 | Epic 425 Mx Treadmill EPTL88105 !
Cuts off and speed is variable and shows err 4
Precor Error E4, Incomplete Initialization Probable Cause Indicates that an incomplete upper PCA to lower PCA initialization occurred. When this error occurs, all lift motor and drive motor motion is ceased and the display will go blank except for the error displayed.
Corrective Action Run the initialization program. Caution: The treadmill's running belt will accelerate to the treadmill's maximum speed (12mph). DO NOT stand on the treadmill's running belt during the procedure.
  1. Set the on/off switch to the OFF position. Wait a minimum of 10 seconds to allow the internal power supply to discharge.
  2. Remove the safety key from the console and set the on/off switch to the ON position.
  3. Press INCLINE UP and SPEED DOWN keys together. While pressing these keys, replace the safety switch on the console. Continue holding the INCLINE UP and SPEED DOWN keys until the display goes blank. INIT will appear in the time window of the display. The EEPROM is now clear and reset. After a second, 1.25 will appear in the distance/calories window, 15.0 (the maximum incline) will appear in the incline window, and 12.0 (the maximum speed) will flash in the speed/pace window.
  4. Press QUICKSTART to begin the speed calibration process. Power bits will appear in the incline window, the target speed will appear in the time window and the actual speed will appear in the speed/pace window. At the beginning of the process, the target speed will be .5mph. The running belt will start. Once the actual speed reaches .5mph, the target speed will then change to 12mph and the running belt will accelerate until it reaches 12mph, then it will stop.
  5. When the running belt stops, the display will return to the user mode and the initialization process is complete.
Precor Error Code E4
Feb 27, 2013 | Precor 9.1 Mode 1 Treadmill Repair Parts...
The treadmill speed is faster than reallife speed. I can easily run 7 minute miles on the roads (not racing, just running) and my wife is an eight minute metronome. But on the treadmill if I set it below...
the speed of treadmills are based on the companies regulations and are machine made. so they might not be 100% accurate. a treadmill is a simulated devise so it is never the same. var fctb_tool=null; function FCTB_Init_c8c9213424bf492d84f2bfaa8e62c574(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_c8c9213424bf492d84f2bfaa8e62c574(document['FCTB_Init_c3525ba5f17e4280b024b96d82d11976']); delete document['FCTB_Init_c3525ba5f17e4280b024b96d82d11976'] var fctb_tool=null; function FCTB_Init_6836227ebca14782a6c9f0284529fff9(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_6836227ebca14782a6c9f0284529fff9(document['FCTB_Init_f3124b0bb88c423dafd62627ed1118bc']); delete document['FCTB_Init_f3124b0bb88c423dafd62627ed1118bc']
May 05, 2011 | NRS Sole S77 Treadmill
I have a reebok edge series 2.2 treadmill, i bought it in argos in ireland but im pretty sure it's been shipped from england, does anyone know if the distance ran on the computer is in miles or kms?
I had this very same problem. I sorted it out this way: the information that Argos supplies says the speed starts at 0.8 kph with a top speed of 14 kph. If your Reebok Edge starts at a speed of 0.5 and has a top speed of 8.8, then the speed and distance is measured in mph, rather than kph. You can check this yourself with the following online speed converter:
http://www.eforecourt.com/mph_kph_speed_convert.htm
Feb 03, 2011 | Reebok Acd1 Treadmill Motor Control Board ...
Treadmill is plugged, lights are on but does not work
The standard calibration procedure to calibrate an Icon treadmill is done by holding down the speed up and stop keys while inserting the safety key or putting the key in place (if magnetic). If your keypad is not responding, because your treadmill keypad has failed or the console computer has failed. In these cases, the keypad can be replaced in limited instances or the console has to be replaced.
Now if you are able to get in calibration mode then Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, This means that it passes the EPROM test. If it shows ff or 2f your upper console will need to be replace.
Next step if eprom passes: Press either incline key and the incline will calibrate automatically.
DO NOT STAND ON THE WALKING BELT.Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window). if you get the the number to 85 and the belt does not move , on the lower board you will see a like flicker that would be the speed control this tells you that the upper console and terminal cable is good ,but lower board defective.
May 20, 2010 | Epic View 550 Treadmill
Elevation has gone too high. foot rollers are hitting front plate
Apr 30, 2009 | Precor EFX 546i Elliptical Version 4
Proform CrossTrainer Treadmill Logo
21 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
