Lawnmower is started spewing white smoke, stalled and I stopped using it for a few minutes - then started using it again, saw more white smoke-
White smoke means that there is water in the fuel air mixture during combustion. a bluish white smoke means oil is being burned during combustion. take another look and make sure which one it is. since all mowers ive seen are air cooled the only way water can be getting in the fuel air mixture is through the gas cap. check your gas tank and gas can for water. may be best to empty both and start over with fresh fuel
Your Tractor is probably burning oil bad. check the oil, there could be too much oil or too little.
http://schematicsdiagram.blogspot.com/2011/12/van-emits-whitish-bluish-smoke-and-bad.html
White smoke and Acrid Smell?
http://whoisbyme.blogspot.in/2012/07/white-smoke-and-acrid-smell.html
Car stalls and throws white smoke from exhaust?
http://repairhelpcenter.blogspot.com/2012/01/car-stalls-and-throws-white-smoke-from.html
This will help.
Thanks.
