Question about Wolff Sunquest Pro 24RS 220 Volts
FAN WONT TURN ON - Wolff Sunquest Pro 24RS 220 Volts
My oven wont turn off
The thermostat for the fan is shorted out
Jan 28, 2016 | Ovens
Fan not turning on
replace The Fan motor
Feb 27, 2014 | 2006 Chevrolet Cobalt
Ac fan wont blow
I would disconnect the fan connector and use contact cleaner to clean the connection. Usually corrosion. Also fan might be going bad (Common Problem).
Mar 27, 2013 | 2000 Saturn L-Series
Fan wont turn off on bmw 520 i
If it's electric fan then the wiring pig tail is bad or the relay is toast had same problem on electric fan and it was just the wiring at conectors was bad try that k
Feb 21, 2013 | BMW X5 Series Cars & Trucks
Right fan of my 2006 passat wont turn on.
Yes you can do that, it will work great.
May 31, 2012 | Cars & Trucks
How do i check the cooling fan my car is over heating
HOT WIRE COOLING FAN USING JUMPER WIRES TO BATTERY.IF FAN DONT RUN WHEN HOT WIRED FAN MOTOR BAD NEED REPLACING. IF FAN RUN WHEN HOT WIRED. CHECK COOLING FAN FUSE AND RELAY.IF ALL IS GOOD.YOUR ENGINE COOLANT TEMPERATURE SENSOR NOT WORKING.IT CONTROL COOLING FAN AT SET TEMPERATURE IF SENSOR OPEN OR FAULTY THE COOLING FAN WONT TURN ON.CHECK COOLING FAN WIRES FOR DAMAGE.IF ALL STILL CHECK OUT GOOD HAVE VECHICLE SCANNED FOR PCM FAULT.IF IT FAILS NO COOLING FAN WONT TURN ON.
Dec 13, 2010 | Hyundai Elantra Cars & Trucks
Mu 1991ford tempo fan wont turn off when i turn
does anything else stay on it sounds like you have a bad ignition switch
Dec 14, 2009 | 1991 Ford Tempo 4 Door
Wolff Sunquest Pro 24RS 220 Volts Logo
11 people viewed this question
Top Wolff Health & Beauty Experts
Steve
NOEL
NOEL
Are you a Wolff Health and Beauty Expert? Answer questions, earn points and help others
