Question about Coffee Makers & Espresso Machines
Jolly boiler Looking for a part for a Atwood jolly Boiler. The main switch that turns it on and off.
SOURCE: vaillant Boiler time switch no user manual
http://www.vaillant.co.uk/stepone2/data/downloads/9a/42/00/timeSWITCH_120.pdf
Posted on Dec 26, 2007
SOURCE: when i turn heating or hot water on fuse board trips
it was a faulty heating pump. replaced, all ok now.
Posted on Jan 05, 2009
mrhotandcold
  • 248 Answers
SOURCE: Biasi 24s combi boiler which is producing
change stat
Posted on Oct 12, 2009
  • 3248 Answers
SOURCE: hi, my ideal combi boiler model mini HE C28 goes
Hi check the flame senser is in postion and clean
Posted on Feb 01, 2010
burty681
  • 56 Answers
SOURCE: i have an ideal mexico
its your gas valve that need replacing
Posted on Feb 01, 2011
I have a baxi combi boiler which wont start and trips the electric..plumber has changed fan,ignition and now pcb to no effect...help!
Start by diconnecting main supply to Boiler (at the boiler input) and see if it trips the electric. This would point to fault in wiring from board to boiler.
Then check several points with meter to find short-circuit.
If not, then you have to TURN OFF THE GAS SUPPLY and connect and disconnect items such as solenoids, switches, board etc; until you find what causes it to trip.
Nov 18, 2014 | Heating & Cooling
Jolly boiler
Clean ignighter and piolet
Jun 11, 2014 | Water Heaters
I've got a Alpha 240 e combi boiler..... Everything seems to be wor,kin ok but it won't start the ignition sequence .
could be air presure switch which tells pcb that fan is working and would then bring inn ignition system then main gas valve.Would suggest getting gas engineer in.pommie engineer
May 26, 2012 | Water Heaters
Saeco Incanto Sirius doesn't turn on. Outlet fine. Is there a main fuse to check/reset? Other suggestions. Hopefully it didn't get surged with Hurricane Irene.
We have here the map with service support but as you can see they to have for the moment any at CT. However you can check if any other area is the best for you.
Sep 01, 2011 | Saeco Incanto Sirius Fully Automatic...
Need to know how to switch off hot water by combi boiler worcester bosch 240 to be able to fix leak on pipe downstairs
its the vavle 3 one in from the left its a 15mm pipe and there will be a iso vavle what you can turn with a flat point screwdriver and that will turn off the main water to the boiler these are the manual
http://www.worcester-bosch.co.uk/homeowner/literature/discontinued-boiler-literature/discontinued-gas-boiler-literature/240-bf-discontinued-december-1997-literature
Jan 23, 2011 | Heating & Cooling
Red boiler light will not go on. The boiler does heat up.
Open the steam valve when you turn the machine on that will vent out the boiler, keep it open until it starts to hiss slightly and produce small steam bubbles, then close and machine should heat to temp. If that solves your problem then the vent valve needs to be replaced, until then you can turn using the steam valve open trick.
May 31, 2010 | Isomac Tea Espresso Machine
Ferroli boiler error code A3
boilers need a certain amount of water pressure to operate as specified--there may be a pressure regulator valve, allowing a certain amount of water to your boiler, and when water is drawn elsewhere, there may not be enough getting to the boiler---this is one possible solution, but there are easily 20 more, and that is where a trusted plumber is worth it's gold...very difficult to diagnose most plumbing problems without being onsite
Mar 03, 2010 | Water Heaters
Hi there. Our valiant boiler doesn't seem
Lack of pressure in the primary circuit [radiators] Look for a pressure gauge should read between 0.5 & 1.5 bar
Somewhere there is a tap/valve/pipe connection to refill & looks like a small thumb turn or a screwdriver turn on a connection on the mains water inlet pipe. turn on until you get the right pressure then off
Dec 16, 2009 | Water Heaters
Baxi Combi 80e
i need to know boiler specifics- make and model but sounds like either the air pressure switch seized or the main printed circuit board, if the boiler has an overheat thermostat please ensure that the little red button hasnt popped out because this will prvent the boiler firing up- refer to the manufacturers instructions for location of the o/heat stat
May 05, 2008 | Combi Centre DX - Mango
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
