Question about Lasko Heating & Cooling
Lasko kenmore 5260 heater will not start up - Lasko Heating & Cooling
Lasko manual5155
The manual for the Lasko 5155 is available here: http://www.devicemanuals.com/productsupport/Lasko_5155_manual.html . You will need to review the heater to download the manual. Other Lasko manuals are available from the Lasko site. The current tower heaters have the manuals on their individual product pages. You can access the list here: http://www.laskoproducts.com/ceramic-tower-heaters/ . Other manuals can be accessed here: http://www.laskoproducts.com/?s=Manuals... .
I hope this helps.
Jan 07, 2014 | Heating & Cooling
New lasko heater keeps shutting down
fatly over heat switch or tilt switch some r very picky
Dec 10, 2013 | Lasko Heating & Cooling
I do not have a problem i need a manual or instructions on useing this heater for lasko ceramic element model #751320
Here is an email address for the Lasko Products Help Dept. They should be able to provide that for you. producthelp@laskoproducts.com If you prefer to call them the number is 800-233-0268.
Hope this helped you.
Mar 09, 2011 | Lasko 751320 Ceramic Heater
The fan makes an odd noise as if it were out of
Recalled: Discontinue use and see
http://www.laskoproducts.com/recall/recall_heater07.html
or call Lasko Products toll free any time at 1-800-984-3311 to receive a free replacement heater.
May 09, 2010 | Lasko 5362 Heater
I have a Lasko Model 5532 electric heater. It has suddenly started shutting off often. I run it through the reset procedure (unplug 5-10 minutes, then restart) and that gets it going again, but then it...
All of these space heaters have thermal protection units in them. They are safety that shuts the unit down if it starts to overheat.If your fan is operating, then it sounds like the thermal protection circuit is faulty, and you'll need to contact Lasko for a replacement. These units do not have parts that can be purchased due to their UL compliance. Check the fan though, it might be obstructed. I have seen that more than once....Rob
Dec 28, 2009 | Lasko 5530 Ceramic Compact Heater
Won't turn on. It gave me a beep when I plugged
Have you cleaned the filter that's on the back? This has happened to me, and I just took the filter out and cleaned it, and it worked fine after.
Dec 27, 2009 | Lasko 5130 Ceramic Compact Heater
Clean the filter : Lasko Model #5812
First make sure heater is unplugged. Next, on the side of the heater locate two holes (see image) these are what's keeping everything in front together. unscrewing these and genty pulling sides out lwill release the top filter and front where control knob is and bottom filter where the heated air comes out. Clean filter & re assemble.
Nov 30, 2009 | Lasko 5812 Heater
I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
Oct 19, 2009 | Tower Lasko 30 Inch Ceramic Oscillating...
Poping, smoking electric Lasko 5540 heater
It depends on where the smoke is coming from. If it's from the heating elements, it's normal as dust and residue burn off. If it is coming from the control section, it's bad and the heater should not be used.
Nov 05, 2007 | Lasko 5540 Ceramic Compact Heater
Heating & Cooling Logo
Top Lasko Heating & Cooling Experts
Steve
Steve Oakes
Mack Baxter
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
