Question about Samsung Televison & Video
How does the base attach to the bottom of a samsung flatscreen tv(2012)
Model #LN40E550F7FXZA The stand is attached at the bottom but the tv is very wobbly and we fear for it falling over
SOURCE: Removing bottom stand Flat Panel LCD Magnavox 32MF605W 32
There are 4 shiny screws at the back of TV just above the stand neck. Unscrew those 4 scrws and then lift the TV up, stand will come out.
Posted on May 21, 2008
SOURCE: Base Detachment
If you lay the TV down on something soft but firm (towel on the floor or counter) put the screen face down on the back you should see 4 screw holes with the an (S) next to them. They are located at the center near the bottom. If you remove these screws the stand should then slide out of the bottom of the TV. Good Luck
Posted on Jul 13, 2008
javswr
  • 44 Answers
SOURCE: TV wobbles on its pedestal stand.
Sounds like stand has been installed wrong an maybe miss aligned, and screws may be loose! Try removing and start over, or call installer back.
Posted on Feb 28, 2009
  • 4 Answers
SOURCE: Removing the stand off the boton of the TV
on the bottom of the foot there are some screws that u agve to take out
Posted on May 15, 2009
  • 148 Answers
SOURCE: need screw specs to attach base assy to tv
I
Hi there, if you are trying to just remove the base, then on your model there is one screw in the center of the underside of the base. If you want to remove the neck of the base to then remove the 8 screws on the back of the tvs neck too. I hoped this helped, please rate thank you!
Posted on Feb 05, 2010
How do I remove the base stand to wall mount a Samsung model T24C55OND flat screen TV
The wall mount attaches to the top 1/3 portion of the TVs rear panel. The bottom of the back of the TV should not interfere with your wall mount if it's the correct size. Full instructions are listed starting at page 39 of the manual.
http://downloadcenter.samsung.com/content/UM/201404/20140426112621559/[X13_NA]BN46-00319C-04ENG-0312.pdf
Jan 08, 2015 | Samsung Televison & Video
Can't figure out how to put the base on a 55 inch flatscreen colby tv
Usually the base is attached to the back of the TV by screws. The standard mounting method is widely used
Dec 15, 2012 | Audio Players & Recorders
Friends gave us their tv when they purchased a new one. It has no base to the tv and we cannot do a wall mount in our rental house. Where can I get a RCA L26HD35D tv base or stand to go in the slot on the...
RCA which is Thompson is the only likely place and you will need to tell them the model number and do not forget the base may not if available come with the bolts that attach it to the set.
Jun 12, 2012 | RCA L26HD35D TV
I bought a new Vizzio M22OVA and have been trying literally for days to attach the base stand. I even called Vizio customer service and they were no help. I'm at a total loss. I really love the design of...
The stand has 8 small tabs that protrude from the top of the stand. There is also a larger clip that sticks up a little in the center. Purpose of large tab is to snap into place to keep stand from coming off. Just place stand on bottom of tv so the tabs on the stand go into the holes in bottom of tv.
Then just slide stand forward or backward till it snaps into place. I think 2 screws go into the bottom of stand after it is snapped in place to hold it. Just be careful and don't put any undue pressure on the screen. Actually works better with one person holding the tv upside down while another snaps base in place.
Jul 04, 2017 | Televison & Video
TV tilts forward on base about 15 degrees,
The only things I could think of causing this would be either the hardware not tightened up properly or defective base (stand.) Make sure all the screws are tightened securely in the bottom of the base and in the back of the tv where the base attaches. Someone may have used the wrong screw holes to attach the base but there really should only be 4 holes to use to screw the base to the tv. This may need returend to the retailer for an exchance of the base.
Mar 09, 2011 | LG 42LC2D 42 in. LCD HDTV
How do you take the stand off a LN32B530 in order to wall mount it?
The manual for this model is located at
http://downloadcenter.samsung.com/content/UM/200903/20090331173532953/BN68-01883M-00L02-0219.pdf
From what the instructions say, there are 4 screws on the back of the tv, at the bottom.. These go through the tv and into the base. Remove them and it should come off.
Mar 06, 2011 | Samsung LN32B530 32 in. LCD HDTV
Problem on Samsung 55" set can't remove base
A difficult one as Samsung do not recommend that this uint is wall mounted but there should be 4 screws attaching the stand to the base of the TV chasssi but if you do remove it you will end up with a gap in the cover as Samsung do not provide blanking covers to cover it up.
Oct 05, 2009 | Samsung DLP HL-P5663W 56" TV
Removal of flat screen pedestal so I can wall mount tv
Had the same issue. I turn the unit upside down and while holding panel down just pulled staight up on the base. The circular base popped off without any damage. I just needed to remove for shipping.so I didn't have to remove the cylindrical post. Once the base is removed you can see a screw that probably attaches that cylinder to the unit. Carefully removing it should work. Good Luck....j
Nov 23, 2008 | Televison & Video
Base Detachment
Jun 16, 2008 | Samsung LN-S2641D 26 in. LCD HDTV
Televison & Video Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
