Question about Ryobi Thickness Planer Blades
How to remove motor on my rigid tp 13002 planer
Is there a fuse or a reset button on a Ryobi 10 inch surface planer. My planer stopped working after getting too hot. Now, it won't even trn on....
check the motor for a thermal over load button
to stop it over heating take more lighter cuts as the motor is a small motor compared to what the cut can be
May 09, 2016 | Ryobi Planer. 15 Amp 13 in. Planer AP1301
I need all manuals for my SAC RS 63-S Surface Planer
Planers - Single - West Coast Machinery
www.wcmachinery.com/WCMACHINERY/myinventory.asp?...S...
Delta/Invicta RC-63-D 24" Planer in excellent condition. ... Table jack screw sprocketshave been replaced ... 16" single surface planer, - 5HP 208-230 volt single phase belt drive motor, - push ... with operation manual, - excellent condition but offered "as taken from service". ... 2240/440V, three phase S/N 203851 1974 year.Missing: my
Wood working machinery > Planers > Thickness planer (used)
www.machineseeker.com/2-106-65.html
Used Dickte SAC, further information will follow shortly... 2.500 EUR ... Thickness Planer, Thicknesser Huefner & Soehne 63 ... Thicknessing machine Sicar S 500... Working width: 500 mm Working height: 200 mm 2 speeds 2 Table rollers manualtable lift 4 knives - Safety shaft. ... Thicknesser mitTersawelle SAC RS 53Missing: my
Woodworking Planers - Southwest Machinery & Equipment
Dec 14, 2015 | Masonry Tools
I have my ryobi planer completely apart to replace bearings but cannot get the housing off of the armature. Do I need to remove the brush holder? How? Any suggestions.
Well, you've probably already done it but make sure you HAVE removed the motor brushes. Usually hidden under a couple of plastic plugs that unscrew. That releases the commutator. The motor should then slide out. Depending on exactly which Ryobi planer you have be aware that sometimes there's a sticker on the end of the motor that actually hides a circlip or other holding device. Good luck!
Feb 24, 2015 | Tools & Hardware - Others
Need delta planer manual
It's easier to find parts and manuals with model numbers. On the Dewalt service website (http://servicenet.dewalt.com) they show your motor number is substituted with part number A00903. If you do a parts search on that motor you will see it fits four different Delta planers, all but one has a manual listed under downloads. Find the model closest to your planer.
Dec 03, 2012 | Masonry Tools
Planer problems
If you're looking at the planer from the infeed side, there's a belt guard on the right side of the head. Remove it and check the condition of the drive belt. If it's broke the motor will spin without powering the cutterhead and feed rollers. The drive belt is still available as part number 22-563 on sites like http://servicenet.dewalt.com/ and www.ereplacementparts.com. Just put your model number in their search box and find the drive belt in the breakdown.
Aug 01, 2012 | Masonry Tools
Is this a good planer?
I do not have that planer, but I live thirthy miles form a Grizzly Store in Williamsport, Pa.
I have many friends that will go no where else to get their tools for their shop...
Have never heard any complaints about any of the Grizzly products...
And yes I have a couple of friends that have that planer and they love it...
You should be well satisfied with that product!
heatman101
Feb 21, 2011 | Grizzly G5850Z 20" Professional Planer w 5...
Can I level the infeed and outfeed tables on my 6" Ridgid planer/jointer? I don't see such information in the manual.
The majority of jointers even cheap chinese imports have 3" or 4" hand cranks for both infeed and outfeed adjustments. The gibs can usually be adjusted when needed even on cheap jointer planers.
The rigid website has a support page and product parts and manual download.
If the download doesnt work call them and insist that they e-mail or mail a paper copy.
Most jointer planers are somewhat similiar in design and appearance.
Some power tool instruction manuals from competitors may have more complete step by step instructions.
Jan 20, 2011 | Ridgid Masonry Tools
I have a wood planer with a 3HP 220 single phase motor wired to 20amp circuit breaker in my house. I usually run the planer off a 12gauge extention wire about 30ft from the house plug. I would like to...
Look on the planer to see what the R.L.A. are, for example 16.0 amps. Set a box with 2- 20 amp fuses, or a double pole 20 amp breaker. Do not exceed the amperage of what the planer says on its data plate. If the R.L.A. is 10.0 to 19.3, use a 20 amp.
Sincerely,
Shastalaker7
Jan 20, 2011 | Inline 20 amp. In-Line Circuit Breaker
I just inherited a Rigid TP3100 surface planer. Vertical guiding rods have some rust & I can only get a small height adjustment. I just put a little penetrating oil where the rods enter 'sliding...
I can't find a Ridgid TP3100 planer but there is a TP1300 but the fix is the same. Your best bet to remove the rust is to completely remove the rods and clean them with rifle bore cleaner (RBC), steel wool and a lot of elbow grease. You'll have to rub them until all the rust is gone and they're shiney and smooth again. Also check the upper head where the rods slide through to make sure they are clean. An alternative is to replace the rods, they run about $14 each, Ridgid part number 827718.
Jan 19, 2011 | Ridgid Garden
Planes Safety tips
* Always wear safety glasses when you use a power planer. * Keep blades in your planer sharp. Never remove any debris or touch the planer blade if it is plugged in. * Always clamp wood to a sturdy surface when you use a power planer.
Aug 27, 2008 | Bailey Stanley 12-920 - Block Plane
Ryobi Thickness Planer Blades Logo
106 people viewed this question
Top Ryobi Masonry Tools Experts
ray gallant
Tom Chichester
Are you a Ryobi Masonry Tool Expert? Answer questions, earn points and help others
