Question about Corvette Chevy Malibu 90-04 Car Radio Wire Harness
Ignition wire color 2002 - Corvette Chevy Malibu 90-04 Car Radio Wire Harness
2002 buick rendezvous ignition key immobilizer wire color diagram image
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Oct 22, 2016 | Buick Cars & Trucks
What is the color of the wire by the ignition for the fuel anable
A 2002 grand prix 3.8 liter has a fuel pump that is controlled by the PCM. The PCM supplies power to the fuel pump relay. That relay energizes and allows current to flow to the fuel pump.
In order to help with your problem it may be better to describe the problem to give a better idea of what information you need.
Oct 09, 2016 | 2002 Pontiac Grand Prix
How do you hotwire a 2002 olds alero
Get a wiring diagram and colors will be shown.
Jan 16, 2015 | 2002 Oldsmobile Alero
Will the 2002 Audi tt radio work with the ignition off?
Normally radio's only work with the ignition off when wired to the ACC side of the ignition switch. you need to see if there is a (red is the usual color) wire linked to +12v at the back of the radio
Jul 15, 2014 | 2002 Audi TT
2002 kia spectra color code ignition switch diagram pdf
PART COLOR LOCATION 12 VOLT CONSTANT WHITE/BLACK (+) and WHITE (+) IGNITION SWITCH HARNESS STARTER RED (+) IGNITION SWITCH HARNESS STARTER 2 N/A IGNITION 1 YELLOW (+) IGNITION SWITCH HARNESS IGNITION 2 N/A IGNITION SWITCH HARNESS IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 BLUE (+) IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 2 GREEN (+) IGNITION SWITCH HARNESS
Dec 27, 2011 | 2002 Kia Spectra
How to change plugs on 02 kia sportage
  • 1
    Keep a regular schedule for inspecting the spark plugs on your 2002 Kia Sportage. According to the official 2002 Kia Sportage owner's manual, spark plugs and ignition wires should be inspected every two years or 48,000 miles, whichever comes first.
  • 2
    Let your 2002 Kia Sportage sit for a few hours before opening the engine compartment. You want to make sure that the engine is cool before you begin working on it.
  • 3
    Pop open the hood of your Sportage and locate the ignition wires, which will be attached to the top of your engine. The 2002 Kia Sportage has a four-cylinder engine, meaning there are four spark plugs each attached to an ignition wire. The ignition wires run from the engine to the fuse box, which is located in the left side of the engine compartment.
  • 4
    Inspect the ignition wires of your 2002 Kia Sportage. These wires will need to be replaced if they appear worn.
  • 5
    Disconnect the ignition wire to your spark plugs. Grab the rubber boot located near the base of the wire and pull upward instead of yanking on the wire. Remove only one wire at a time, or mark the wires with a colored Sharpie marker before disconnecting all of them. Improperly reconnecting the ignition wires can seriously affect the performance of your Kia Sportage.
  • 6
    Attach the spark plug socket to your socket wrench. Use the socket wrench to remove the spark plug from the top of the engine's cylinder.
  • 7
    Inspect the spark plug. There will be some soot, but if the spark plug is completely covered in soot, it needs to be replaced.
  • 8
    Position your replacement spark plug in place and secure it with the spark plug socket on your socket wrench. Be careful not to overtighten the spark plug after it has been snuggly fitted.
  • 9
    Position the rubber boot of the proper ignition wire in place above the spark plug and insert it with your hands. Close the hood of your 2002 Kia Sportage
  • Mar 16, 2011 | 2002 Kia Sportage
    What color is the +12V wire on the ignition moduale
    The 2 wire connector on the module and the ignition voltage wire is pink.This would be in terminal B.Good luck.
    Nov 22, 2009 | 2002 Buick Rendezvous
    Which color wires go together in a 2002 chevy impala stereo to make it turn on?
    If its an aftermarket stereo, the Yellow wire will be 12v all the time. Red is when ignition is turned on, and black is ground. The rest are speaker wires. Mike. Rate 100% please.
    Sep 19, 2009 | 2002 Chevrolet Impala
    Stereo wiring
    The ignition wire on your gm is yellow.
    Jun 29, 2008 | Car Audio & Video
    Corvette Chevy  Malibu 90-04 Car Radio Wire Harness Logo
    14 people viewed this question
    Top Corvette Car Audio & Video Experts
    xxxxxx xxx
    Mike Dutton
    Chris Ward
    Are you a Corvette Car Audio and Video Expert? Answer questions, earn points and help others
