Question about Epson Office Equipment & Supplies
WF 2530 Epson adf scanned documents come out with long parralel streaks all the way down the middle
Flatbed scans are fine
SOURCE: scanning document leaves streak down right hand side
Backu
Thanks for the tip...the problem is NOT a black line but a wide yellow line on the right side of the paper. It starts out about a quarter of the page in width and diminishes in size to about a half inch in width after many repeated scans.
The glass IS clean , and even when the glass had some smudges here and there, I never had a yellow stripe problem!
Scanner bulb is bright and even the entire length of bulb (no dark areas) so I don't think it is the bulb!
Rowboat
Posted on Dec 26, 2007
Bubbabear64
  • 2794 Answers
SOURCE: RICOH AFICIO 1022 ADF scanning with a black line down right-hand side
There is a tiny spec on the scanner glass. Cleaning it will make the line go away.
Posted on Jul 11, 2008
crayzeetrayn
  • 837 Answers
SOURCE: when scanning document stops halfway through ADF
Have you tried lowering the resolution of the scanned document?
Posted on Nov 24, 2008
Joed911
  • 4338 Answers
SOURCE: Line on scanned documents
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Feb 20, 2009
SOURCE: When using the ADF for scanning to pdf, it creates
hello,
there might be a dirt or white out on the scanner unti.u need to have a lint free cloth and isopropyl alcohol.follow this instruction:
lift document cover.clean the white strip that is located underneath the cover on the left side of the white film.clean thin glass strip located on the left side of the scanner glass of the flatbed.tried making copy using adf.if copy has still black vertical line, clean the white strip and thin glass strip 3x and run your fingertip over the glass strip to check if u feel any debris or dirt.
Posted on Dec 09, 2009
Epson Wf-4630 keeps jamming when i use the ADF to scan documents
It may be due to the corner of the paper is bend or not exactly parallel.
Nov 04, 2016 | Epson WorkForce WF-4630 Wireless Color...
WOT DOES ADF MEAN ON MY EPSON WF-2630
ADF stands for Automatic Document Feeder - used for scanning multipe paper feeding
Apr 15, 2016 | Epson WorkForce WF 2630 Wireless Printer
When I try to make copies using the ADF the screen tells me to remove documents and place on glass.Can you explain why. I have sveral pages
Automatic document feeder requires you to insert files into holder and let the machine scan through the pile providing you have not over ridden settings to manual.it sounds as if you have switched off adf to manual which would require you to place each document onto glass one at a time.see if you can switch it back to auto in the screen menu.
May 04, 2015 | Epson WorkForce WF-2530 All-in-One...
I have an Epson WF-2530 printer and when trying to scan a message comes up that says Remove paper from the ADF and below that message it says 1. Yes 2. No. I have removed the paper but the message...
Apparently the printer detects paper in the automatic document feeder input. Mostly detection is done using a tiny switch or light sensor. Remove all paper and look if there are any pieces of paper or paper dust in the paper feeds. You can also try to use a vacuum cleaner with a small tube or a compressed air duster to clean off any pieces of paper or dust.
Oct 19, 2014 | Epson Office Equipment & Supplies
Epson troubleshooting
for iPad & iPhone you can use Epsons App "iPrint"
Wireless Printing with Epson iPrint
    Epson iPrint offers the convenience of wireless printing direct from your iOS™ or Android™ devices. With iPrint, you can easily print web pages, Microsoft® Office™ documents, photos and PDFs over your home or office network. You can also scan and save onto your mobile devices, send as an email or upload to a cloud service such as Box.net, Dropbox, Evernote® or Google® Docs™. Epson iPrint is free to download from Apple App Store and Google Play Store.
for the Mac download the latest software below:
Epson WorkForce WF 2530 All in One Printer
epson-troubleshooting-wutfveiel3ypko01ydor435x-1-0.jpg epson-troubleshooting-wutfveiel3ypko01ydor435x-1-2.jpg
Sep 06, 2014 | Epson WorkForce WF-2530
How do I fix the automatic document feeder on my Epson wf-2530
The best way to sort this out is to First go to the Epson website (http://www.epson.com) and click on your location - many Epson printers have different model numbers and drivers depending on location - then download the drivers and other software for your product - the website will normally correctly identify your operating system so you get the right products to download. Before installing do this - go to Start - Control Panel - Printers then click on the printer icon and press the Delete key on your keyboard and thus delete the existing installation. Obviously you should have the printer switched off for this operation. Now run the setup for the new download and when advised onscreen, switch on the printer and when all finished, your printer and its facilities should all be properly restored. Sometimes problems such as yours can occur through another background utility interfering and rendering something inoperative or could have been a small electrical spike. In any event, do the reinstall using latest software as described.
Aug 22, 2014 | Epson WorkForce WF-2530
Scanner leaving black streaks
There are two possible fixes.
Download the latest firmware update by CLICKING HERE
The following is provided by courtesy of Lexmark:
Problem Vertical lines; Auto document feeder scan anomaly; ADF scanning problem; Scan issue; Scanner issue; Visible line; Streaks show on page; solid line down the page; Top to bottom line; Smudge runs down the page; Opaque line; Broken line; Bar all the way down the page Solution Overview
This article provides the self-diagnostic steps necessary to evaluate top-to-bottom streaks that appear when copying or scanning.
Important! This is seldom a scanner hardware failure.
The main reason for this anomaly is debris or marks on the scanner glass that is used for Auto document feeder (ADF) page scans.
Printed or Scanned Page Illustration
Who should consider this article?
Any user of an MFP or All-In-One printer experiencing the following symptoms:
  • -Vertical lines only when using the Autodocument Feeder (ADF).
  • -Observed with any type of scan job (e-mail, ftp, solutions, fax).
  • -However, normal expected output when the page is scanned from the scanner flatbed.
ADF scan behavior
Think of it this way:
  • -The page is pulled from the ADF.
  • -The moving page slides across an ADF-designated portion of glass.
  • -The image sensor, which is located under the glass, reads and interprets the moving page's contents.
  • -Contamination on this ADF glass is seen by the image sensor for the entire length of the page.
  • -The image processor interprets the image sensor's repeated capture of this contamination as a vertical solid line.
  • -Any ADF scan function now exhibits a vertical line.
Suggested Diagnosis and Fix
Step Action 1 Locate the portion of the glass designated for ADF scans.
HINT: The glass location differs by model. This area is often separate from the scanner flatbed. Please reference User's Guide for more information if you are having a difficult time locating this designated area.
2 Perform a visual inspection for any of the following recurring culprits:
  • -Clear adhesive tape
  • -Glue
  • -Ink pen
  • -Paper
  • -Marker
  • -White out
  • -Staples
  • -Environmental dust or dirt
HINT: Ink marks can be especially hard to see and almost translucent at first sight. However, the image sensor (CCD) registers them as a mark. 3 Use a clean, soft, moistened cloth to thoroughly clean and remove any marks or debris. 4 Inspect the underbelly or underside of the ADF for any marks or debris. 5 Perform another scan to see if cleaning the glass alleviated the issue. 6 Repeat the procedure if a vertical line still appears.
Remember! Printing and scanning from the scanner flatbed work fine.
7 This time, place an intentional mark on a blank sheet of paper and take note of its location. Now place that sheet of paper in the ADF and make a copy.
8 Evaluate the distance of the vertical line to the your mark. 9 Inspect that area of the glass for further debris or marks and clean as necessary.
Other Possibilities
If... Then... Vertical lines appear only when printing... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear when you lay the page on the flatbed... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear on ADF-fed printed copies, but they do not appear on scan-to-network [e-mail, FTP, folder (PC), solutions]... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support.
May 01, 2012 | Lexmark International LEX90T9005 Inkjet...
How do I get rid of the line running down the scanned document?
Simple, clean the ADF glass that the paper passes over during a scan (not the flatbed glass itself, just the thin strip of glass at the head of the flatbed glass). A speck of dirt on the glass will appear as a line down the length of the paper.
May 23, 2011 | Epson GT-2500 Flatbed Scanner
I have the Epson GT2500 scanner. There is a black line down the middle of every page that I scan
There is a speck of dirt or some such on the ADF Scan glass not the flatbed iteself. As the paper travels over the glass the speck of dirt is being seen by the scanner making a "line" appear on the entire length of the scan.
Feb 16, 2011 | Epson GT-2500 Flatbed Scanner
How do I scan a bunch of originals from the tray and get 1 file for each page?
Loading originals to scan
Use these instructions to load originals into your device for scanning. For the best quality
scans, use the flatbed scanner. See Selecting media for the automatic document feeder
(ADF) for guidelines on choosing original documents for scanning.
Loading originals onto the flatbed scanner
1. Make sure that the automatic document feeder (ADF) input tray is free of media.
2. Lift the flatbed scanner lid.
3. Place the original document face-down on the flatbed scanner with the top, left corner of
the document at the lower-right corner of the glass.
4. Gently close the lid.
5. The document is ready to be scanned.
CAUTION To prevent damaging the device, do not allow the scanner lid to fall onto the flatbed scanner
surface. Always close the scanner lid when the device is not in use.
Loading originals into the automatic document feeder (ADF)
input tray
Note The ADF capacity is up to 50 sheets of 75 g/m2 (20 lb) media (depending on the thickness of
the media), or fewer sheets if the stack fills the ADF.
The minimum size for media in the ADF is 127 by 127 mm (5 by 5 inches). For smaller sizes
use the flatbed scanner. The maximum size for media in the ADF is 215.9 by 381 mm (8.5 by
15 inches).
1. Make sure that the flatbed scanner contains no media.
2. Close the flatbed scanner cover and put the top end of the stack of originals into the ADF
input tray, with the media stack face-up and the first page to be scanned on top of the
stack.
3. Slide the stack into the ADF input tray until it does not move any farther.
If this helps you, let the Boss, FixYa.com Know...
May 13, 2008 | HP LaserJet 3030 All-In-One Printer
32 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
