Question about Kenmore Sewing Machines
Kenmore model 2142 Sewing Machine hand book - Kenmore Sewing Machines
SOURCE: Kenmore Sewing Machine model # c877.15
I have an old Kenmore and here are the directions from my manual: 1. Draw thread from spool through bobbin winder tension discs. 2. Wind thread around an empty bobbin several times. 3. Place bobbin onto bobbin winder shaft with thread coming from rear of bobbin. Push bobbin winder latch against bobbin until it clicks. 4. Release clutch by turning clutch knob toward you. Start machine.
Posted on Aug 09, 2007
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
SOURCE: Kenmore sewing machine manual for model # 148 12080. (older)
i have a older kenmore sewing machine model #148.19370
Posted on Sep 17, 2008
Michaelle
  • 65 Answers
SOURCE: need help to thread our sewing machine.
you really must get a manual for this machine.
You can find manuals online for a small price.
At one time some sites had them for free, but I haven't been able to find many recently. sewusa.com has some older ones for free. but not many. you could try the kenmore site as well, if not I'd try to search on dogpile.com (sewing machine manuals)
Just so you know, your manual is the MOST important tool for any sewing machine, and its worth a couple of bucks to get it.
Posted on Jan 24, 2009
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
The bobbin winding mechanism on my Sears Kenmore model 2142 doesn't work. I have to wind my bobbins by hand! How do I fix this feature?
If you don't want to pay for a service call, you can purchase a handy implement (a stand-alone bobbin winder) for about $30 at the local fabric store or online.
Amazon com Simplicity SideWinder Portable Bobbin Winder
Mar 15, 2017 | Kenmore Sewing Machines
Model 2142. Motor runs but why doesn't belt move for regular sewing?
Make sure the bobbin winder has not been activated. When the bobbin winder is activated, the needle bar is deactivated. The belt could also be stretched, damaged, or broken.
If it is a mechanical machine, how long has it been since a thorough cleaning and oiling?
It was working now it seems to be frozen the needle part wont move
Mar 06, 2016 | Kenmore Sewing Machines
How can I get a free downloadable kenmore 158 sewing machine users manual
Search the internet for:
Manufacturer + Model + the word "Manual"
FWIW, most Kenmore manuals are not available for free, but usually you can find them at Sears. (P.S.--the manual is worthwhile having in order to operate and maintain your machine properly AND decrease your frustration!)
Jan 10, 2016 | Kenmore Sewing Machines
I need a sewing machine kenmore model 2142 manual. any help?
Hi. Could you please verify the model number as I couldn't find model 2142 listed. Most Kenmore models begin with a three number prefix (385 or 158 most commonly, but also 148, 117, and 877).
Thanks!
Robbie
Mar 17, 2010 | Kenmore Sewing Machines
Need manual: Kenmore sewing machine 158.9
Those books are long since out of print. Try contacting sewing machine stores who stock old instruction books. Many shops do this. Or try eBay.
http://shop.ebay.com/i.html?_nkw=instruction+book+kenmore+sewing&_sacat=0&_trksid=p3286.m270.l1313&_odkw=instruction+book+sears+kenmore+sewing&_osacat=0
Jan 24, 2010 | Sewing Machines
Kenmore 2142 sewing machine won't zigzag.
Before you put the cam in did you make sure the machine was set on straight stitch and then select zig zag?
Nov 05, 2009 | Kenmore Sewing Machines
I need a FREE manual for a sears kenmore 2142,model 158.331. i need to know where to oil it and thread it.
Unlikely you will get a free manual but try this site for manuals www.sewing-machine-manuals.com and click on relics, don't be put off by relics
Nov 02, 2009 | Kenmore Sewing Machines
Sewing Machines Logo
35 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
