Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
Xerox workcentre 6505 error code 016-317 - Xerox WorkCentre C2424DN All-In-One Laser Printer
  • 2072 Answers
SOURCE: reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
Posted on Apr 03, 2008
  • 2072 Answers
SOURCE: Xerox WorkCentre M128 - 016 - 782
There is an error in the in the server password or a template setting.
Here is the documentation. Pretty straight forward
Login to the Server was not possible during Scan to Server file transfer.
arrwup.gifInitial Action Refer to BSD 16.1.
Power OFF/ON
arrwup.gif Procedure Set the login name and password in the destination server.
Set the attributes of the Job Template file correctly.
From a client PC, set the same account as the above as a resource using CW.
Posted on May 19, 2008
  • 3 Answers
SOURCE: Xerox WC Pro 35 - Error 14-563
this code means your scanner has failed to setup correctly. this could be a problem that you would need a qualified tech to service the copier. there is nothing that you can do after you power off and power on (popo) the copier. it could be voltage, pwb board, or a binding scanner assembly.
Posted on Oct 07, 2008
SOURCE: LSU Error
Hi Dear
I am facing LSU Error on my Xerox workstation PE 220
I am not able to do anything, please let me wat to do
i have lot of work penindg
urs
mujahid
Posted on Oct 13, 2008
  • 2072 Answers
SOURCE: workcentre c2424 is showing system error 39,003.40:117010
That is a document feed or scanner fault. Often times it is simply that molex connector working loose. It is the connector mounted vertically next to the main power cord on the right rear side of the machine. That bottom screw can be dificult to tighten. What I would try first is to shut the machine off, unscrew and disconnect that conntecot totally then firmly slide it in and get both the top and bottom screwss tight. Like I said, the bottom thumb screw can be hard to tighten even with a screw driver because it is a pretty soft rubber the tighteners are made out of.
If that doesnt work. go to the back and disconnect the document feed to scanner cables and reconnect. Other than that, you pretty much have to replace the feeder/scaner assembly since very very few parts are spared for that .
Posted on Oct 23, 2008
Xerox 6505 Scanner Sensor Error 062-360
Check out the Xerox.com website.
Good luck..
Oct 03, 2014 | Xerox Office Equipment & Supplies
Xerox black developer fade printing
Try this: http://www.fortwayneprinterrepair.com/wordpress/2014/03/17/xerox-phaser-6500-workcentre-6505-light-print-issues
Apr 25, 2014 | Xerox 6500/N Phaser Laser Printer
Xerox workcentre 6505 reset drum
You will need to replace the chip on the drum unit with one like this that is available for purchase.
2pcs Drum Reset Chip Imaging Drum Unit for use in Xerox Phaser 6500...
Mar 20, 2014 | Xerox Office Equipment & Supplies
Scan documents on the 6505/DN using my pc or mac, what do I need from xerox
copier/scanner should do the trick and the new product will contain all the equipment.
Oct 17, 2013 | XEROX - COLOR PRINTERS 6505DN 6505/DN...
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
245 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
