Kyocera KM-6330 ( c-6020)
Hi, hope you can shed some light on a problem I'am having, The machine was unpluged with power on and the hot connection was broke off. I fixed the power cord, power machine up & got C6020. I replaced thermister , same thing, checked power supply it semmed to be ok. I then took the power supply to the Wholesaler I bought the machine from and I tried it in a different machine, it was fine. This is where I'am @, I'am thinking main pcb?. Any help you can give would be greatly appreiciated. Thank You very much for your time in this matter. Chuck Clark
  • Chuck Clark Nov 02, 2007
    all the lamps are fine,thermister is good, thermal fuse is good.all conections are in good condition. power supply is fine. i'am in the process of checking main PCB, thanks for your help.
    Problem Solver:
  • 5 Answers
Hi could you enter to simulation and run sim 163 and enter execut
and maybe you correct the problem
Posted on Jun 22, 2009
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Did you check the thermofuse? are you getting continuity from the fuser lamps?
Posted on Oct 31, 2007
  • CheckitRight
    CheckitRight Nov 02, 2007
    also, some copiers like toshiba have a switch ( a relay) that sometimes pop worth taking a look at.
  • maligyo andrew Aug 02, 2013
    yes we are still receiving the same problem
Call for Service ...... C710
Hi there
I have found various documents which may help you with this problem and possible future problems. This page:
Error Codes Kyocera Mita KM1530 Code C710
can find any code connected with Kyocera mita machines by changing the machine and the error code in the appropriate drop down menus. C710 is identified as:
Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Another page showing error codes and their meanings is here;
Kyocera Mita Error Code Messages
and this confirms the above.
Also the link below takes you to a Kyocera web page where you can download various manuals for this machine (KM-1530). By changing the product in the drop down menu to KN-2030 you can get similar manuals for this machine.
Download Center
In your question you mention "Compatible KP23153 Black Toner Cartridge 106153" and that led me to wonder if the compatible cartridge is the cause of your C710 error since that is toner related.
Might be worth trying an original cartridge to see if the error goes away.
Hope this is helpful, if so would you please register that with Fixya
Nov 24, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
How to reset kyocera cs-1500
Hi Nickolas,
You may want to visit this site that has a manual of your machine in order for you to check the reset process. Hope it helps.
Kyocera KM 1500 KM CS 1500 Operation Guide Rev 2 0
Apr 25, 2014 | Xerox Phaser 4500 Printer
How can i clear an error c3300?
Hi anonymous, Firstly read your user manual. Secondly search online for "error code c3300 kyocera km5050". I did and therefore can't see any reason to spoonfeed any further.
Aug 25, 2012 | Kyocera KM 5050 Toner Cartridge 34000...
Kyocera fs-c5400 toner usage
I don't think you are looking at coverage I think you are looking at toner levels
Aug 09, 2017 | Kyocera FS Office Equipment & Supplies
Unable to copy with my Kyocera KM-1815. Error code is C3200.
Typicaly the scanner optics would need to be cleaned. Or it could be a scan lamp failure. A Kyocera dealer could help you with this.
May 27, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
Kyocera km-f650 keeps saying self testing...
Open the top cover and remove the toner cartridge.
Unplug the power cord
hold down the ENERGY SAVER KEY while plugging back in
display should say RAM INITIALIZE
scroll down to SHIPMENT SET
press SET
press 2
Wait for the machine to reinitialize.
Oct 21, 2009 | Kyocera KM-F650 Plain Paper Laser Fax
I need to detach finisher from main body and then reattach once I have moved it to the next room.
Turn off main switch. Unplug power cord. Remove two screws where the extendable frame of the finisher connects to the copier. Unplug the connector cord from the back of the copier by pushing release button on the connector.. Done.
Apr 14, 2009 | Office Equipment & Supplies
Km-2030 Checksum error f1
my copier is displaying error code 100, whats the problem km 2030
Jan 21, 2009 | Kyocera FS-2000D Laser Printer
Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
Oct 20, 2008 | Kyocera Mita KM-1815 All-In-One Laser...
Have error: C6000 on Kyocera KM-3050
Have Kyocera FS-1118MFPF that is coming up with Error C6000. Can we fix this ourselves
Aug 02, 2008 | Office Equipment & Supplies
558 people viewed this question
