Question about LG 47LE5500 TV
No back light no sound
My 47le5500 LG TV lost picture and lost sound. I wanted to post this to thank everyone that posts problems and solutions .if your smart you will research answers wisely. I replaced my power circuit board, it cost me 100, it didn't fix the problem. The only other thing to replace is the main board. Then I noticed someone put a main board into an oven and it fixed the problem. So that what I did, Didn't Have Anything To lose, I couldn't find a main board for my 2 year old TV. IT WORKED. Put it in for 8min at 240f. Let it cool down, installed it and I'm watching TV again, 2 days so far. Keep on posting problems because there's always a solution....cheap electronics, not built like the old days.
  • Steph DsBlings Dun
    Steph DsBlings Dun Apr 02, 2016
    Well I be. Placing the main board in the oven actually worked. Thanks for sharing, although it was two years ago. Great info to come across, my TV now works
SOURCE: Keeps turning off
I am having the same problem, is there any solution for this problem?
Posted on May 26, 2008
  • 8 Answers
SOURCE: replace main board on LG 42LC7D-UB
not sure what you're referring to as a "main board", but heres the LCD Control Board for the TV
http://cgi.ebay.com/LG-42LC7D-UB-LCD-CONTROL-BOARD-6870C-0119A_W0QQitemZ150277759127QQcmdZViewItem
Posted on Mar 13, 2009
  • 92 Answers
SOURCE: LG 47LC7DF LCD TV Remote Sensor not working
IR senor may not be bad. Try using a different remote (universal) and program to TV. If universal remote works and your doesn't, you may need to purchase a remote instead of IR board. If you confirmed that the IR board is bad then replacing the IR board will fix the remote issue. IR board is an easy fix. Just open the back cover out and it's located right in the middle toward the bottom of the TV.
Posted on Jun 22, 2009
dsacco86
  • 1077 Answers
SOURCE: 42 Inch Plasma 42PC3D-UD
Option 1
If you or your husband have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
Option 2
http://www.shopjimmy.com/catalogsearch/result/?q=42PC3D-UD
This link sells repacement boards for your TV. If you know which ones the tech said are bad, you can order them and replace the board yourself.
Option 3
Pay $475.00 to get it fixed. :(
I hope I shed some light on the subject for you.
Posted on Jul 05, 2009
SOURCE: LG 42PX4MVH PLASMA TV - Sound but no picture.
I have the same issue with my LG 42PC3DVA and I narrowed it down to the Y SUS board. After a little research there are a few items that are prone to go. The ceramic fuses (as you found), sometimes the capacitors on the Y SUS, Z SUS, and power supply go along with them You can tell because thy will be bulged at the top instead of flat. I replaced a few of my capacitors - they are only $0.89 each so it was MUCH cheaper than a board.
The other thing that is common on the Y SUS in particular are the FETs (also called MOSFET). They can be replaced if you are good with a soldering gun but they are static sensitive so be grounded. They are also a bit tricky to test so you may want to do some research on how to determine if this is the issue... or you can just replace the whole board.
Posted on Oct 28, 2009
LG TV 60PZ550 black screen no pic or sound green lit flashing it has back lite
LG 60PZ550 Plasma - No Sound, No Picture - Badcaps Forums ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Sep 15, 2013 - 20 posts - ‎4 authors
LG 60PZ550 Plasma - No Sound, No Picture Troubleshooting TVs and Video Sources. ... I see no change in the screen at any point (no glow). With the rear cover ... I've worked with some electronics in the past, but am new to TV's. I'm sure .... Multimeter on DC 1000V, red on (+) marked, black on (-) marked. Lg 3d plasma 60pz550 i've got sound but no picture
Jul 18, 2014
LG 60PZ550 color issue - Badcaps Forums
Jun 9, 2014
Purple/Pink Lines / Postering on plasma LG 60PZ550
May 29, 2014
LG Plasma 60pz550 has strange greenish rainbow ...
Jan 20, 2014
More results from www.badcaps.net
Jan 10, 2016 | LG 60PZ550 3D Plasma TV
MY LG TV HAVE NO VIDEO NO LIGHT BUT ONLY SOUND
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Oct 19, 2015 | LG Electronics 50PN4500 50" 720p Plasma TV...
LG LED TV model 47Le5500. would turn on/off but no picture or video. is this still fixable?
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Apr 02, 2015 | LG Televison & Video
Where was my problem solution posted on this site?
I only see one previous post of yours at FixYa, about a password to some unspecified website.
If you posted your question on some other website then please go to that website to find solutions.
Jan 24, 2014 | FixYa Service
I've upgraded the FW on my LG 47LE5500 and now the TV is not succeeding to start - looping reboot
Ur tv Firmware u upgraded it have corrupted files or the wrong version.Sorry ur main board tv Tuner signal board it have corrupted in it softwares or the wrong version in it CPU programming now.This problems,u cannot be undone or put the old version back.Only can repair by doing replacing a whole refurbish new tv Tuner signal board only now.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish main board tv Tuner signal board for the replacement.
Aug 30, 2011 | LG 47LE5500 TV
What brand USB Wireless Adaptor will work with my LG TV
Any brand of USB Wireless Adapter will work. Netgear, Linksys, etc
Apr 08, 2010 | LG 37LC7D 37 in. LCD HDTV
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
LCT3201AD will not turn on . The red light flickers but wont come on
open up the tv and look at the power supply. On my tv there where a couple of capacitors that where bad. They most likely have a bulging top all you have to do is replace them and everything should work fine. cost me about $5
Jun 12, 2009 | Akai LCT3201AD 32 in. LCD Television
Need a replacement battery
I am a lg dealer for my home Theater business. I am going to check with my manufacturer for one, I think you responded to someone else that you have the software for this TV, could I get a copy of it?
Mar 12, 2009 | LG 15LW1R 15 in. LCD Television
TV's on. No Picture...No Sound
Have a problem with Zenith 37 HDTV. Medel number: Z37LZ5D As wathcing TV, along with 'pop' sound, TV went dead. LG service center gave an advice to unplug the power cord and press ON/OFF power switch about 1 min. Then plug power back and turn on the TV. Well, the green light blink for a while and solid green, but still no screen, no audio. Search the Web and someone suggested to replace Power Supply Board which will fix the problem. Again, search the Web and came out with Power Supply Board. LG Electronics/Zenith 'Power Supply Assembl' with $124.95 from PartStore.com. Is it the right solution? Do I have to replace entire Assembly Board? not just replacing some fuse? Any cheaper way to do? If I have to replce PSA board, any suggestion to how? Comment posted on Apr 22, 2009 I have a basic knowledge of electric and electronics, such as rewiring entire house for renovation and assemble entire computer from scratch.
Actually, the TV belongs to my father and the problem that I stated was based on what he told me.
So the question is based on the symptom that I posted, how sure are you that the problem is the Power Supply Board?
Is it good to order PSB? Comment posted on Apr 23, 2009 Purchased 2 and half years ago. Expired one year warranty. Comment posted on Apr 23, 2009 Zohail,
This is LCD TV.
There is no problem with the wall socket nor current.
I put other appliances on same wall socket and worked.
It has to be internal problem.
As I mentioned on the main post, there was a 'pop' sound while watching and TV went dead.
Turn on remote control, there is blink green light and then green stays on, but no sound, no screen.
Turn off remote control, light turns red. Comment posted on May 14, 2009 I fixed the TV.
Orderd power supply board which cost me $136.51 total.
Replacing was simple.
Just removed the rear panel cover then electronic board housing cover.
Took power supply board with all the connector cables and replaced with new one.
Problem was a transformer connector which got burned and blow up the plastic cover.
But no problem with fuse and capacitors.
Thanks all for advises.
Jan 01, 2008 | Zenith Z37LZ5D 37 in. LCD TV
Open Questions:
See all LG 47LE5500 TV Questions
LG 47LE5500 TV Logo
56 people viewed this question
