Question about Dewalt D24000S Wet Saw With Stand
Ho do i remove the blade guard - Dewalt D24000S Wet Saw With Stand
Replacing blade guard on a 1700W sliding mitre saw
There is an upper (fixed) blade guard and a lower (moving) blade guard which has the added complication of being connected to a linkage or mechanism to swivel the guard away from the workpiece as it approaches the cut.
Mostly careful inspection, once the blade has been removed, will show removal of the guards to be a faily intuitive process. It is inevitable some makes of saw will be more complex and in the absence of official detailed instructions, it will mean a process of removing clips and screws until the part falls off and then remembering what you did so you can put it back together with no parts left over.
Jun 12, 2016 | Saws
B & D #3051 worm drive saw: How do I access the return spring for blade guard?
Link,
Usually you will have to remove the blade guard to get access to that. There is usually a rubber stop with a screw going through it that you will have to remove, and a spiral spring clip on the inside of the hub of the blade guard that will also have to be removed and then you should be able to lift the blade guard off the saw. The spring will hook around the blade guard and the other end will hook to the saw housing. Hope this helps!
Apr 22, 2015 | Saws
Lasko table fan model 4916 , I would like to know how to take it apart to clean it.
Kevin-
LASKO's typically have latches or clips that hold the front fan guard to the back fan guard.
Flip latches or carefully remove the plastic clips. This will reveal the 'nut' that secures the fan 'blade assembly'. Note, the nut has 'lefthand' thread so to remove it, turn it clockwise to remove.
The fan blade assembly can be pulled / wiggled free.
The fan blade assembly can be washed with water / wiped with a cloth.
Another nut (righthand thread) secures the back half of the fan guard, remove it and remove the guard.
That should do it.
Dec 18, 2014 | Dryers
How to reinstall saw guard on Mac Allister MAC185LS?
Never heard of this brand of saw. A Google search indicates that MacAllister only makes big earth moving equipment. Otherwise, most saws have an appropriate washer and retaining clip that holds the guard on. And you'll need the original spring to return the guard to the closed position every time you use it. Then there are two shaped washers that fit on the armature that have a 5/8" shoulder to fit a normal saw blade. Finally there is the nut that holds everything on. Hope you didn't lose all these parts. If you did, go to eReplacementparts.com and and enter your make and model. If they don't have what you need you might be plum out of luck. But a new saw.
Oct 03, 2014 | Saws
Why is my blade hitting the blade guard
Hard to say without seeing it but....wrong sized blade, bent blade, clamp missing or installed wrong, bent guard, or bent blade shaft. I'd look in that order. Hope that helps.
Jul 26, 2014 | Skilsaw 5150 Circular Saws
How to remove guard and blade on LS1013
Theres a nut on the guard you need to loosen. Guard will then open enough to change blade. if you want to remove it completely theres a phillips srew you also need to remove.
Jan 24, 2011 | Makita 10" Miter Saw LS1030N
Can't find my owners manual. How do I change the blade. Bolt hits on a guard that covers the arbor. On a DW713 combination saw.
Removing the Blade
1. Unplug the saw.
2. Raise the arm to the upper position and raise the lower guard as far as possible.
3. Loosen, but do not remove guard bracket screw until the bracket can be raised far
enough to access the blade screw. Lower guard will remain raised due to the position
of the guard bracket screw.
4. Depress the spindle lock button (Fig. 3) while carefully rotating the saw blade by hand
until the lock engages
5. Keeping the button depressed, use the other hand and
the wrench provided to loosen the blade screw. (Turn
clockwise, left-hand threads.)
6. Remove the blade screw, outer blade clamp, and
blade. The inner blade clamp may be left on the
spindle.
Installing a Blade
1. Unplug the saw.
2. With the arm raised, the lower guard held open and the
guard bracket, place the blade on the spindle against
the inner blade clamp with the teeth at the bottom of
the blade pointing toward the back of the saw.
3. Assemble the outer blade clamp onto the spindle.
4. Install the blade screw and, engaging the spindle lock,
tighten the screw firmly with wrench provided. (Turn
counterclockwise, left-hand threads.)
5. Return the guard bracket to its original position and
firmly tighten the guard bracket screw to hold bracket
in place.
WARNING:
• The guard bracket must be returned
to its original position and the
screw tightened before activating
the saw.
• Failure to do so may allow the guard
to contact the spinning saw blade
resulting in damage to the saw and
severe personal injury
you can download a manual at: http://www.dewalt.com/tools/machinery-miter-saws-dw713.aspx
Jul 20, 2010 | Garden
Circular saw blade rubs on the guard
remove the blade and check for the inner flange that should be behind blade. also there might be a ring underneath the inndr flange. or check to make sure the flange is installed correctly.
Apr 05, 2010 | Ryobi Saws
How do I remove the guard?
Lift the guard up and you will see a nut holding the blade. You should not have to remove guard to change blade. Make sure unit is unplugged before working on it.
Dec 24, 2008 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Andis masters are chewing my guards
Stop using speedo guards and get yourself an oster 76 and all the blades.
Aug 16, 2007 | Andis 01690 Hair Trimmer
Dewalt D24000S Wet Saw With Stand Logo
Top Dewalt Saws Experts
JOHN LAPIER
ken skalski
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
