Question about ION Block Rocker
Sound cutting out
My block rocker cuts in and out with the volume under half way up
Are the slide outs on a montana rv made to slide out futher than normal for replacing the main floor under it?
In some cases they will slide out far enough to repair the floor but you need to be extremely careful to prevent damage and personal injury. *I am not responsible for any damage or injury caused during repairs based on this free advice* First, you will need to remove the inside fascia, then un-staple the rubber seal all the way around and then remove the inside frame that the fascia screwed to so that the slide will go out of the opening. Next you will need to start opening the slide. Right before it clears the opening you will need to go underneath and insert blocks of wood between the floor of the slide and the frame of the slide rack and pinion to keep the slide lifted in the proper location for re-installation. now move the slide out just far enough to clear the side wall of the unit. Once it is clear of the side wall place a few saw horses and or jack stands under the outside edge of the slide to add more support. Now that you are clear you can begin the process of replacing the damaged floor. Start by pulling the carpet/linoleum back. The flooring will only be stapled down so once you remove the staples it should peel back pretty easily. Once you get to a wall you will have to cut along the edge of the wall for the flooring to release (since the flooring was installed first then the walls this will be necessary). When you are ready to reinstall you will have to use some 1/4 round trim to resecure. Once the flooring is peeled back determine how much floor will need to be replaced and mark your cut points and set your saw blade cut depth to 3/4" (you do not want to cut too deep) and make your cuts. Remove the damaged floor. Now cut some scab blocks to insert along the cut edges to where half of the block surface in under the existing floor and the other half will be under the new floor. Cut a new piece of decking and install. To install the blocks and the new deck I use wood glue and screws. If you are using linoleum flooring you may need to fill the crack and sand the floor so that the seam does not show over time. Reverse the process for installing the slide out. Good luck!
Oct 09, 2014 | RVs
Deh-x6500bt cuts out at high volumn
I have the same problem, it's only when the bass comes in, and it starts to cut at half volume.
My wiring is correct and every possible problem to do with the car and its wiring have been eliminated.
-Apart from plugging the unit into another vehicles loom.
Jun 29, 2013 | Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth...
My Brand new Stihl ts420 cut saw wont run full throtle, smokes white, and leaks fuel out of exhaust filter. it runs like the choke is half on.
This sounds like the carb is flooding, there is a rubber tipped needle under the metering side of the carb, this may be leaking, before replacing the needle make sure the air filter is not blocked, replace with a new filter and try again
Dec 14, 2011 | Stihl Ts 410 420 Cut Off Saw...
I have a power acoustik ibm12000d amp had it installed to weeks ago wired at one ohm to a 15inch acoustik p3 sub worked good for to weeks hit good and everything but now its cutting off when turned up I...
Sounds like an over current condition. Your sub may be the problem. Does it go into protect mode when it cuts out? remove the sub and turn up the volume and see if it cuts out when you keep increasing the volume. If not, then it may be that the sub shorts out when turned up too much, kicking the amp into protect mode. If it still cuts out, then it may be the amp. Try another sub if you have one or borrow one from a friend.
Aug 06, 2011 | Power Acoustik OVN1-2000D 1-Channel Car...
Stereo cuts out at half volume.
You don't exactly define what "cuts out" means.... silence, protection or power off?
What makes you think it's thermal in nature?
Have you considered the speaker load impedance may be too low for the amp?
May 02, 2010 | Audio Players & Recorders
Sound system skips out when the bass hits or the trble gets too high at a certain degree of volume and the dash sometimes cuts out or doesn't come on, i have to hit the dash in the right spot with the...
There is a loose/damaged/corroded ground connection -- sounds like it's under the dash.
But, I would check the battery cables and the chasis ground strap as well. The chasis ground strap is usually near the bottom of the engine compartment -- it's a braided cable running rom the engine block to the chasis.
Charlie
Aug 16, 2009 | 1998 Dodge Caravan
Volume on jvc home stereo receiver cuts off at a certain level
I had the same problem and found that when I moved the speakers apart further...It works as well as it always did before my 8 speakers were introduced..I think the sound was interfering with itself.. Try it !!
Jan 18, 2009 | Audio Players & Recorders
ION Block Rocker Logo
97 people viewed this question
Top ION Audio Players & Recorders Experts
Jay Plesset
richie46
Erin Wood
Erin Wood
Are you an ION Audio Player and Recorder Expert? Answer questions, earn points and help others
