Question about Sakar Talking Caller-ID Speaker Phone
Manual for ht555id
Need to set speed dial
Speed dial option in Karbonn K451+ Gold champ
Hi Nilesh, the user's manual says, quote: "Speed dial: If you already set the speed dial numbers, then you can long press number key 2 to 9 to dial set numbers out under the standby mode.Long pressing number key 1 is to dial to voice mailbox if you already set the mailbox number." So it looks like you need to add the speed dial option in your chosen contacts details, first. Then follow the quote above. Good luck!
Dec 19, 2014 | Cell Phones
How to change the shutter speed on my nikon n65 film 35mm slr camera
In the manual and shutter-priority modes (set the dial to "M" or "S"), turn the command dial to change the shutter speed. In the aperture-priority mode (set the dial to "A"), turning the command dial changes the aperture and the camera will set the shutter speed appropriately.
If you need a manual, you may download a copy from here.
Oct 13, 2012 | Nikon N65 35mm SLR Camera
How do you set the aperture and shutter speed independently
First, make sure you're in the manual exposure mode, not manual focus mode, as set by turning the mode dial to the "M" position.
In manual exposure mode, turning the main command dial should change the aperture, while turning the subcommand dial should change the shutter speed.
If the two command dials don't have the expected effect, reply to this post and we can troubleshoot further.
Feb 20, 2012 | Olympus E-1 Digital Camera
Setting up speed dial numbers and groups
I found the manual on-line and printed out the part I needed.
Nov 04, 2009 | Brother MFC-8220 Fax
CECT KA08-how to set up speed dial?
Follow the following:
>Call Center at the bottom
>General call settings
>03 Speed dial
>Check that "enable speed dial" is on
Then
>02 Set number
>You will see a list of "empty"
>Touch on the one you want to assign a number
>Edit
>this takes you to your phone book
>Choose a name from your list and save it to your speed dial.
>To call the number from your speed dial list, click on the "Phone dial" icon, and hold the number down. For example, is the number 2 is home, hold 2 down until you see it dial and there you have it.
Hopes this helps
Jul 29, 2009 | Dual Electronics CECT P168 Cellular Phone
Clear speed dial/one touch settings
There is no way to clear the settings you would have to re-program the correct setting. Did you program one touch speed dial on the line buttons? I do not see how programming a speed dial could effect accessing the CO lines unless you re-programmed the CO line buttons by mistake. If so, you would need to re-program those soft keys to line buttons. The manual you have may not cover this? The phone you have can work on a few different Panasonic phone systems. If you need a more detailed manual you will first need to know which Panasonic phone system you have. The phone part number WILL NOT help you determine which phone system you have. There is a main control unit somewhere (basement, utility closet, etc..)
Aug 13, 2007 | Panasonic KX-T7431 Corded Phone
Slow shutter speed
from the manual: Using Shutter-Priority Mode 1. Set the mode dial to S (shutter-priority) and a yellow arrowhead on the screen points to the current shutter speed. Press the jog dial and the current shutter speed turns yellow. 2. With the current shutter speed displayed in yellow, rotate the jog dial to select the speed you want to use. 3. Take the picture. If a workable aperture isn?t available for the shutter speed you?ve selected, the shutter speed indicator on the screen flashes when you press the shutter button halfway down. You can use the setting as is, or press the jog dial down to select the shutter speed again and rotate it to select a new shutter speed.
Jun 03, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
Pre-set dial numbers
Pick up the handset / handsfree button, hit the SET/SAVE key, punch in the entire phone number you wish to program to speed-dial, hit the SET/SAVE key again, hit the speed dial key you want to save to (0-9). To actually use the speed-dial key once set, you have to pick up the handset / handsfree, hit the AC key followed by your speed dial (0-9) I know this seems unusual and you have to do it relatively quick, but it's the only way that works properly on this phone unit. Cheers!
Mar 31, 2007 | Innovage 69420210126 Phone
Sakar Talking Caller-ID Speaker Phone Logo
15 people viewed this question
Top Sakar Lands Phones Experts
Aaron Venable
Level 1 Expert
Computer Repairing
Computer Repairing
Are you a Sakar Lands Phone Expert? Answer questions, earn points and help others
