Question about Plantronics Voyager Legend
Low voice volume
People are having trouble hearing me
I can't hear peoples voices when they call. The volume only works for the ringer
If you want to change volume of the caller's voice, then try adjusting the volume control WHILE you are actually talking on the phone during a call.
If you try to adjust the volume when there is no call in progress, then the volume controls will only change the ringer volume.
If you provide the exact model number of your particular device, then we may also be able to provide you with the User's Manual for your phone.
I hope that was helpful Loli.
Good luck and take care.
Joe.
Dec 09, 2011 | Apple iPhone Smartphone
I can hear callers but they cannot hear me. Mute is not engaged,
Please see the link below for the User's Guide.
• Headset is muted. Long press (3 sec.) the volume down button on headset to unmute the microphone. See page 16.
• Improper positioning of voice tube. Try various other positions.
• Voice tube may be clogged. Remove voice tube and test to see if callers can hear you without it. If they can, then replace the clogged voice tube. See page 18.
• Speaking volume is too low. Increase the speaking volume by
adjusting the speaking volume minor adjust buttons on the base unit as described on page 16. If the volume is still too low, select another speaking volume major adjust setting as described on page 16.
• Incorrect configuration dial setting for your phone. Try other
phone configuration dial settings on the base unit. Ensure the
selected number is in line with the position indicator. See page 14.
Plantronics CS70 User's Guide
Good luck from Headsets Direct!
Jul 18, 2011 | Plantronics CS70 Wireless Headset
My new Nokia C1-01 is very low on caller volume. I can hardly hear my callers properly. How do I increase the volume so that I can hear my callers properly.
oh! your problem is voice of volume. my dear user make sure your volume button and increase your volume voice.this type problem is creates when we are listen a song at low volume voice and forget to increase volume.
Jul 04, 2011 | Nokia C101 Cell Phone
E72 incoming voice is too low to hear .
When you are talking to someone, you can increase or decrease the incoming voice through Volume key. Press the volume Up to increase volume.
Remember volume will increase or decrease only if you ore on a call.
May 31, 2011 | Nokia E72 Smartphone
It is very low voice to other people
Just increase the volume of your phone, because you are probably clearly hear them speak but the tone of your phone is low,that is why they cant hear your clearly as you might expect.
Check on the phone tone/volume.
Dec 11, 2010 | Cell Phones
VOICE TOO LOW
When you talk on you phone make sure your volume label is up. There is a key in right hand site on top. Press up / down for adjusting the volume. if you seen the volume label is fully up but nothing to be change in voice, its mean the internal speaker is damaged. Replace it. And about your voice is not loud from other side then replace that microphone also. I think that's a common problem of Nokia N73 mobiles.
Thanks
Jan 24, 2010 | Nokia N73 Music Edition Smartphone
Not able to hear caller voice , ringer volume is low
You can use a program to edit the mp3 file on your computer to make it louder.
To edit the volume of the mp3 file on your computer, download Goldwave for free from here: http://www.download.com/GoldWave/3000-21… then open your mp3 file in Goldwave. On the toolbar there should be a volume knob, the one that doesn't have any arrows on it. Click that button then go to presets and chose either 150% or Double. After chosing one click ok, let Goldwave perform the change, then save it and reload it onto your phone.
Aug 10, 2009 | Cell Phones
The voice on my tomtomone is very low and you can't hear it when driving
Assuming you have a TOMTOM Go.
The volume is on the touch screen. You have to tap about 1/8 of the way up the screen from the botton.
A slide volume should come on the screen.
Regards and hope this helps...
James
May 28, 2009 | Tomtom ONE 3rd Edition GPS
No voice heard
There is a volume control on the right side of the gps. You may have just accidentally turned the volume down too low to hear.
Aug 12, 2008 | Garmin StreetPilot C330 GPS Receiver
Plantronics Voyager Legend Logo
15 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
