Question about Sony CDP-CE375 5-Disc CD Changer
My disc player keeps going to loading to disc 1-2-3-4-5 and no disc are in 2-5 but only in 1
I've got a 2001 Honda Accord with the 6 disc cd player that is not working
Removing the cd you might have busted the load arm or spring that is why it would not eject, best to get replacement from junk yard, the usually give you thirty day warranty
Mar 07, 2014 | Vehicle Parts & Accessories
My dvd player will not load disc and keep saying disc era
it has lense problem.
1) clean the lense with toner or lense dirt remover
2) other wise you have to change the lense
Jan 19, 2012 | Lanzar SD75MU Car Video Player
I don't know if my first REQUEST for Assistance was received, at any case, I REQUESTED to find WHY my GO.VIDEO COMBO Player is NOT READING any of my blank DVD DISC( SONY, IMATION, MEMOREX, DVD+R ), IT KEEP...
If there is nothing on the disc, it will read, "no disc". It will only read and/or identify discs with media loaded or burned onto it. Your unit is a player, not a DVD+R (recorder). Can record VHS, but not discs.
Jun 30, 2010 | GoVideo Go Video DVD/VCR Combo
When I put in a disc it says it's loading; however, it keeps showing "no disc".
when I put in a disc it says it's loading, however it keeps showing "no disc"
Oct 27, 2009 | Mintek MDP-1760 Portable DVD Player
Doesn't recognize the disc
Hi
they have three method to fix this problem..
1. Check the Flex ribbon wire, or replace a new one then test run! if the tes run is same go to next method.
2. replace the pick up lens carefully then test run if the test run is the same go to next method.
3. replace the motherboard.
Note: check first the ribbon wire, and please be carefull replacing the lens.
Thanks!
Jun 06, 2009 | GPX PD708B Portable DVD Player
Player justs keeps saying "bad disc" !!
clean your dvd lens with dvd disc cleaner.
May 30, 2009 | Cyberhome CH-DVD 300 DVD Player
Disc not loading
You're going to have to switch off the unit and turn it back on to make it stop. the disk is either badly damaged or the infra red in the remote isn't responding to the dvd player vice versa. hope i managed to help. goodluck. PS also clean the lens of the player as dust causes disk loading probs aswell
Mar 30, 2009 | Televison & Video
WHEN DVD IS PLACED IN MACHINE IT KEEPS TRYING TO LOAD BUT NO PLAY
yes that is very possible. cleaning the lens of the dvd player should happen atleast once a month. it can also be that the lens itself is scratched or the lase does not reach the disk tracks due to dust or bad handling
Mar 29, 2009 | Toshiba SD-5000
Sony CDP-CE375 5-Disc CD Changer Logo
49 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
