Question about NetGear N750 Wireless Dual Band Gigabit Router WNDR4000
Wndr4000 bricked after bad flash
Soft bricked gtn7000b
"DON'T" use Odin for B15. Use MtkFlashTool or SP-FlashTool.
On XDA Developers you can find the Stock-ROM files incl Boot.img, Recovery and ...!
Read manual carefully and "never never" flash Preloader or DSP_BL except your Preloader is already bricked! In that case you've gotta be really careful not to flash a wrong one. (Phone went Dead and maybe 4 ever)
better try about warranty
Feb 13, 2014 | Cameras
Setup wndr4000 as wireless access point
You need to read the router set up in the manual for a cable modem.
You need to check that the device IP ranges are the same.
There is not a disconnection of the DHCP server in the router listed, but there is some advice on setting up the router as a wireless extender which might be useful.
http://www.downloads.netgear.com/files/GDC/WNDR4000/WNDR4000_UM_06May2013.pdf
Feb 02, 2014 | NetGear N750 Wireless Dual Band Gigabit...
Where do i enter pin for wps on my netgear router wndr4000
Do you want to enter login password?
if yes, then put your IP address in your browser (192.168.0.1) press enter and login with username and password.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Feb 28, 2013 | NetGear N750 Wireless Dual Band Gigabit...
MY LINSKYS e3000 ROUTER
Bricked. Bad Firmware.
http://www.savemondo.com/2008/11/21/how-to-unbrick-a-linksys-router/
Jul 24, 2012 | Linksys Computers & Internet
Acer aspire 1710 msi laptop makes popping sound when turned on won't start
Popping sounds are bad. Usually shorting electrical somewhere. Is the light on the power brick green? flashing? Red?
It's either a bad power brick or a bad connection in the laptop. You can buy a power brick fairly cheap, but if its out of warranty and the problem is not in the brick its probably not worth it to fix.
Jun 28, 2011 | Acer Aspire 1710 Notebook
When I power up my router I get 5 lights , nothing for a power light . Should there be a light on for that ? How many lights should be on total ?
It sounds like a bad flash attempt has bricked the unit (made it as useful as a brick)
It can be revived, but you need a copy of the original firmware and a piece of hardware called a JTAG to flash the nvram in the unit and revive it.
If you google linksys jtag ebay you can usually find this hardware for under $10.
Some computer stores will also do this for you for a nominal fee.
Here's a great little video of the process.
Best of luck!
Mar 21, 2011 | Linksys Wireless-G Broadband Router
I had a bad flash of the firmware for this TV?
Same exact thing happened to me. Can't believe they would post a firmware update that bricks the TV.
Mar 29, 2010 | Samsung LN-T2342H 23 in. LCD HDTV
I HAVE A HP 530 LAPTOP AND THE BATTERY HAS DRAINED AND THE CHARGER DOES NOT SEEM TO BE RECHARGING IT. WHEN THE CHARGER IS PLUGGED IN THERE IS A GREEN LIGHT ON THE OILLUMINATED ON THE FRONT OF LAPTOP...
It's either a bad power brick or a bad system board. The easiest way to tell is to try a different power brick if you can borrow or buy one.
Sep 20, 2009 | Computers & Internet
NetGear N750 Wireless Dual Band Gigabit Router WNDR4000 Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
