Question about Dimplex Compact Electric Flame Stove Heater
Model DS5629 Changing bulbs
Model DS5629 Manual says to change bulbs from inside unit but no diagram. Says to unscrew center screw holding logs....can't find it. hELP
How do I replace bulbs on model DS5603 Mod G electric fireplace
Do you need to replace the upper or lower light bulbs?
For both, first open the door of the fireplace. For the upper light, locate the upper bulb bracket (above the door). Bend the bracket down. Unscrew the old bulb and replace it with 7 W clear chandelier or candelabra bulb with an E12 base. Bend the bracket back up to its original position. Close the door, if only the upper bulb is out.
You will need a Phillips blade screwdriver to replace lower bulbs. Open the door (if it wasn't already open). Locate the screw that holds the log set in the center of the ember bed. Remove that screw and the log set. Locate the bulbs that are behind the log set and determine if one or both bulbs need to be replaced. Unscrew the bulb(s) to be replaced. Screw in the replacement 60 W clear chandelier or candelabra bulb with the E12 base. Replace the log set and press firmly against the glass. Replace the screw that holds the log set. Close the fireplace door.
The procedure to replace the bulbs is on page 4 of the service manual. It is also on pages 10-11 of the Owner's Manual. The documentation is available from Dimplex: http://www.dimplex.com/en/customer_support/technical_and_troubleshooting . The direct link to the service manual is http://www.dimplex.com/cms/publications/7400650000R04.pdf . The Owner's manual is here: http://www.dimplex.com/cms/publications/7206570100R09.pdf .
I hope this helps.
Jan 12, 2017 | Heating & Cooling
Headlight changing
please use chelton manual for getting instructions with diagrams.
remove the side screws and then remove the rim of the light
now you can access the lights
Oct 17, 2008 | 1992 Toyota Celica
Surface Light Bulb burned out where can I purchase new one. Model ge #JVM230BL001 Spacemaker
most hardware stores/home centers carry them,you will need to unplug the unit and you should be able to access the lamp and unscrew it from inside the cooking chamber near the top of the cavity,you may need to remove a screw holding the cover first
Jun 25, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Picture went black. where do i find the lamp. i do not have a manual
Pop the front cover off. There is a built-in screw left of center that holds a door on. Unscrew that and remove the cover. Inside, you will see another screw on the right side. Unscrew that (it stays with the housing unit) and pull the handle to remove the lamp housing unit.
Oct 16, 2009 | Panasonic PT-50LC13 50" Rear Projection...
How difficult is changing brake light on 2004 Envoy?
Hi. Its quite easy and i have a guide that will help you achieve your goal.
Step1 Determine how the bulb is accessed: On some models the lens (the red or white plastic part over the light) must be unscrewed from the outside, and on others the bulb is accessible only from inside the trunk. If there are no screws on the lens, you can assume that the bulb must be replaced from inside. Usually there will be a plastic cover that must be removed in order to access the bulb. There may be tabs, screws or small knobs that hold this plastic cover in place. Step2 replacelight_2s.jpg Unscrew the lens on the outside, or take off the plastic cover from inside the trunk, to reveal the bulb. Step3 replacelight_3s.jpg Unscrew the bulb. You'll have to push in and turn at the same time. Step4 Take the bulb with you to the auto supply store to help you find an exact duplicate. Step5 replacelight_5s.jpg Clean the connection with a wire brush and/or wipe it clean with a rag if there's any corrosion. Step6 replacelight_6s.jpg Screw the new bulb into the empty socket. Again, you'll have to push in and turn simultaneously. Line up the tiny raised bumps on the base of the bulb in order to screw it in. Step7 Replace the lens or the plastic cover. Step8 replacelight_8s.jpg Test your work by stepping on the brakes and turning on the headlights while a friend watches the new bulb to make sure it lights up.
Please rate and god bless.
Mar 26, 2009 | 2004 GMC Envoy
How to Change the taillight bulb 2002 Aerio standard model
You have to unscrew one or two screws (don't remember) to remove the whole light assembly (need the hatch or trunk open to access screws). The solution is work from outside the car not inside.
Nov 16, 2008 | 2002 Suzuki Aerio
Changing interior light bulb in Whirlpool Frost Free 350,390 or 460 (per manual)
Hello davvyde,
Welcome,
You said, you have removed plastic cover for light bulb, as per manual supplied, but I cannot fit my fingers around light bulb to unscrew it. Is it clockwise or anti-clockwise and does the bulb actually screw into the white bayonet, or is that part of the overall bulb-structure? Not enough space to screw anything! Incidentally, I have a small hand and therefore small fingers.
What is the model number of your appliance.
Is the bulb intact or did the glass part come off and leave the metal base inside?
IF YOU HAVE A PROBLEM TURNING OR GETTING THE BULB OUT, BEFORE YOU US ANY THING OTHER THAN YOUR HANDS, UNPLUG THE FRIDGE!
  1. Whirlpool bulbs screw out counter in the counter clockwise position.
  2. If it is screwed in very tight try a rag, or towel in your hand.
  3. Or you may try a rubber glove which causes friction and may give you a better grip.
  4. Turn off the fridge for a moment while you do this, in case the bulb breaks in your hand
  5. If the bulb comes apart from the metal base, (AND YOU HAVE THE PLUG OUT OF THE OUTLET) You may be able to gently use a needle nose pliers, to little by little loosen the bulb up if it is stuck
I've never seen this before in a fridge.
Let me know what works?
Huuum
Please remember to leave a rating!!!!
Oct 14, 2008 | Whirlpool Refrigerators
Changing light bulb in a 25 year old freezer
Whatever you do, you MUST unplug the freezer before attempting any repairs... there will not be any release buttons, nor any special installations for water safety... also, take care to avoid cutting yourself on the broken glass..
1) did the whole light bulb glass And internals come out, or is the internal part of the bulb still present?
2) verify that the light bulb is really a screw-in appliance bulb -- look into the center of the broken bulb and see if the metal base has internal ridges -- or if the metal base is smooth on the inside...
3)  if a screw-in appliance bulb:  3a)  if the whole light bulb glass AND internals came out, you will have to probably look very close inside the socket to determine the wall of light bulb base... it should be very thin and flexible and very unlikely you can unscrew it directly -- I've had to take needle-nosed pliers and gently bend and twist until the bulb base came out...
3b)  if part of the glass remains as well as the internal stem, I have heard that one could cut a potato in half and then push the internal part of the potato onto the broken end of the bulb and gently unscrew the bulb by twisting the potato... never tried this so I don't know if it will work -- if the internal stem is still intact, I'd use my fingers and try to gently turn it to unscrew the bulb
4) if it has smooth inside wall -- this is probably a bulb with small exterior pins -- the base should be a little more thicker than the screw-in type, so you should be able to push the bulb base in -- a little give in the spring holding it in -- if you feel this give, then turn carefully counterclockwise and it should pop out...
Again, turn off all electrical power to the freezer, Pull the Plug before attempting any repairs... remove all glass and handle with care...
Jul 25, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
How to Change light bulb (yes, really...)
If yours is the same as the model 04890 that I looked up on the net, you will unscrew the center nut of the light fixture being carefull to not let the fixture drop to the floor. Once you have the center piece off you will be able to unscrew the bulbs and install new ones. Be carefull and be sure power is off before you do this.
Dec 29, 2007 | Dryers
Bulb replacement
NO,If you can get to the three phillips screws directly over the vent door then you do not have to take the unit down. Unplug the unit. Remove the top three screws over the center of the louvre and then carefully lower the vent louvre. (Lowering helps me get a better grip on the louvre assembly. Then you will slide the vent louvre assembly about 1/8" to the left and then it will pull straight back and out. In the center is an aluminum cover which has a phillips screw facing you. Remove this screw and the cover plate. The light bulb is directly to the left of the inside of the cover plate. You will see the metal tabs which hold it in place. Pull the bulb housing assembly straight out (to your right) as you face the microwave. Then you will locate your halogen 120V 20W bulb. I just received this from a fellow guest on fix it and I was able to fix my unit 10 mintes ago.Also another tip was to take the inside glass out when reinserting the bulb unit back in because it does get in the way. Good Luck
Aug 08, 2007 | GE JVM3670 Microwave Oven
Dimplex Compact Electric Flame Stove Heater Logo
22 people viewed this question
Top Dimplex Heating & Cooling Experts
paulcarew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
