Question about Ridgid 5" Random Orbit Sander R2600 - Variable Speed
Sander just stopped working
Sander was working fine shut it off to change disc and now it won't turn back on
How many Types of Power Sander?
Power sanders are really helpful tools that help the sanding job done in fewer minutes but usually takes hours by hand. The amount of effort requires while removing old peeling paint depends upon the type of sanders is used. If you pick a wrong tool, all your effort may go in vain. Different sanding machines have different specific utilities.
more details Category Sanders
Mar 14, 2018 | Tools & Hardware - Others
Change a disc on the 5" sander on the belt and disc sander item 10027
please be more specific!!
guessing - bench top disc/belt sanders' discs usually use stick on backed sand paper discs ;)
Jan 13, 2015 | Sander Tools & Hardware - Others
The edger runs when switched on but then shuts off when I start to sand with it. The brushes and switch have been changed on it.
check the belt and the pinion..had same problem...replaced the belt and the pinion drive, works fine
Dec 15, 2013 | Bona Edge XL Flooring Edger Sander
Ryobi belt and disc sander
It's only a month old. Take it back for a repair/replacement under warranty.
Jul 01, 2017 | Tools & Hardware - Others
Skill 7292 hand sander won't turn on
a lot of times sawdust gets into the switch contacts and won't allow the tool to operate. I would try turning the switch on/off several times and see if it temporarily helps. Also check the cord. Let me know if you need more assistance.
Feb 23, 2012 | Tools & Hardware - Others
I have a MS1000 Black and Decker Cyclone round sander..looking for replacement sanding disc
Hello, W/D here.
Most sanding disc types are available at the larger box hardware stores. They are (sometimes) generic or exact replacements.
I use the "Gator" brand on my B7D sander, and the discs work just fine.
Best regards, --W/D--
Feb 23, 2011 | Black & Decker Black And Decker Cyclone 4...
I am using a Model 343 type 2 Porter Cable random orbital sander. It worked just fine, I turned it off, and 20 minutes later it would not turn back on. No strange noises, smells, etc. it just wouldn't...
Plug in the sander, Turn it on and Wiggle the wire around the plug. If your sander jumps on and off your plug need to be replaced.This should be a easy fix if you are a bit mechanically inclined. If that doesn't work, get a ohm meter and see if your cord is hooped. If cord is fine then look at the brushes.
Jan 10, 2011 | Porter Cable Tools & Hardware - Others
Porter Cable 7800 Drywall Sander ran fine, stopped and ate supper, went back to work and motor will not come on. Vacuum is working fine but cannot get motor to turn on when flipping the switch. Did not get...
Sounds like a problem with the ON/OFF switch. Hit it with a bit of contact cleaner or WD40 and work it a dozen or so times, it may just be dirty...... at least if you are lucky.
Paul
Sep 18, 2010 | Black & Decker Black Decker/ Porter Cable...
Makita gv5000 5" disc sander won't work
there isn't an internal fuse. by the sounds of it you probably have a short, a bad brush, or some arcing.
if you use your sander for fine sanding (100+ grit paper) you have to make sure to clean out the motor housing. Fine sanding dust, like any fine dust, creates alot of heat when aerated and can melt the plastic brush holders or can cause the electricity to arc from one wire to another inside the housing.
my advice is to take the 8 (i think it's 8) screws out of the side of the gun and carefully pull the halves apart. there isnt alot you can mess up inside and just visually inspect the wires for burns or melting on the brush holder.
here's a breakdown if you need it.
http://www.makita.com/en-us/Assets/images/Products/_PartsBreakdowns/PB_GV5000.pdf
if you find something inside that you're not sure of, or if you have any additional info i'll keep checking in on this.
Dec 08, 2008 | Makita 5" Disc Sander GV5000
Ridgid 5" Random Orbit Sander R2600 - Variable Speed Logo
114 people viewed this question
Top Ridgid Tools & Hardware - Others Experts
R Daniel Wolfe
 perry tradesman    ...
perry tradesman ...
Level 1 Expert
Are you a Ridgid Tool and Hardware - Other Expert? Answer questions, earn points and help others
