Question about Home at Five Vertigenius Digital Rotisserie by Cuizen - Black
Vertigenius motor stopped working
Everything else seems to work but i cannot get motor to turn
I came home I did not hear the pump working so I pushed the button to turn on the jets and they seem to work fine, but when I shut the jets off everything shuts down. Just humming coming from motor.
That is a capacitor. Replace it. If it blows another or hums like that, then get a new motor. Also, see if the motor shaft turns freely.
Dec 28, 2016 | Pool & Spa
Wont start but there is power
FROM MY DEALING WITH CARS IN THE PAST IT SEEMS LIKE THE STARTER MOTOR.........IT HAS A SOLENOID ON IT AND IF THIS DOES NOT ENGAGE...YOUR STARTER MOTOR WILL NOT TURN.....
Apr 15, 2014 | 1992 Ford Bronco
My chrisler crossfire 2004 will not start,i already checked the rcm and the interlock switch by the clutch pedal but everything seems to work fine.by turning on the ignition all lights seems to work fine...
No get the immobilizer checked as the motor will crank untill the battery is flat as the ecm will not be getting the code to tell it to allow the motor to run
Aug 16, 2017 | Bosch 1985 - 1994 Classic Saab 900 Turbo...
Dryer drum won't turn everything else works including motor, belt seems OK
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 20, 2010 | Dryers
Kenmore dryer won't work upon restarting
Yeah, I would buy that new motor....
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 12, 2010 | Kenmore 73952 Gas Dryer
Usually a motor that runs for a short time and shuts off is a bad motor. Cleaning it will usually not help. Replacing the motor is the best solution. Hope this helps.
Mar 20, 2010 | Kenmore 73952 Gas Dryer
My LG dryer does not spin...everything gets hot and works except either it spins VERy slowly or not at all
Open the back to get to the motor and check to see if the belt is loose on the motor pulley. Try to turn the empty drum by hand--does it seem bound up? Turn the motor pulley, does it seem hard to turn? Maybe the motor pulley is loose on the motor shaft. Run the dryer for a short time to watch the action of the drive belt.
Sep 27, 2009 | LG DLE0332 Gas Dryer
The dryer drum won't turn. Everything else seems
If you can hear the motor running when it is turned on then you dryer needs a new belt. If you cannot hear the motor running it needs a new motor.
Apr 11, 2009 | Kenmore Dryers
Home at Five Vertigenius Digital Rotisserie by Cuizen - Black Logo
67 people viewed this question
Top Home at Five Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Home at Five Kitchen Appliances - Other Expert? Answer questions, earn points and help others
