Question about Hitachi Touro Computers & Internet
When I plug the drive into the computer, it is not seen by the computer. It just makes a clicking sound when powered on.
bob_computer
  • 3153 Answers
SOURCE: click-click sound
If you can hear clicking then I am afraid there is a serious problem with the hard drive.
The noise you can hear is usually known as "the click of death" when referring to hard drives.
Most common causes are that the drive unit was dropped or mishandled or just plain old age
There is no known cure unless the data is mission critical
In which case you could sent it to a data recovery specialist but this is usually VERY expensive.
If you are advised to place it in a freezer or anything similar then that is up to you
but my advise would be to run from the person who may give this advise.
This is very old fashioned advice and meant for very old types of drives that used to get very hot.
If it a drive that was / is from an external enclosure then you could still use the enclosure
and just place a new hard drive in there.
Posted on Aug 26, 2009
Testimonial: "not what i wanted to hear but thank you."
bob_computer
  • 3153 Answers
SOURCE: My drive has power but is making a clicking sound
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Hope this gives you the information you need
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Posted on Jan 21, 2010
  • 561 Answers
SOURCE: hard drive doesnt show up when plugged in
Hi
Thank you for your query
If the hard drive is making a knocking/clicking sound, then unfortunaltey its on its way out.
The read arm that reads the metal discs inside the drive is heating against the discs, thus causing the knocking sound
I would recommned that you replace the drive ASAP
I hope this helps
Posted on Mar 01, 2010
itchibahn
  • 54 Answers
SOURCE: Toshiba 160 GB usb hard drive, has clicking sound
Clicking sound is the motor trying to move the head. Unplug it and try gently tapping it from the side, it seem to help time to time with some drives. If that doesn't work, put it in a zip-lock bag and freeze it for 40 minutes and try again. If still doesn't come up, you're out of luck.
Posted on May 31, 2010
sfender713
  • 397 Answers
SOURCE: USModular Dragon Drive 2.5 just
The clicking sound you here is a sign the hard drive has physically crashed. If there is important data, consult a data recovery firm to try and retrieve what files they can- if there is modestly important data on the drive, try placing the drive in a freezer drive and place the bagged drive in the freezer for 48 hours. Once that is done, connect the drive- if it is recognized- BACK UP EVERYTHING YOU CAN. You will have only a limited time before the drive heats back up and likely recrashes the heads into the drive
Posted on Oct 07, 2010
No sound is coming out from the speakers an we only owned it for about 3 months.
Please check all the cords associated with the speakers (the one to the computer, the one to the power outlet, ect) and make sure they are all plugged in correctly. Next make sure you have turned the speakers on, I dont know how many times I have thought my speakers were bad and I had turned off the power to them. Next in the lower right corner there may be a speaker looking thing, double click it and make sure you are not muted (can also be found in control pannel (sound and audio devices). Next try in the control pannel, and sound and audio. Make sure the output is set properly. I have seen some computers set to a digital coax out, when plugged in with a standard mini jack. If this is the case change the digital coax to the analog mini jack. Also make sure that it is not selecting only the front port.
Hope one of these helps
Sep 01, 2011 | Cyber Acoustics CA-2014 Computer Speakers
I changed the hard drive , now when i plug the power back on theirs a clicking sound, i think its coming from the fan in the back because its moving and also when i hit the power button in the front of the...
If there was no clicking sound before and now there is after you installed a hard drive (goes click...click...click) then that is bad. A clicking sound is what you never want to hear from a hard drive. Means it's bad.
Fans don't make clicking sounds.
Aug 30, 2011 | Dell Dimension 2350 PC Desktop
My computer will not reconize the external hard drive. The red light is on and the blue light is blinking. Help!
Listen closely to the drive, if it sounds like it is clicking then it is probably not getting enough power through the usb. You should have received a cable with a split dual USB plug for extra power. Make sure that both large USB plugs are in the computer while the smaller one is attached to the drive, this will give it enough power to start working. If it is not clicking and has plenty of power then it could be that it is mapped to a drive letter that is already in use. Under device manager, (right click my computer and select manage then click on disk management) If you see the device in there then you can right click on the bar graph representation of the disk and select to change drive letter and paths. This will allow you to remove the conflict and have it show up again.
Jul 06, 2011 | SimpleTech 250GB USB2.0 7200 RPM External...
My WD250gb wont show up ? it is not working ?
Listen closely to the drive, if it sounds like it is clicking then it is probably not getting enough power through the USB. If you received a cable with a split dual USB plug for extra power. Make sure that both large USB plugs are in the computer while the smaller one is attached to the drive, this will give it enough power to start working. If it is not clicking and has plenty of power then it could be that it is mapped to a drive letter that is already in use. Under device manager, (right click my computer and select manage then click on disk management) If you see the device in there then you can right click on the bar graph representation of the disk and select to change drive letter and paths. This will allow you to remove the conflict and have it show up again.
Jul 06, 2011 | Western Digital WD Passport 250GB Portable...
I followed the instructions on the quick start sheet but do not see the simpletech external drive icon on my computer.
Listen closely to the drive, if it sounds like it is clicking then it is probably not getting enough power through the USB. If you received a cable with a split dual USB plug for extra power make sure that both large USB plugs are in the computer while the smaller one is attached to the drive, this will give it enough power to start working. If it is not clicking and has plenty of power then it could be that it is mapped to a drive letter that is already in use. Under device manager, (right click my computer and select manage then click on disk management) If you see the device in there then you can right click on the bar graph representation of the disk and select to change drive letter and paths. This will allow you to remove the conflict and have it show up again.
Jul 05, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
I am trying to do a back-up from my computer but the external hard drive does not appear on "my computer". when the external drive is connected to the external usb drives it makes a noise.
The cable coming off the hard drive should have two usb plugs. Make sure both are plugged into the computer so that the drive is getting enough power. If it's a laptop you are plugged into the same thing applies but also make sure that the AC Adapter is plugged into the laptop when you plug the external drive into the USB ports. Sometimes it won't power the drive if it's running off battery power.
Of course it could be a problem with the Hard Drive within the enclosure if it is a constant clicking. But it sounds like it could just be the USB port not powering the drive up.
You could try on another pc as well.
Jan 21, 2011 | Hitachi SimpleDrive Mini 250GB USB 20...
Seagate Barracuda ATA V 120GB. Using this as an internal storage drive (slave drive). Drive spins up but not seen in BIOS. Drive has clicking sounds every few seconds which sounds like the head searching....
It sounds like a problem with the card on the drive. You could try replace the card with one from an identical drive just to see the result you will get. I have read a lot about what they call "the click of death". So it could well be time for a new drive ckanca. The fact that the bios isnt detecting the drive points to the card. You sould also ensure there is no dirt on the cards contacts with the drive body (by removing the card and cleaning them aswell as ensuring they all make proper contact).
Dec 23, 2010 | Seagate Barracuda ATA V (ST360015A) 60 GB...
Brand new, not recognized by hardrive
Try plugging it into the back ports of your computer haven't already. The clicking is from the reading head not finding zero on the platter, which means its either a bad drive or a lack of power. So try the back ports first if you haven't already, because they usually supply more power than any front ports. It also depends on how old your computer is, but in general if it has XP on it it should have enough juice to power the drive.
Jun 25, 2010 | Hitachi SDM320BD 320 GB USB 20 Hard Drive
I have a smartdisk Fire Lite external harddrive - When I plug it into the usb hub the computer does not acknowledge it
Hello
If you power up the drive and you can feel that the drive is actually spinning, a periodic clicking noise is bad news.
Does the computer make a sound when you plug it in, or does it make a sound.
If the computer recognize when you plug it in, but it just not show in my computer, here is how you fix the problem. Go to:
control panel
Administrative tools
Computer management
Storage
Disc management
Now you should see your drive in the schematic below. Right click on it and choose the option to change drive letter or paths. Now just assign a new drive letter to the drive, restart your computer and it should work fine.
Best regards
Andrea
Nov 05, 2009 | Smartdisk - Peripherals - HARD DRIVE,...
I need help please
Did you tryed in another computer???Does it work???Try it and let me know for the successssss?
Jul 05, 2008 | Western Digital (WDXB1200BBRNN) 120 GB...
Computers & Internet Logo
19 people viewed this question
Top Hitachi Computers & Internet Experts
steve morris
steve morris
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
