Question about KitchenAid Cooktops
How to turn on andi stove - KitchenAid Cooktops
Boil element caught on fire and melted.
If element caught on fire, I would suspect stove needs cleaning. Do that then elements should not smoke for long. (I hope all moisture was removed from stove!!!)
Feb 11, 2014 | Kenmore Element Stove Burner Frigidaire,...
My maytag freestanding stove won't turn on. The clock works but the stove or oven won't turn on.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Sep 15, 2012 | Maytag Stove / Oven / Range Cooktop -...
Maytag accellis 2x stove won't heat-up, does power-up, light comes on but no heat
Buy a new stove element. If you open the stove look in the back. It should be black. It might have a crack or be clearly broken. This is a cheap fix. If you want to be sure that it is working at the connection unplug the element and pull it out. Put a volt meter into the prongs. Turn stove on and see if its putting out voltage.
Jun 02, 2012 | Maytag Stove / Oven / Range Cooktop -...
Just moved in, used stove for the first time, a little red light won't turn off.
You might need to turn off the stove entirely. If there is even one function slightly on, the red light may not turn off. Try unplugging the stove if you can't figure out why its not off still.
May 22, 2011 | Jenn-Air JED8345 Electric Cooktop
I have a Wolf gourmet 30" stove. it's about 10
Interesting, I'm looking for a solution to a similar issue. Our new (7 month old) 30'' Wolf Range has this issue. When both front burners are light, the back burner's electronic starter begins to click, but only when you put a pan on the front left burner. I believe the iron/steel in the pan is causing a magnetic field thats starting the rear burner to go off.. just don't know.. will report back after the repair person comes.
Jan 22, 2011 | Wolf Range 18 in. SPR-100 Gas Cooktop
I have a similar problem with my GE Profile stove
one of the ignitor switches is shorted out.sometimes it is moisture inside and it happens after boilover or spraying some liquid for cleaning.remove the knobs and try a hair dryer to dry them or leave the unit unplugged for some days.it should work fine after this ,if not then the bad switch needs to be replaced.always avoid boilovers and spraying any cleaning liquid for cleaning.
Aug 16, 2009 | GE 30 in. Profile JGP989 Gas Cooktop
I cannot adjust the temperature on the elements of my stove top.
Hello Skyemahan,
I work on stoves with various problems all the time, and have never encountered a problem exactly like yours. You may get other answers, but here's my two cents worth: When I don't trust a stove, I replace it. Period. Hopefully, your's is old and you're ready for a new one. A new stove is much cheaper than a house fire.
Best Regards, --WoobieDog--
Jul 10, 2009 | Cooktops
Stove keeps tripping fuse
when turning on stove, the current inrush is too great for the breaker. you need to look at the data plate on stove first to see if the current (amp) usage is greater than your breaker. If not, then you may have a faulty element or control
Jul 02, 2009 | Whirlpool 30 in. RC8700 Electric Cooktop
Holiday Stove Pilot Light won't stay lit.
Wow this problem sounds exactly like my landlords problem only he is just now saying he is learning of the problem. You even have the age of the stove correct.
Jun 16, 2009 | Cooktops
Cooktops Logo
60 people viewed this question
Top KitchenAid Cooktops Experts
Dale Copeland
Dale Copeland
davenpdx
freddyfox
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
