Question about NINJA 3l Deep Fryer
Ninja won't stay on - NINJA 3l Deep Fryer
My 2012 ninja 650 wont let me turn key to on position
Hi, Milad for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Key won turn to the on position
Ignition switch won turn ITS STUCK
Ignition key won turn on 2004 Ninja 250R motorcycles
http://mototh.com/files/kawasaki/Ninja-650R/Kawasaki-Ninja-650R-Service-Manual-EN.pdf
Nov 04, 2016 | 2012 kawasaki Ninja 650
Why wont my 09 ninja 650 run
Hi, Keith and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Fuel line to the carburetor or throttle body pinched or kinked.
8. Carburetor float stuck.
9. Fuel injectors clogged.
10. Severely discharged or damaged battery you need 12.5 volts or better and be able to pass a load test if necessary.
11. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
12. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and CDI box.
Spark plug cables in bad condition and shorting check for leakage in the dark, cable connections loose, or connected to the wrong cylinders.
13. Ignition timing incorrect due to a faulty MAP, CKP, O2, TPS, sensors.
14. Faulty neutral, clutch lever, or kickstand safety switch.
15. Faulty fuel pump or fuse or relay.
16. Faulty CDI box.
17. A stuck bent or burnt valve.
18. Tip over sensor needs a reset.
19. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2009 Ninja 650R Won Start Please Help
2009 Ninja 650R Won Start Please Help Kawasaki Forums Kawasaki Ninja 650R Service Manual
OEM Parts for Kawasaki
Kawasaki 2009 ER 6f Owner Manual
Apr 01, 2016 | 2012 kawasaki Ninja 650
I have a 2004 ninja 636 and it won't start unless
look at a electrical diagram,make sure there are not any other switches in the starting circuit. if there is ck. all of them for proper operation.
Jun 23, 2013 | Motorcycles
Zx6r 2004. Bike ran great for two months. Went out to dinner last night and came out to my bike not starting. Trailered it home, started when taking off trailer. Went for a 15 minute ride and parked it....
Hi, Matt it saddens me to inform you that you have to put on your Battery Priest Robe and prepare yourself for the Ceremonial "LOAD TEST" but before you begin, maintenance type batteries must be topped off with distilled Holy Water and all batteries must present their terminals to the battery charging altar to receive the electrical infusion of Holy Ions until they have reached a 100% full charge of 12.5 volts or better.
Below is a quick and easy test to see if your battery is in good condition or needs Last Rites and must be replaced.
1. Start by disconnecting the spark plug cables.
2. Adjust voltmeter to DC volts 20-volt range
3. Place the voltmeter leads to the battery terminals.
4. Turn the run/off switch to run.
5. Turn the ignition switch on and press the starter button.
6. Watch the voltmeter as your engine turns over for 15 seconds.
7. If the voltage drops below 9.5 volts, the battery is faulty and must be replaced.
ZX6R 636 Bike won start
Kawasaki NINJA ZX6R My bike won start Starter problem or discharged battery
Kawasaki Ninja ZX6R Service Manual
Kawasaki Ninja ZX 6R Owner Manual
How to Tell if Your Battery is Bad in 3 Easy Steps
May 18, 2017 | 2007 kawasaki Ninja ZX6R
I lost the keys to my 2005 ninja 250 and had to replace the ignition but i had to hot wire it to get it home I have since replaced the ignition and now it won't start I'm getting power to the
Check down by the battery and the fuse box area and make sure that all the fuses are good. It may have blown a fuse when you where hot wiring it.
Dec 15, 2012 | 2005 kawasaki Ninja 250 R
2004 Kawasaki ZZR250 will not idle without the choke on
Hi, Teresa26mill and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Bike won run without choke Kawasaki Forums
06 Ninja 250 won stay running unless choke is open
Kawasaki ZZ R250 Service Manual
2004 Kawasaki NINJA 250R Owner Manual
Nov 24, 2017 | 2004 kawasaki ZZR 250
My, 2008 kawasaki ninja 250, gas tank won't open. When I insert the key, it won't turn. I've pushed and fidgeted it as much as possible to the point before breaking the key in it. ...
Hey Simon,
I would haul it to a local (GOOD) locksmith, they will get it open..
Are you 110% SURE it the RIGHT key???
Good luck...
Jul 27, 2017 | 2008 kawasaki Ninja 250R
1997 Kawasaki ZX-6R Ninja speedometer not working
Hi, Radicaldave for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
07 ZX6R Speedo not working Stays at 0
HOW TO Speedometer Fix Kawasaki Ninja ZX6R
Kawasaki 1994 Ninja ZX 6R Service Manual
Kawasaki Ninja Owners Manuals
Aug 24, 2017 | 1997 kawasaki ZX-6R Ninja
I have a 2009 ninja 250r that i slid and i was wondering how much it would cost to get a turning signal fixed. the front right signal broke off and now the back signal only stays on not blinks when on
hi mate you can installl them your self the are held in by 2 bolts or a nut on the inside just unscrew that and disconnect the 2 wires also you can buy them cheap fom somewhere like ebay
Aug 26, 2009 | 2008 kawasaki Ninja 250R
NINJA 3l Deep Fryer Logo
47 people viewed this question
Top NINJA Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a NINJA Kitchen Appliances - Other Expert? Answer questions, earn points and help others
