Question about NEC AccuSync LCD72VX LCD Monitor
Accusync lcd72vx Monitor How do I change the resolution?
I don't have a manual and I can't find it scrolling through the controls
No sound
Posted on Jan 21, 2008
My Lcd monitor goes black when i turn it on. NEC AccuSync lcd72vx
Sorry the unit is dead and you will need to replace it. I would avoid NEC on the next purchase.
Nov 12, 2015 | Computers & Internet
Auto adjusting
This is normally caused when the monitor does not support the screen resolution the computer is set to. Change the screen resolution and see if that helps. Also, consider updating your graphics driver too.
Hope this helps
Steve
EmoticonIT com Computer Solutions Lincolnshire Joomla Websites IT...
Apr 30, 2014 | NEC AccuSync® LCD73V 17 inch Monitor
Touch screen
Does the touch screen work?
Oct 15, 2013 | NEC AccuSync LCD72VX LCD Monitor
How do I fix my screen from being blurry? I have an AccuSync LCD 72vw with AT&T services.
Hello: Try the following:
Signal cable should be completely attached to the computer.
Use the OSM Image Adjust controls to focus and adjust display by increasing or
decreasing the FINE control. When the display mode is changed, the OSM Image
Adjust settings may need to be readjusted.
Check the monitor and your display card with respect to compatibility
and recommended signal timings.
If your text is garbled, change the video mode to non-interlace and use 60Hz refresh rate.
Nov 19, 2009 | NEC AccuSync LCD71VM 17" LCD Monitor
My monitor only power 1 sec and next shutdown the led forever green
This is a common issue on LCD display caused by a short circuit in the inverter area. As soon the power supply detects the short circuit, it shut off the power to the display.
As user, there is nothing you can do. If you are planning to fix it (and have previous electronics repair experience) you may want to read how this type of displays can be fixed.
Do not try if you don't know anything about high voltage.
Nov 06, 2009 | NEC AccuSync LCD72VX LCD Monitor
Images appear stretched verticley. How can i adjust?
comtrol panel - display - settings - unclick "strech to fit"
Oct 08, 2009 | NEC-Mitsubishi AccuSync LCD72VX 17" LCD...
Resolution Notifier pops up every 30-45 seconds
Do you have an NEC display?
If so, it is part of the display's programs. Use the buttons on your monitor to select the "menu" then scroll to find "Resolution Message/Notification/Error" and disable or off.
This should do it.
Jul 19, 2008 | NEC-Mitsubishi AccuSync LCD72V 17" LCD...
NEC AccuSync 120 Frequency setting
This is the maximum resolution for this monitor:
1600 x 1200 / 76 Hz
Even if you lower the resolution to the monitor, as I can see that you want to do, the maximum refresh rate is still going to be 76 Hz. If you were able to force the monitor to scan a greater field rate and its protection circuits do not shut it down, the monitor will be damaged.
Your display card is most likely limited also, unless you went out and bought a very high end card.
When using a different resolution that what the specs on the monitor indicates as its native mode, this will reduce the quality of the results displayed.
Specs for this monitor:
http://www.superwarehouse.com/NEC_AccuSync_120-BK_Black_21_CRT_Monitor/AS120-BK/ps/120193
Jerry G.
Apr 24, 2008 | NEC-Mitsubishi Nec Display Solutions...
Nec flat screen goes blank after 20 seconds
i got the same prob.supposedly its the cap(capacitor) ,the one for the power suppy near the cord input.im getting my shit fixxed.and i will let you know.
Sep 24, 2007 | NEC AccuSync LCD72VX LCD Monitor
NEC AccuSync LCD72VX LCD Monitor Logo
278 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
