Question about Fisher and Paykel DG08 Electric Dryer
Squeals how to fix it?
Squeals when you use it maybe ball bearings front loader where can I find out where the part is so I can fix it myself.
Clutch squeals when pushed down
Your throwout bearing is likely failing. Your transmission will need to be removed to fix the problem.
Apr 17, 2014 | 2007 Kia Rio 5 Sx M/T Hatchback
Squealing when Brushes are moving
they have bearings at the ends of the brushbar it will be them that need changing
Feb 24, 2014 | Dyson DC17 replacement BELT GEARED DC-17...
Crosley cw5000w topload
the problem of this is the ball bearing need to change it.
Oct 03, 2013 | Washing Machines
Squeals during the washers spinning cycle
What model is it? The answer is probably both. Every machine I've worked on has a motor with a belt that drives a pulley that turns the tub held in place by bearings. Your squeal could certainly be caused by a bad belt. If the belt looks bad change it. If it looks okay, try a squirt of belt dressing, if the squeal disappears change the belt. If it is a front loader open the loading door, put one hand just inside the tub at the top (like a waiter carring a tray shoulder high with one hand) and LIGHTLY push upwards then drop your hand a little then push upwards etc., etc. If the whole tub moves solidly you are okay, but if you feel a wiggle or a slight space in the jump (man this is harder to explain than i thought it would be) then your bearings may need attention. I doubt it is your bearings causing the squeal though. Does it squeal through entire spin cycle, or just at the beginning?
Dec 30, 2012 | Washing Machines
An abnormal noise from the right front wheel
Have your mechanic test drive. Most common noises from front wheels on this vehicle are:
squeals- like an old door, usually related (but not limited to) ball joints
clicking in turns, usually related (but not limited to) worn cv axle
rotary vibration, usually related (but not limited to) worn wheel/hub bearing or differential
Aug 31, 2011 | 1998 Ford Explorer
Front of car squeals when turning .Feels like a tire was wobbly going on the highway. Real screachy sound ....any idea what may be going on it or possibilities ???
There are several possible causes, varying in severity, that could be responsible:
  • Lack of power steering fluid
  • Bad or worn serpentine belt - would slip when turning causing a squeal and/or difficulty steering
  • Bad wheel bearings - this would cause the wheel to wobble, and squeal on turns
  • Bad ball joint(s)
  • Bad steering box
Mar 24, 2011 | 2000 Hyundai Accent
Washer squeals during wash & rinse cycles.
It sounds like you're brake stator & rotor is worn and merit replacement, it would also be prudent to replace the thrust bearing as well since you'll be in the same area for the repair. The way to verify is to place the unit in spin & allow it to reach speed then open the lid. If it squeals then the repair would need to performed, if it does not then further troubleshooting would be needed. Hope this helps... Bill
May 29, 2009 | Maytag PAV2300 Top Load Washer
Squealing noise
possible causes are:
bra wire stuck in tub and rubs against the drum and squeals when on spin.
lip seal at front of bearings squealing - this is a difficult repair
Sep 02, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Fisher and Paykel DG08 Electric Dryer Logo
32 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
