Question about 5303L 2Way LCD Remote Start Security System
I changed the battery but the display still doesn't show anything. Does not work at all.
Display does not show any view
You know you can change the monitor brightness? Check the manual (eventually online) to see how to change the settings. Please check if you can playback pictures you already shot, to make sure the display still works.
You also could remove the battery, charge it and then replace it. This acts like a cold boot from a computer.
May 24, 2014 | Olympus FE-210 Digital Camera
Does anyone know why my mic doesn't work and my desktop background doesn't show?
If you have Windows 7 Starter then you are limited on changing the background.
Jun 09, 2012 | Computers & Internet
External vga display doesn't work
Check external monitor settings on Fijitsu.
Jul 03, 2017 | Fujitsu Siemens Stylistic ST5022 Tablet PC
Had a power outage during a lighting storm and now the GE spacemaker phone/unit does not work; it's showing in the display screen "Initializing". The phone works, but when you press any of...
Does it have a battery backup? If so, after disconnecting the AC power adapter, remove the battery for 15 minutes, then re-insert it (make sure it is a good battery), plug the AC adapter back in, and try again. Hopefully, this will re-set it. If not, it probably isn't worth tryiing to repair. May have to buy a new phone.
May 06, 2017 | GE Spacemaker 26976 Cordless Phone
Dosnt work
If display is scrambled, reset timer: Push reset button while holding down enter button.
If display doesn't show, check AAA batteries.
If timer still doesn't work, then Contact Intermatic.
8000 series comes with 1 year limited warranty
https://parts.intermatic.com/
Intermatic does not show replacement memory board for ET8000 series
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 29, 2011 | Intermatic ET8215C- 7-Day Electronic...
NO DISPLAY ON UNIT
Pull your display off wall and see if your unit has batteries. If you have a blue wire or, a wire connected to the "B" terminal in your thermostat(the part connected to wall, this should produce the power to show display. If you do not have a blue wire, it is dependant on the batteries for display. Change out batteries and see what happens. Obviously with no display, your system won't work. If this doesn't solve your problem, replace the thermostat.
Apr 26, 2011 | White Rodgers White-Rodgers 1F85RF-275...
Display screen doesn
I had the same problem here,,,
This was my friend rowing that we received as a "gift" (he wasn't using it anymore) and the LCD display stop working.
Without the user manual, I decided to remove the side panel and by doing so the LCD panel pop out showing the source of the problem...
The AA battery simply felt off inside the case.
So my guess is that either your battery felt off or is dead.
So here're the steps...
1. remove the LCD panel (use a flat screwdriver if needed)
2. if there's no battery, it is probably inside the assembly. You can try to retreive it by removing the 7 screws on one side or simply leave the battery if it's not interfering with the rowing mechanics.
3. if there's a battery, it's probably dead. Change it!
Apr 02, 2010 | RTO Lifespan RW1000 Rowing Machine
Dont take any pictures
Change the batteries and try again.
Feb 12, 2009 | Kodak Advantix F620 Zoom APS Point and...
5303L 2Way LCD Remote Start Security System Logo
21 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
Colin Stickland
Colin Stickland
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
