Question about Sony KV-32S36 32" TV
Sony TV not working
The TV is 10 years old and it suddenly went blank while I was watching a program. When I press the power button, there is no click, picture or sound. Checked the fuse and it is fine. Any suggestions welcome.
Thanks.
  • 45 Answers
This is not an easy fix for most people! I suspect the ps is blown, R607, Q601,Q602 (use all org Sony parts, lots of factory 2nds around). This stuff blows to protect the fuse!!!!! Very rarely the input bridge rectifier or filter cap short.
Check R622, if open or discolored also replace VDR601(doesn't go bad very often). Check Horz output Q502. Inspect whole board for any bad connections, all parts with heat sinks(regulator ICs). Horz driver transformer, 0.47uf to horz driver tr. There could be other parts bad (flyback??). Make sure no supplies are shorted, check audio output supply, vert output supply, etc. Easily $150 repair at a shop. Good luck!
Posted on Nov 04, 2007
Was watching live tv on my seven day old hisense 65k700uwd tv, when I pushed the you tube button the tv went completely blank (no sound or picture) and the remote wouldn't work
Cheryl, unplug, wait 10 minutes plug back in, if this does not reset it, return for refund or exchange.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 04, 2016 | Hisense Televison & Video
Screen is going blank but blue power light stays on
most likely a capacutor has blown or it just lost the signal. try unplugging all connections while powered off the replug the power on. hopes this works. if it dsoes please rate with a comment
Feb 07, 2013 | Sceptre "32"" Class 720p 60 Hz Lcd Hdtv...
I was watching a dvd on my week-old Sony Bravia XBR-52HX909 for the past three hours when the screen suddenly went blank. The standby indicator light in red started blinking. I attempted to turn on the...
This tv only a week olds,should never having this problems already.The tv should be return and get a new tv for the replacement,this tv have tv Tuner signal board or tv power supply board distrubution problems.Even when the store test it out it work,don't take that tv back.Insit they give a new tv for the replacement.
Dec 13, 2010 | Sony Bravia XBR-52HX909 52 in. LCD HDTV
My JVC LT-42X579 42 in. LCD TV is only 13 MONTHS old and it suddenly won't turn on anymore. The blue power light comes on -as usual- but after 3 seconds, it will start blinking and it will remain that way...
I contact JVC and was told to first make sure your cable box or whatever you use to normally watch TV is powered on and is ready to work
He told me to unplug TV for 10 seconds at least. Then he had me press and hold down the "MENU and VOLUME DOWN (-)" buttons, at the same time for about 10 seconds. Then after 10 seconds of holding the 2 buttons down, he had me continue to hold the 2 buttons and press and let go of the power button. In other words after 10 seconds of holding down the volume down (-) and menu buttons, add the third button (power) and immediately let go of all 3 buttons, at the same time.
It worked for me instantlynd hopefully it works for you!!!
Nov 20, 2009 | JVC LT-42X579 42 in. LCD TV
Sony KV-32S36 32" suddenly stopped working, no picture or sound
Check soldered in fuse R607 in power supply circuit =
If open, replace it and bad converter xistors ( 2SC4834)
Next, replace shorted horizontal output transistor w/ first Quality.
Solder any / all bad connects,esp.horiz drive to base of horiz.
o / p xistor. Soldering is critical or it will blow up again......
Oct 27, 2007 | Sony KV-32S36 32" TV
Bush id tv
Dear Sir, unfortunately tonight you will not be able to watch this TV set. Please try with an alternative solution. This job definitely requires a professional technician Best regards, Arpi
Jun 17, 2007 | Bush 5693D 24" TV
Loud electrical sounds
It sounds like the Power transistor that drives the High Voltage Transformer shorted out. The rapid clicking sound you are hearing when pressing the power button now is that of the power supply starting to come up, detecting a short circuit and shutting back off again, preventing further damage. It is likely that the HV Transformer is shorted as well which usually causes the Output transistor to fail. Since the set is only 2 1/2 years old, it is probably worthwhile getting it to a repair shop as long as you have been very satisfied with the picture quality up to this point. If the picture size was larger than you needed, you might consider going down to a 37" LCD HDTV set. Toshiba is tops in this category IMHO.
Mar 30, 2007 | Zenith R40W46 40" Rear Projection...
Electricution sound w/ clicking noises and no picture
I am having the same exact issues wih the same TV and mine is only 2 years and 6 months old. Please let us know what is going on. Thank you.
Mar 07, 2007 | Zenith R40W46 40" Rear Projection...
Televison & Video Logo
127 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
