Hi I used my drier and worked fine, went to turn it off and light stayed on and the off button would not turn off. Turned it off via the plug, now will not come back on. What is the fault , and is it easy to fix Many thanks . My tumble drier is a Login LVD7W15 Many thanks
If so, probably bad gas solenoid valves. They can safely be replaced without fear of releasing gas. Two phillips screws, two pull off wire plugs. That's it. Cost about $30 bucks depending on where you buy them. They are a universal part and will fit 99.9% of machines.
Hello my name is George, I was wondering if the dryer was just burning fleece or all of your clothes. Fleece is a very delicate material, and should be dried on low temp or delicate depending on your drier. Driers are thermally protected inside with various parts. If the drier is getting to hot one of these would have caused the drier to stop heating. If the drier is burning all the clothes and not just the fleece I would recommend having a technician come out and check it as this could be a hazard for you and your family.
Hi John, W/D here. Most likely scenario: squealing was either a belt or a bearing. Failure to run is probably a broken belt. Gain access to the back of the drier, with the power disconnected. Open the back and check the belt. If broken, replace it, and then rotate the drier by hand, listening for additional squeals and squeaks. If no other issues are noted, replace the back cover, plug it back in and try it out. Best regards, --W/D--
The timer on your dryer is more than likely bad. You already know what the timer is and where located. Not really that high priced thru ebay or an appliance repair outlet. Usually just a screwdriver and a small socket is all you need to change. Great sense of accomplishment when you finish and it works while saving a lot of $$$$. Stan
