Question about Jenn-Air JFC2089HE French Door Refrigerator
Door on left has dropped
Door hard to shut and appears to rubbing on bottom tray
I bought a house that has this dishwasher. I do not know how old it is. It does a great job of cleaning dishes but three problems: 1. how do you know when it is finished? it has no lights, only a plain...
There is an indicator light on the top left side of the door, it's on when running and flashes for about an hour when done. There should be a reflector attached to the bottom of the countertop, with double sided tape, above the light, allowing you to see the light when the door is closed. It looks like a piece of clear plastic about 2x2 inches. To turn the dishwasher off, when not in use, you need to press the off button, and press the on button when you want to use it, that's normal for your dishwasher. The door latch might need a little adjustment. On the top edge of the dishwasher, in the center there is a small metal latch sticking out. You can loosen the screws and move the latch out, just a little, tighten it up again and see if that makes it easer to latch the door. Don't move it out too much or it could start leaking from the door seals. Also make sure the door is not rubbing on the cabinetry or countertop. The bottom basket should just have tines for 2 rows of plates, you should be able to fold one side down. Silverware goes in the cutlery tray at the very top of the dishwasher.
Mar 28, 2015 | Miele 24 in. Incognito G843SCVi Built-In...
In my machine when we switch on the machine the code c- 0920 appear
One of the trays has a lift problem, try clearing by touching the small wrench in the bottom left of the display (if the wrench isnt there open and close the front door) after touching wrench open and close front door, if that doesnt work one of the trays needs troubleshooting
May 01, 2014 | Konica Minolta Minolta Di450 Di470 Di550...
TRAY UNDER DOOR DOESNT OPEN AND SHUT PROPERLY MODELCCP-509
One of the tabs on the bottom of the drop panel (the lower metal door that folds out) is bent incorrectly. Try bending it a little which every direction is needed to close the drop panel.
Do not break it, there are no replacement parts for that brand.
Nov 07, 2013 | Helman Group CCP509 Popcorn Maker
My Bosch economic cooler has a door problem. It no longer shuts automatically unless one pushes it hard to shut it.
check for food or shelves protruding. Check if door is rubbing on the bottom, sometimes scrape marks are evident. check to see if gaskets are sticky if so clean them and apply thin layer of petroleum jelly. Depending on the model sometimes the closing cams are broken on the bottom hinge.
Apr 14, 2011 | Bosch Refrigerators
Sir I have canon IR2016J that some of days paper jam tray not working properly message shows paper jam open left cover but there no paper in machine.
first, do you copy from second drawer or bypass tray or first drawer?
Open the left door, in lower section open the paper cover. Now remove drawer. If You look from the left door side beneath the drum unit, you will see axis with 2 rollers, CLEAN them with alcohol or water by rubbing them, and dry them with dry cloth.
Also if you look little closer beneath the axis with rollers you will see the two rollers ( grey, one above the other ) clean them also or replace them if the rubber on them are too smooth.
If the problem appears when copy from second drawer, i.e. A3, you need to replace the pick-up clutch!
If the problem appears when copy from bypass, clean the bypass feed roller.
Hope that something of these helps you!
Mar 30, 2011 | Canon iR 2016i Black and White Copier
Fridge Door seems to have dropped
The cam risers at the bottom hinge have gone bad. Get the model number form the fresh food section and you will be able to order new ones. Not expensive to repair.
May 16, 2010 | Refrigerators
Oven door sqeaks and is hard to open all the way . Is there a way to adjust the hinges on the door? Everytime you open it, it makes a sound like metal rubbing on metal
Adjusting the oven door is best left for a factory trained tech. There is alot involved with getting the hinges and monitor switches working together in harmony. alot of times the bottom grate on the front of the oven rubs on the door and usually gives you the metal on metal sound. the bottom grate just pulls off. Then see if its still rubbing. Be sure that the oven door has all of the screws and they are tight before calling for service. There are 3 screws on the left side and on the right side without them you will have problems.
WARNING: Procedure should be done while
oven is hot. As a result, exercise extreme
caution when adjusting the door.
good luck Sean
Nov 18, 2009 | TurboChef TORNADO Electric Oven
Minolta cspro ep2010
Do you have two trays or four trays for the paper? If you have four and the display is showing the bottom door is open... turn the copier off and disconnect the bottom two trays and turn it back on..... Just use the top two paper trays.. Or the problem is that a acturator is broken off the side door, look for any broken pieces of plastic. Also, recheck for any jamed paper left in the copier.Good Luck
Jun 12, 2008 | Office Equipment & Supplies
Jenn-Air JFC2089HE French Door Refrigerator Logo
21 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
