53017 round to the nearest hundreds
How can we round numbers to hundreds if there's a 0 on the hundreds place
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
The same way you would do it if the digit is something other than zero.
53017 rounded to the nearest hundreds is 53000.
Posted on Nov 06, 2014
  • 41 Answers
SOURCE: Estimate the total cost by rounding the total cost of each car an
195 reps --> 200; $21710 --> $21700; 200 * 21700 = $4,340,000
Posted on Sep 15, 2009
  • 7993 Answers
SOURCE: ACME Skateboards Inc., has paid
Doesn't any body do their homework anymore? How are they supposed to learn anything?
Draw your graphs by hand or on a graphing calculator.
Think about the intersection points. (What does that mean when two curves intersect?)
Use the equation for the demand to obtain D for a particular x.
You can also determine by how much one function exceeds another for a particular value of the x variable (the graph is rather clear).
I assume you can solve a quadratic equation.
Use these hints to solve the problem.
Here is a graph. I even restricted it to the first quadrant so as not to mislead you into giving meaningless answers.
Hope it helps.
Posted on Oct 04, 2009
SOURCE: i need to round 301,421,
Well that would be... 301,500,000 rounded UP, or 301,400,000 rounded down.
BUT the second answer, 301,400,000... is YOUR answer....
The nearest hundred thousand is 400,000... hence the answer, see?
Posted on Aug 19, 2010
rw93003
SOURCE: How can I change the setting to print total the
You need to set your decimal selection to full-floating if you expect any numbers to be more than 4 decimal places.
Each time you press the DEC key it changes the decimal selection. From F to 0, 2, 3, 4 and A in that order. F is "full floating" but appears as a blank on the screen. A is the "add-mode" for currency transactions. The "A" does show on the screen if this is your selection.
As soon as the letter for the number of decimal places you want ("F" is blank just before 0 decimals) appears on the screen you are "ready to go." Problem is, the decimal indicator numbers and letters are so tiny and screen is so difficult to read that under many lighting conditions your selections might be all but invisible. They are in the upper left side of the screen just to the right of the equally difficult to see multiplication and division rounding indicator "5/4." PS If the 5/4 does not appear on your screen then you have set the round-off function to not available.
Posted on Apr 01, 2011
thehappydog8
  • 50 Answers
SOURCE: what is 27,415 rounded by
27,400 is the answer
Just like rounding your 10's
The breaking point is at 50 instead of at 5
So if the number was 27,465 it would be 27,500
Posted on Jun 23, 2011
I need your help to tell me what 1925 is rounded to because at school I am really struggling and I look a bit silly in front of everyone and I get enbaressed
That depends on what you want it rounded to,
To the nearest thousand: 2000
To the nearest hundred: 1900
To the nearest ten: 1930
Feb 01, 2017 | Homework
How do you round 87,147 to the nearest 100
I want to take you through the steps of rounding so that you can do it with this number, and any other number.
Step 1 - Find the column in question.
Step 2 - Look to the number immediately to the right of this number.
Step 3 - If this number is great than or equal to 5, add 1 to the column in question.
Step 4 - If this number is 4 or less, don't add the 1
Step 5 - Since this number is to the left of the decimal, make all numbers to the right of this number a 0.
Using the example provided of 87,147 to the nearest hundred.
The hundreds column is the third column to the left of the decimal. Ones, Tens, Hundreds. In this case, the 1.
The number immediately to the right of this number is 4.
This number is 4 or less, so we don't add 1 to the hundreds column.
We set all numbers to the column in question to be 0.
I get 87,100.
Good luck.
Let me know if you have any questions.
Paul
Apr 07, 2016 | Office Equipment & Supplies
Which number rounds to 5,000 when rounding to the nearest hundred? a.5,107 b.5,089 c.4,963 d.4,962
Step 1 - identify the column - hundreds - and check the number immediately to the right.
Step 2 - If the number is 5 or more, add 1 to the hundreds column, otherwise leave it the same.
Step 3 - set all numbers to the right of the hundreds column to 0.
a. 5,107 rounds to 5,100
b. 5,089 rounds to 5,100
c. 4,963 rounds to 5,000
d. 4,962 rounds to 5,000
Good luck,
Paul
Oct 06, 2015 | Office Equipment & Supplies
159.501 rounded to the nearest thousand?
Calculators usually have a position switch to do it for you.
Rounding Numbers to the Nearest Thousand - AAA Math
www.aaamath.com/g3_41cx1.htm To round numbers to the nearest thousand, make the numbers whose last three digits are 001 through 499 into the next lower number that ends in 000.
Feb 16, 2015 | Office Equipment & Supplies
Estimate by rounding to the nearest hundred
118+146
Round 118 to the nearest hundred. Look at the number to the right of the hundreds column. If it is 5 or greater, add 1 to the hundreds column. If not, don't add 1 to the hundreds column. Make all columns to the right of the hundreds column 0. Since the number in the tens column is 1, we don't add 1 to the 1 and make the 1 and 8 zeros, so we get 100.
We do the same with 146. 4 is less than 5, so we just change the 4 and 6 to 0 and get 100.
We now add 100 and 100 and get our estimate of 200.
Good luck.
Paul
Oct 20, 2014 | Office Equipment & Supplies
How do you round 5,403.264 to the nearest hundred
Assuming you do mean to the nearest hundred, answer the question 'is this number closer to 5400 or 5500?' It is closer to 5400 (The first digit to the left of the decimal point is 'ones', the second place is 'tens', the third place is 'hundreds', so you look at the third digit to the left to round to the nearest hundred)
If, in fact, you meant hundredth, answer the question 'is it closer to 5403.26 or 5403.27?' It is closer to 5403.26 (The first digit to the right of the decimal point is 'tenths', the second digit is 'hundredths', so you look at the second digit to the right to round to the nearest hundredth)
Sep 17, 2014 | The Learning Company Achieve! Math &...
I neeed to round 740,692 to the place value
Round to which place value?
To the nearest million: 1,000,000
To the nearest hundred thousand: 700,000
To the nearest ten thousand: 740,000
To the nearest thousand: 741,000
To the nearest hundred: 740,700
To the nearest ten: 740,690
Sep 02, 2014 | Office Equipment & Supplies
How can i round to the hundreds or thousands?
Put the calculator in scientific display mode (SHIFT>MODE(Setup)>FIX. You will be asked to enter the number of fixed decimal digits. Enter 2 for hundredths, and 3 for thousandths. To round to the nearest hundreds or the nearest thousands, do it by hand as follows.
For hundreds
Locate the hundred digit. Let it be h.
If the next digit (the tens digits is less than 5 replace the 10 and unit digits each by 0. Your result will look like ...h00.
If the 10s digit is 5 or above (5, 6, 7, 8, 9) you must round up by increasing the hundreds digits by 1. Your result will look like ...(h+1)00
For thousands
Let the thousand digits be t
If the hundreds digits to its right is less than 5, replace it and the digits following it by 0. Your result will look like ...t000.
If the hundreds digit is 5 or higher, increase the thousands digits by 1 and replace the hundreds, tens, and units digits by 0. You result will end with (t+1) 000
Note if (h+1) or (t+1) give you 10, put a zero at their positions and increase the digit to the left by 1.
Example. 78997 to the nearest hundreds 78997 becomes 789(9+1)0 or 78(9+1)00 or 79000
May 22, 2014 | Casio FX-115ES Scientific Calculator
Round off to the nearest hundred 2x12x0.23
2x12x0.23 is 5.52. 5.52 rounded to the nearest hundred is 0 (zero).
If you want the result rounded to the nearest hundredth, it's 5.52.
Feb 04, 2014 | Office Equipment & Supplies
113 people viewed this question
jasbo
jasbo
