Question about Logitech Computers & Internet
How to clean a M210 wireless mouse
Wireless mouse
Microsoft 800 wireless. How do I disassemble and clean?
How to open microsoft wireless mouse 800 - YouTube
? 3:06
https://www.youtube.com/watch?v=ptrvp9Vjz8g
Aug 25, 2013 - Uploaded by rabb able
This video is about if ur mouse left click is not working or hard clicking for use then this is simple way to open ...
Microsoft Wireless Mouse 5000 disassembly - YouTube
? 0:53
https://www.youtube.com/watch?v=vnU3xYoxcSo
Jan 31, 2012 - Uploaded by keroronsk
Microsoft Wireless Mouse 5000 disassembly ... to get to my scroll wheel...the dang thing's rubber seal has detached and I can't scroll anymore.
Microsoft Wireless Mouse 800 Teardown/Disassembly ...
? 3:35
https://www.youtube.com/watch?v=_I4n-WM3nh8
Mar 21, 2015 - Uploaded by Shin2_D
Microsoft Wireless Mouse 800 Teardown/Disassembly ... [Quick tips] Simple way clean your Android Wear LG Gwatch - Duration: 1:05. by ...
How to disassemble Microsoft Wireless Mobile Mouse 1000 ...
Dec 12, 2015 | Computers & Internet
How remove trackball for cleaning?
Most folks do not clean the trackball as most have wireless mouse that do not ever need trackball cleaned inside, but just need new battery replaced by pushing tab to open part where battery is.
Apr 29, 2014 | Kensington SlimBlade Media Mouse -...
Laser mouse very inaccurate?
Instructions
    • 1
      Check your wireless connection. If you are using a wireless adapter or USB linking device, ensure that everything is plugged in properly. The best way to do this is to unplug the device and then plug it back in, making sure everything fits snugly.
    • 2
      Try to re-sync your mouse with your computer/adapter. If your computer came with wireless networking capabilities (such as Bluetooth) and your mouse uses this signal to communicate with the computer, go to your computer's control panel and turn off the network for a few minutes. Then reboot the network and see if the connection to your mouse has been restored. If you are using a wireless adapter, go to the wireless utility that your computer uses to manage the wireless mouse (this can usually be found in the "programs" section) and repeat the above process.
      Look at the bottom of the mouse. If your wireless mouse has a trackball, try removing the cover and cleaning the individual wheels on the inside of the mouse with a Q-tip. If you are using an optical mouse, then try cleaning the bottom of the lens with a soft tissue and a frugal amount of glass cleaner.
    • 4
      Ensure that any drivers needed for the mouse are still installed. Although it is unlikely, the drivers that facilitate communication between your mouse and computer may have been accidentally corrupted or erased. Try visiting the mouse manufacturer's website to download new drivers.
God bless you
May 24, 2013 | HP Wireless Optical Mouse
Ineed a manueal to download for K260 keyboard with M210 Mouse.
Hi ,
The best thing to do is go to www.logitech web site and type in model number/drivers and it wil come up with a list of drivers you can download ......................Good luck Roy
Sep 17, 2011 | Logitech Computers & Internet
Why did my wireless mouse stop working?
check if the battery of your mouse is out of power. and if it is out of power replace the battery and clean its sensors from the mouse.
May 09, 2010 | Microsoft Wireless Laser Mouse 5000
Our mouse is jumping all over the place. Have removed the ball, cleaned, new batteries, etc. What else can we do. If there is nothing else, how can we keep our wireless keyboard connected but use a regular...
With a ball mouse the parts to clean are the two small spindles inside the mouse (they usually have little gears on the end of them). They run at 90 degrees to each other and over time dirt and grease build up on them. It can be quite difficult to remove. Scrape it off with a cocktail stick or similar - you will need to turn the spindle as you do this to completly remove dirt on all sides of the spindle.
Nov 08, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Wireless mouse intermittent
try going into your control panel, go mouse/ settings change your mouse settings and get some air for computers clean everything on the mouse
May 18, 2017 | HP Wireless Optical Mouse
Wireless mouse
Try a different mouse pad or use on a white sheet of paper.
Make sure there is no source of electromagnetic interference, like speakers, magnets, etc, close by.
Stay within a 4 foot range of the reciever.
Try a different USB port for the reciever, and try to elevate the reciever (if corded type), by placing it on a book.
Do not use the mouse on metal/glass surfaces as this can affect tracking ability.
Try a replacement of batteries with a fresh set.
Hope that helps!
May 18, 2008 | Dell Wireless Keyboard Optical Mouse w0147
User guide Samsung M210 cell
This link should help you:
http://www.telusmobility.com/content/clientcare/pcs_east/guides/samsung_m210/samsung_m210_Eng_UG_web.pdf
Jan 02, 2008 | Samsung SGH-D900 Cellular Phone
Computers & Internet Logo
99 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
