Question about Frigidaire Kenmore Washer Tub to Pump Hose 134455900
Humidifier motor Kenmore 758.144161
I need a fan motor for the 758 144140 Sears Kenmore Humidifier
I have a Kenmore Quiet Comfort Electronic humidifier, model 758.144140. Is missing filter holders, and float switch, so is inoperable. Motor works fine. Contact me if you want the motor - mnwilli@hotmail.com. No charge if you pay for shipping. I will include 2 filters, can include any other parts you want. Why the offer? Space in my house worth more than an inoperative appliance.
Dec 16, 2015 | Kenmore Humidifiers
How do I fix my blower problem on my humidifier?
Free Sears Humidifier User Manuals ' ManualsOnline.com
homeappliance.manualsonline.com > ... > Household Appliance Sears
Products 1 - 11 of 11 - Sears Humidifier 758.144120. Sears Kenmore Evaporative Console Humidifier Owner's Manual. Pages: 0 Saves: 0. See Prices
Oct 29, 2015 | Kenmore Quiet Comfort 12 Humidifier Filter...
Motor on one of the fans burnt out-is it repairable?
Brief research on Kenmore products looks promising--
Sears claims to have all parts, no matter where you bought it--
Here is the link to Humidifiers:
http://www.searspartsdirect.com/partsdirect/brands-products/Kenmore-Parts/Humidifier-Parts
Let us know if this helps
Mack B
Jan 15, 2011 | Kenmore 14416 Humidifier
Kenmore Humidifier 14114 - the fan suddenly stopped running. Changed fliter and water, unplugged the unit, changed dial to highest humidity level - the unit will not run.
Hi
Please turn off the power to the unit and unplug it. Now check the fuse inside the unit, make sure its fine and not burnt If fuse seems OK then inspect the connections to the fan and make sure the wires are not cut. Also, inspect the control for any burnt components, use a multimeter to confirm. Hope this helps... Please post back with complete model# if you need more information.
Daniel
Jan 04, 2011 | Kenmore Humidifiers
I need the manual for the 758-144170 Sears Kenmore Humidifier
http://www.managemylife.com/mmh/owner_manuals/22799/KENMORE-Humidifier-L0411294
Dec 16, 2010 | Kenmore 14417 Humidifier
How to adjust the thermostat,for kenmore humidifier
I need a little more info to help you. What do you mean by "how to adjust the thermostat, for kenmore humidifier". Do you need to know what the relationship is to the setting and moisture in the air? Let me know.
hardrocko
Feb 10, 2010 | Kenmore 14417 Humidifier
Kenmore Humidifier not operating?
Turn the unit off, lift the fan assembly off the base, and push the connector together that goes to the float switch on the bottom of the fan motor. If you hold the switch in with your finger (careful not to get into the fan blades) and turn the unit on, the F indication should go away. F (as in Fill), apparently, means the base has no water. The plastic tube that sticks up out of the base floats on the water and pushes the switch. Put it back together, it should work!
Dec 08, 2009 | Kenmore Humidifiers
Can't find valve button for float (part #28110101 no longer available)
Greetings!
We just got a new furnace with humidifier, so they took out our old Kenmore humidifier.
We now have 4 of these parts...........valve button for float #28110101.
Linda
Feb 01, 2009 | Kenmore 146010 Humidifier
Humidifier manual
ManageMyHome.com. allows you to print pdf of the manual you need.
Nov 09, 2008 | Kenmore 14410 Humidifier
Frigidaire Kenmore Washer Tub to Pump Hose 134455900 Logo
12 people viewed this question
Top Kenmore Vehicle Parts & Accessories Experts
Tom Chichester
syspro
ericschnidri
ericschnidri
Level 1 Expert
Are you a Kenmore Vehicle Part and Accessory Expert? Answer questions, earn points and help others
