Question about Roper Washing Machines
Take roper washer apart model # RTW4440VQ1 - Roper Washing Machines
I have a Roper washer and model number is RTW4440VQ1. We bought them used setat an estate sale and they looked brand new...they were well taken care of.
Your electric valve (solenoid) for the hot side is not working, and you originally had the two hoses reversed.
May 15, 2015 | Roper Washing Machines
I have a Roper washer Model RAX4232PQ0 When it drains and spin cycle comes on it makes a very loud rubbing slash screeching sound and when we open it it smells like a burning smell Not rubber burning but...
Known problem:
A Failed switch Ark-Les part #8318084
Incident report on there website:
I have a Roper model #RAX4232PQ0 top-loading washing machine. The door switch wore out, short-circuited, and caught on fire. The machine continued to operate, so it took a little while to figure out where the smell was coming from. The failed switch is an Ark-Les part #8318084.
Dec 19, 2013 | Washing Machines
My washer functions on all cycles but will not spin
Generally if a washer will not spin it is due to a broken door (lid) switch. The lid switch
can appear good but may be cracked. You can find the model number under the lid
and google parts for that particular model. Many parts sites have expanded
diagrams to help figure out how it comes apart.
(Generally the two screws on the control panel are removed
and the panel hinges back to access the plug to remove the switch)
Hope this helps.
Mar 06, 2011 | Roper Washing Machines
WHEN SPINNING, SOUNDS LIKE GEAR IS STRIPPING
This is usually caused by the coupler very inexpensive and easy to fix. This video will walk you thru the process. Scroll down to the video on taking apart a whirlpool stlye washer it goes thru replacing the coupler properly. Your washer will come apart the same as in the video.
www.appliancehelponline.com/servicemanual.html
Mar 12, 2010 | Roper RAS8445KQ Top Load Washer
I have a roper washer that wont spin. Probably the coupler. I have changed couplers many times on other types of washers whirlpool amana and kenmore. etc. is the process the same with a roper ?
exact same as a whirlpool, for they own roper, amanas do not have couplers..... the kenmore might if the model starts with 110.********* or 118.*********
Jan 16, 2009 | Roper RAX4232KQ Top Load Washer
Washing Machines Logo
46 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
